Wheels and Tires
Old 08-10-2010, 10:00 AM   #1
guzzy68
My Ride: 325i
M3 wheels on E46 sedan
Hey fellas, does anyone know if I would need spacers to fit wheels on my 325i that came off an m3. Thanks.......
Sent from my HERO200 using BimmerApp
guzzy68 is offline   Reply With Quote
Old 08-10-2010, 10:04 AM   #2
ufjason99
My Ride: 2008 335i
I have 18" staggered M3 wheels on mine and I have to put spacers in my rear springs to keep them from rubbing. If you ran 4 fronts I have heard you will not have a problem.
ufjason99 is offline   Reply With Quote
Old 08-10-2010, 10:10 AM   #3
LittleChrist12
My Ride: 2003 BMW 325xi
4 front M3 rims will fit on an E46 sedan. You won't be able to fit the rears.
2003 BMW 325xi
2010 BMW M3 Sedan
LittleChrist12 is offline   Reply With Quote
Old 08-10-2010, 10:12 AM   #4
guzzy68
My Ride: 325i
I'm planning to do the same, staggered 18, where can I pick up the spacers and how much $?
Old 08-10-2010, 11:09 AM   #5
ufjason99
My Ride: 2008 335i
You can get them at Pep Boys, AutoZone etc. They look like http://www.amazon.com/Superior-18-12.../dp/B00029K20C
Old 08-10-2010, 12:36 PM   #6
perfectmybmw
My Ride: has 4 tires
Bro, I am running 4 front's with 10mm spacers all around, even without spacers it should be fine.
M3 staggered Rears wont fit sedan, if you put spacers, you will never be able to fit it in the rears. because ET +27 is already too aggressive for sedan. There are few options I tried before moving to all fronts
1. Fender rolling - but rubbing as my car is lowered while aggressive cornering, even with a thicker sway
2. Stretched 235/35, but still had rubbing at some aggressive driving, if you have stiffer suspension, I dont think so there will be rubbing.
3. Chopped off the inner side of the wheel like 3-4 mm, shops can do for like 50-70bucks for both rears.
After going thru all these, I have decide, let me just run all fronts and have a peaceful solution.
perfectmybmw is offline   Reply With Quote
Old 08-10-2010, 02:45 PM   #7
guzzy68
My Ride: 325i
Thanks for the info, the one guy told me he's got them on with spacers and they are fine.
Old 08-10-2010, 04:57 PM   #8
DTMdan
My Ride: 2004 M3
Send a message via AIM to DTMdan
Bahahahahaha
DTMdan is offline   Reply With Quote
Old 08-10-2010, 05:03 PM   #9
guzzy68
My Ride: 325i
Thanks for the info.....
Old 08-10-2010, 05:03 PM   #10
SLVR JDM
My Ride: 4Runner
Rears won't fit. You need 4 fronts. Do spacers once you get 4 fronts if you want.
SLVR JDM is offline   Reply With Quote
Old 08-10-2010, 05:08 PM   #11
TuoRedrum330i
My Ride: has dents
i'm running 4 fronts with no spacers, no problems at all. spacers wouldn't hurt though, definitely would improve the look.
TuoRedrum330i is offline   Reply With Quote
Old 08-21-2010, 06:30 PM   #12
817bimmerfanatic
My Ride: is schön!
Send a message via ICQ to 817bimmerfanatic
I have staggered OEM M3 18" wheels and i rolled my rear fenders just to stop the rubbing. But i suggest putting 15mm spacers up from just for a flush look! but ya they'll def fit!
817bimmerfanatic is offline   Reply With Quote
Old 08-21-2010, 06:39 PM   #13
CCR323Ci
My Ride: '00 323Ci
225/40-18 tires all around
20mm spacers in front
no rear fender rolling
CCR323Ci is offline   Reply With Quote
Old 08-22-2010, 12:03 AM   #14
tuscan1205
My Ride: e46 325CI, w212 E550
your also a coupe...
'02 Orient Blue 325Ci
tuscan1205 is offline   Reply With Quote
Old 08-22-2010, 12:15 AM   #15
CCR323Ci
My Ride: '00 323Ci
same setup came off a sedan
