Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 07-07-2010, 10:24 AM   #321
spencers
My Ride: 2006 330i
Later today:
Meyle HD arms/bushings
spencers is offline   Reply With Quote
Old 07-07-2010, 11:46 AM   #322
Martin 03 325i
My Ride: 03 325I
Black kidneys, LED interior lights, replaced hood roundel..good for a while
Martin 03 325i is offline   Reply With Quote
Old 07-07-2010, 03:49 PM   #323
theinfamousdrew
My Ride: 911 Turbo / E70
today.....
I glued the driver B-pillar, also glued my falling window trim on both sides.
also cleaned the inside of my windows
theinfamousdrew is offline   Reply With Quote
Old 07-07-2010, 03:52 PM   #324
theinfamousdrew
Originally Posted by willsbma View Post
Painter my stock rims flat black and put on a roof spoiler, tinted my tail lights and next up is painting my headlight bowls. btw, anyone know where that thread is, for the bowls?
http://forum.e46fanatics.com/showthread.php?t=757907
Old 07-07-2010, 07:59 PM   #325
SHK&BAK3
My Ride: rustles jimmies
Cleaned my interior with some lexyol (sp?), good product my drivers seat was pretty clean but I still managed to get a white rag to turn black
SHK&BAK3 is offline   Reply With Quote
Old 07-07-2010, 08:08 PM   #326
Zero2_2005
My Ride: 328i
Ok, here I go:
Koni Str.t struts and shocks
H&R sports springs
new front swaybar links
new rear Meyle shock mounts w/reinforcement plates
appointment set for this weekend for an alignment
Zero2_2005 is offline   Reply With Quote
Old 07-07-2010, 08:52 PM   #327
whataboutbob
My Ride: 2002 325 xit...
Drove it like i do everyday
whataboutbob is offline   Reply With Quote
Old 07-07-2010, 09:02 PM   #328
joneperry
My Ride: e46 + S60 + Z
yesterday i changed the oil filter housing gasket made sure all the bolts in that area were torqued to spec... last week i changed the entire ccv system intake boot, throttle body housing gasket, icv grommet, the vanos oil line, replaced some washers and O-Rings...today i got to unscrew all the ignition coils and got stuck at removing the wiring harness for them..i also let some oil slip out accidentally
joneperry is offline   Reply With Quote
Old 07-07-2010, 09:46 PM   #329
joeski3d
My Ride: 2000 323i
I replaced my busted rear window regulator saving myself $250 in labor.
But I paid for it with 2.5 gallons of sweat. Not because it was a difficult job (quite simple after reviewing some DIYs actually) but because it was 102 degrees today.
Ballbusters Inc.
DISCLAIMER: No balls were physically hurt during the reading of this post. Should redness and/or swelling occur consult your gynecologist immediately.
joeski3d is offline   Reply With Quote
Old 07-07-2010, 10:30 PM   #330
Guest100615
Account closed per your request
I washed it thru the carwash and gave it a tank of 93 octane.
Guest100615 is offline   Reply With Quote
Old 07-08-2010, 07:33 PM   #331
E-XLVI
My Ride: 05 330Ci ZPP/ZHP/ZCW
over the last week...
Purchased a Porter Cable 7424XP
- Washed -Citrus soak
- Clayed (medium grade)
- Meguiar's M105 / Orange Pad (specific sections only)
- Menzerna PO106FA / Orange Pad
- Menzerna PO85RD / White Pad
- CG Jetseal 109 / Blue Pad (2 coats)
- Pinnacle Souveran wax (by hand - 2 coats)
- 3M Metal Polish (Exhaust Tips)
Polish/Pad combo worked very well.
ID:	366652   Click image for larger version
ID:	366653   Click image for larger version
E-XLVI is offline   Reply With Quote
Old 07-08-2010, 07:54 PM   #332
spencers
My Ride: 2006 330i
^ SUPERB!!!
Today I changed out my grilles. Bought some lightly used M3 coupe kidney grills.
I really think the previous owner somehow fit sedan grills in there. The old ones were terrible!
Also, found out I have an OEM alarm installed. Managed to break the tabs where the interior roof sensor is, and had to superglue the tabs back on. Good as new!
Old 07-08-2010, 08:02 PM   #333
rka976
My Ride: '04 325Ci - Step
Today I ordered Orion V2's. Should have them for install on Monday.
rka976 is offline   Reply With Quote
Old 07-08-2010, 08:05 PM   #334
tony325ci_51
My Ride: BMW 335i 2007 Coupe
Today... Just washed my 330Ci when I came home from work, ready for driving it at the weekend.
tony325ci_51 is offline   Reply With Quote
Old 07-08-2010, 08:11 PM   #335
rka976
DUDE! Someone moved your steering wheel to the passenger side!
Just playin. Looks good tho.
Old 07-08-2010, 08:21 PM   #336
IntegGeezer2Bimmer
My Ride: M3
i let some hot asian ucla college students wash my bmw
Originally Posted by Born Again View Post
you have to understand the people that jump from car to car often have NO MONEY
they are usually making poor financial decisions and rolling over debt.
No offense to some members on the group but there are dudes making less than $35K driving in fairly new cars - lol like leasing a $40k car - wtf - the car is worth more than what you make in a year!
OP just be sensible - good luck!
IntegGeezer2Bimmer is offline   Reply With Quote
Old 07-09-2010, 12:08 PM   #337
hk_e46
My Ride: 2000 318Ci
struggling with the generator..
then..
found out the steering pump is leaking also...
Spec.: E46 318Ci 2000'
A bimmer fans from Hong Kong
hk_e46 is offline   Reply With Quote
Old 07-09-2010, 08:20 PM   #338
theinfamousdrew
Today i installed another 12v power source on the rear end of the console
I used this:
http://www.oreillyauto.com/site/c/detail/CSM0/10749.oap
And here is how it turned out....(sorry for the shitty iphone pics)
Old 07-10-2010, 04:42 AM   #339
Imola.ZHP
My Ride: Imola ZHP
Installed the Connects2 and Parrot bluetooth kit Might have started on the front brakes if I hadn't spent an hour trying to figure out why I didn't have radio anymore after installation. The power wire/pin popped out of the aftermarket wiring harness, easy fix once the trouble was located...
About to go loom, tape and zip tie my Orion V2 kit, its been on the car since February, so I'm just slightly behind on wrapping that up...
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
Old 07-10-2010, 05:07 AM   #340
Boomdog
My Ride: BMW 323i 1999 Sedan
I ordered:
1 E46 Smoked LED Tail Lights For Sedan (98-01)
1 E46 Smoked Front Indicators For Sedan (98-01)
1 E46 Smoked Side Indicators For Sedan (98-01)
1 LED Reverse Bulbs (White)
1 LED License Plate Bulbs (White)
1 LED Front Indicator Bulbs (Amber)
1 LED Side Indicator Bulbs (Amber)
and put a deposit on some 19" Mesh Gunmetal Alloys.
Oh, and drove around all day listening to some cool trance.
Boomdog is offline   Reply With Quote
Rate This Thread
