Sponsored by BimmerWorld
Old 07-05-2010, 10:18 PM   #1
BMW_Stu
My Ride: HPF 330ci
how to tighten down front shock mount?
today i helped install a kwv2's on my friend's car, everything went well but we had a very hard time tightening down the nut that holds the upper shock mount onto the shaft of the strut. the nut is a 22mm but then i turn it, the shaft hust turns with it and it dosnt get any tighter. theres no way to hold the shaft in place and no way to no way to hold the top still while the socket is on it, no room for any other tool. i'm sure people install mounts to their struts all the time so theres something i am missing. can anyone help!
BMW_Stu is offline   Reply With Quote
Old 07-05-2010, 11:04 PM   #2
mrx733
My Ride: E46, W201
Send a message via AIM to mrx733
i had the same issue, i used an impact gun, while a friend was pushing the front end down.
mrx733 is offline   Reply With Quote
Old 07-05-2010, 11:10 PM   #3
blacksport325
My Ride: 98 M3, 318is, CBR600
Impact gun did it for me as well, I pushed down the upper shock mount and kind of compressed the spring then used an impact gun until it was tight...
blacksport325 is offline   Reply With Quote
Old 07-06-2010, 12:59 AM   #4
BMW_Stu
My Ride: HPF 330ci
how does that keep the shaft from spinning?
Old 07-06-2010, 08:45 AM   #5
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
It doesn't, its the speed that will get turn the nut faster than the shaft will rotate. I used a towel and some vice grips on the shaft.
...that's what she said!
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 07-06-2010, 12:49 PM   #6
BMW_Stu
My Ride: HPF 330ci
ah ha! cool thx.
Old 07-07-2010, 08:00 AM   #7
blablac
My Ride: 240sx
The first time around I took my coil-overs (prior to putting them on the car) to a mechanic and had them do it.
Since then I got one of these:
http://www.harborfreight.com/1-2-hal...nch-45252.html
blablac is offline   Reply With Quote
Old 07-07-2010, 08:06 AM   #8
Lemonsqr
My Ride: 2001 TiAg 330i
ah ha! cool thx.
a much better way is to use a socket that is the correct size to the nut, vise grips to turn the socket and an allen wrench to hold the rob from turning.
Lemonsqr is offline   Reply With Quote
Old 07-07-2010, 08:24 AM   #9
blablac
My Ride: 240sx
haven't done it on an E46 tho, So there is a spot to put in an allen wrench to keep the shaft from turning ?
Old 07-07-2010, 06:13 PM   #10
Minnoe07
My Ride: 2004 BMW 330Ci
What he did.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 07-07-2010, 11:30 PM   #11
bigjae1976
bigjae1976's Avatar
too much talk about nuts, shafts, and spinning
Old 07-08-2010, 02:23 AM   #12
BMW_Stu
My Ride: HPF 330ci
good suggestions guys! he ended up going to a shop, they used an airgun and it worked out!
Old 07-10-2010, 10:50 AM   #13
York
My Ride: 01 330Ci
I'm in the middle of my install right now and was wondering the same. I did use my impact wrench, but still wanted to make sure the nut is tightened down all the way. I'll hit it again once I have the car back on the ground. I like the idea of the vise-grip around the 22mm socket and then using the allen key. I mentioned this issue of access to the guys at work and a couple of them mentioned a socket wrench with a hole in the center? I've never seen a socket wrench like this. They said you could slide the allen key through the wrench and then the center of the 22mm socket. Anyone hear of such a wrench?
330Ci
York is offline   Reply With Quote
Old 07-10-2010, 11:39 AM   #14
blacksport325
Basically you can use a long box wrench so you get the torque needed and put the allen key through the middle, i've never seen a socket wrench that has a hole in the middle.
Old 07-10-2010, 01:45 PM   #15
York
My Ride: 01 330Ci
All done. Just used the 22mm deep socket with vise-grip + allen wrench. I was able to tighten both sides almost one full turn!
330Ci
