Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average.
Old 07-19-2010, 02:52 PM   #21
Iceman00
Banned User
My Ride: E90 6MT
I have a custom one I built as a prototype long before I knew there was a long to option available, it's not mandrel bent, and it is made to fit my Z. If I can dig it up, I'll send it your way for sure (it might be a bit dusty though) I'd recommend trying to run that filter and velocity stack on it, if possible. Interested still?
Old 07-19-2010, 02:53 PM   #22
Iceman00
Banned User
My Ride: E90 6MT
FYI, I'd also like to add that your numbers reflect those of Adam's when he had the shorty type Confronti Intake (220lb-ft)
Old 07-19-2010, 02:58 PM   #23
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
3.5 inch piping?
Yep. After discussing it with him, I decided I'd go ahead and do a cone. He said he saw differences in the A/F when he added the Conforti.
Old 07-19-2010, 03:22 PM   #24
Iceman00
Banned User
My Ride: E90 6MT
Ahh, You have the B30 with larger inlet piping. Sorry, it's just 3 inches.
Old 07-19-2010, 03:31 PM   #25
aggieE46
Keep it clean
aggieE46's Avatar
No worries. Thanks for the offer, though. Keep your fingers crossed on the exhaust.
Old 07-19-2010, 08:13 PM   #26
blablac
My Ride: 240sx
would an M3 airbox + piping fit in a regular 330i ?
blablac is offline   Reply With Quote
Old 07-19-2010, 09:09 PM   #27
aggieE46
Keep it clean
aggieE46's Avatar
Short answer is no.
Old 07-26-2010, 04:53 PM   #28
aggieE46
Keep it clean
aggieE46's Avatar
Here's my dyno.
File names are confusing, sorry. Blue is back in January. Conditions were 72 degrees, green was last weekend with 99 degrees.
You can see that I picked up a little bit everywhere. REALLY need to get some tuning done to knock out that big dip at 4200.
Only changes were the intake that I pictured above and an oil change. I also reset my throttle adaptations, but I do that every time I dyno.
Old 07-26-2010, 06:17 PM   #29
McSpeed
My Ride: 2005 ZHP TT Stg 1
didn't I hear that dip was from the DISA aka idle control valve flap action? If you haven't yet you could try unplugging it during a dyno run and see if things smooth out.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 07-26-2010, 07:27 PM   #30
aggieE46
Keep it clean
aggieE46's Avatar
Well, I've been told that it helps a lot with low end torque. I think it can be tuned out.
Old 07-26-2010, 08:24 PM   #31
tylerc
My Ride: 330ci
Do you mind telling us where you got the velocity stack? I really like that intake setup and think I will do that to my car. Right now I have no heat sheild and I am sure that's hurting power, I'm also not using a velocity stack and think that would help.
tylerc is offline   Reply With Quote
Old 07-26-2010, 08:27 PM   #32
aggieE46
Keep it clean
aggieE46's Avatar
It's a BLOX stack and filter. I think I got the stack and filter on Ebay. Bought the 3.5 to 4 inch elbow at siliconeintakes.com. I'll probably eventually buy a different filter (slightly shorter), but it was cheap and I just wanted to make sure it would work. AFE makes one that's slightly smaller, but it's fairly expensive.
Check out Vibrant for parts, too. They make a nice aluminum stack.
Old 07-26-2010, 10:02 PM   #33
tylerc
My Ride: 330ci
so why didn't you just get a 3.5" stack?
Old 07-26-2010, 10:02 PM   #34
Iceman00
Banned User
My Ride: E90 6MT
I seriously suggest a longer tube for your intake. Not because of the cold air, but because of air turbulence and resonance tuning. Check my sig.
Old 07-26-2010, 10:17 PM   #35
tylerc
My Ride: 330ci
I did have the thought of a 90 bend right before the maf... on my other car the intake is long and in the fender but it gets very dirty very quickly, which i don't like, however I suppose if there is that much of a difference...
Old 07-26-2010, 10:30 PM   #36
TxZHP04
My Ride: ESS TS2+ ZHP
And that would be asking for flow separation right in front of the MAF sensor leading to inaccurate readings.
Old 07-26-2010, 10:59 PM   #37
JohnBlaze
My Ride: Black Sunshine
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 07-27-2010, 12:34 AM   #38
Iceman00
Banned User
My Ride: E90 6MT
Originally Posted by vI6ious View Post
You're a fucking tool. Argue that.
Old 07-27-2010, 07:42 AM   #39
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Oh...it flattens things out alright, just not in a good way.
Disa=resonance flap
Iacv=idle air control valve
*sent from my iTool
Old 07-27-2010, 09:07 AM   #40
aggieE46
Keep it clean
aggieE46's Avatar
4 inch was really easy to find at the time, and fairly cheap.
Rate This Thread
