Old 06-04-2010, 12:19 AM   #1
Estiee
My Ride: e46 318i MY2000
Question Advancing timing on 318i... Please help.
Hi Guys.
I have a nugget 318i, and in all of my cars i use 98RON premium fuel, as its better for the engine in long term and gets a slightly better mileage , so thought why not advance timing for maximum benefit and use all of the 98RON that i pour in there weekly.
1) Just wondering, how well do these engines respond to advance timing?
2) Do these engines have knock sensor which will throw out the advancing ?
3) How do i advance timing on these engines?
Thanks in advance guys.
Estiee is offline   Reply With Quote
Old 06-05-2010, 01:30 AM   #2
Estiee
anyone?....
Old 06-05-2010, 02:08 AM   #3
kai-
My Ride: three two slow
pretty sure the ecu adjusts timing based on the fuel you use. you could probably advance it further....
best guess would be to get it chipped
a 318 is a 318 short of turbo/super charging there is really no gains to be had
kai- is offline   Reply With Quote
Old 06-05-2010, 08:57 AM   #4
paraklas
My Ride: ESS TS2 320ci
Originally Posted by Estiee View Post
Hi Guys.
1. Pretty good, any modern engine advances timing according to fuel, temp etc.
2. yes
3. You can't. Only through software. Question is why? No need to mess with this if you are using RON98
