Group Buy: ATI Damper for M54 - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-06-2010, 12:18 PM   #21
McSpeed
My Ride: 2005 ZHP TT Stg 1
Originally Posted by mspiegle View Post
I believe one of the threads made a reference to a HP limit for this unit at around 500hp. Is this something to be worried about if you want to make more power than that?
This is how ATI was sizing E46 dampers as of a few months ago:
Ricky said a 5.5" damper was good for up to about 500-550 hp.
He said a 6 7/8" one like Adam's would be good for 1000+hp.
He and another sales rep, Chris, were very focussed on max hp determining the damper size.*
RPMwise they had three types of tuned rubber they'd mix and match for the 'inertia ring' depending on the redline and the typical RPM range the damper would experience.
*not saying it's the best way - it's just the approach I saw in action
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 06-10-2010, 03:34 PM   #22
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Bump!
Old 06-10-2010, 03:50 PM   #23
aggieE46
Keep it clean
aggieE46's Avatar
1. aggieE46
2. bluejeansonfire
3. trippinbimmer
4.
5.
6.
7.
8.
9.
10.
Old 06-10-2010, 06:21 PM   #24
tinkwithanr
My Ride: '00 323i + '75 2002
Ahh... If I can get my bonus in time this might be my next investment.
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
Old 06-12-2010, 03:30 PM   #25
gte869h
My Ride: 2002 330i Orient Blu
You can count me in (please get the price to drop even more). I have a 5-rib A/C belt btw.
Also, will I be able to provide a list of my mods for a very specific damper or is ATI providing us a one size fits all solution based on just peak HP?
gte869h is offline   Reply With Quote
Old 06-15-2010, 04:06 PM   #26
McSpeed
Does anyone have easy access to an M54B30 crank?
I need a measurement for the design of an installation tool:
"What is the measurement from the end of your crank snout to where the threads start in the crank?"
Old 06-16-2010, 11:01 PM   #27
McSpeed
it's 50.50mm - thanks to a nameless source
Old 06-16-2010, 11:23 PM   #28
McSpeed
The damper does a pretty specific thing - it snuffs out resonances at the natural frequencies of forged steel in order to avoid crazy harmonic crank twisting torsion. Based on my research ATI is the top dog in this field - they're the official NASCAR damper supplier and they have lots of great reviews on other car sites - so I'm confident in their approach even though it sounds kind of simple. And it's only a one size fits all solution because our cars generally fall below the thresholds that, in their experience, would necessitate a change in design; few, if any of us, plan on exceeding 550hp and 7500 rpms. Except bluejeansonfire
Old 06-17-2010, 02:32 PM   #29
gte869h
Thanks for the info.....
I ask b/c I thought things like rpm redline (7000 for me), standard N/A mods, and Light-weight Flywheel (UUC Stage 2) affect how the damper should be tuned. I expect the ATI solution takes these thing into account. Based on the info I've found, a flywheel change significantly alters crankshaft harmonics.
Got another few questions;
It was mentioned you could rebuild this thing for $75 with new o-rings so in effect the damper is good forever. Does the damper need to be removed from the crankshaft in order to be rebuilt? If so, based on how tight the fit is can this be done with a large gear puller, or is a special tool also necessary for removal? Is the damper housing made out of steel or aluminum?
Brady, any updates? Can we still keep the same deal if only 5 people buy?
Old 06-17-2010, 02:43 PM   #30
aggieE46
Keep it clean
aggieE46's Avatar
Not sure, man. He told me 10.
1. aggieE46
2. bluejeansonfire
3. trippinbimmer
4. gte869h
5.
6.
7.
8.
9.
10.
Old 06-17-2010, 02:47 PM   #31
HighBoostin330
My Ride: 2002 Stock 330Ci
Any word on an install tool being provided by ATI? Not all of us are as skilled as Adam at being MacGyver.
HighBoostin330 is offline   Reply With Quote
Old 06-17-2010, 03:24 PM   #32
McSpeed
lol I should have an update sometime soon
  • I'm pretty sure it needs to be pulled to be rebuilt
  • from what I hear the dampers are pressed REALLY tight
  • ATI and Moroso and probably others make damper install/removal tool sets that'll work once we get a thread adapter: http://www.atiracing.com/products/da...arts/index.htm
  • the inner hub is steel but the rest of it is aluminum
Old 06-18-2010, 09:03 PM   #33
F1004fun
My Ride: '02 330Ci
Hey guys, I just wanted the let you all know that install tool isn't that hard to make. I wrote all the part numbers on my other post and all you need technically is welder, or a buddy with a welder. I have write-ups on the other tooling you will also need and how I made it.
If you guys are serious I know some guys that do professional fabrication and have a much higher quality.
F1004fun is offline   Reply With Quote
Old 06-21-2010, 05:39 PM   #34
aggieE46
Keep it clean
aggieE46's Avatar
Sorry, guys, I'm going to have to bow out on this one. Too much going on...
Old 06-21-2010, 06:51 PM   #35
McSpeed
Can anyone recommend a good place to rent a 350+ ft-lb torque wrench? The crank bolt is a 300 ft-lb deal.
This looks promising but I haven't talked to them yet: http://www.jmtest.com/pages/productdetail.asp?ID=866
ATI is finally making a thread adapter for their install/puller tool out of the crank bolt I sent them. Will update as I know more.
Bummer man!
Old 06-29-2010, 04:59 AM   #36
McSpeed
it's official - ATI made me a thread adapter for their tool set
The damper should be installed within a couple weeks.
Old 06-29-2010, 06:58 AM   #37
aggieE46
Keep it clean
aggieE46's Avatar
Awesome!!!
I may still be able to pull this off. I don't think my car is going anywhere soon
Old 06-29-2010, 06:35 PM   #38
HighBoostin330
is this included with the GB?
Old 06-29-2010, 07:20 PM   #39
aggieE46
Keep it clean
aggieE46's Avatar
Excellent news. I'll email my contact tomorrow about getting the adapter included.
Old 06-30-2010, 09:21 AM   #40
aggieE46
Keep it clean
aggieE46's Avatar
Ricky said the adapter would not be included. Man, they're not helping out much with this group buy. No shipping, no adapter... Bummer.
