Thread Tools Search this Thread Rating: Thread Rating: 42 votes, 5.00 average. Display Modes
Old 08-25-2010, 05:53 PM   #1
xi_ter
My Ride: 2003 325xi
Replacement OEM Seat cover DIY for Seat bottom with pics
The OEM replacement cover comes complete with heated seat panel. The leatherette version cost about $260 at BavAuto. You will need to move 4 wire rods from the old cover.
Note for after 2014. I can't recommend doing this. I repeated this for my passenger side seat and the OEM leatherette seat cover was made of a thinner vinyl with less deep grain molded in. This vinyl puckers up where the zip-ties are. The pricing is much higher now. Best bet is to buy used seats that are comparable. That means you need to ask about heating and bolster options in the replacement seats.
The edge of the driver's seat bottom is a common wear point and also a look at the pulled out seat cover at the end of the job.
Steps:
1. Remove head rest and put aside.
2. Move seat to a high height position remove the 4 16 mm fasteners holding the seat. You will need to move the seat back and forth to gain access. I used this DIY to guide seat removal and switch disassembly:
http://forum.e46fanatics.com/showthread.php?t=657042 (I will use a few pics that I found esp helpful)
3. Move the seats forward, one last time before you disconnect the battery, then disconnect it. Remove 2 torque screws at the back of the seat. Remove 16 mm bolt for the seatbelt anchor.
4. Tilt the seat back, pry yellow slide with slot screwdriver and undo the main power to the seats.
5. Remove seat from car. Put a moving blanket over the door sill.
6. Cut zip tie holding the seat heater wire and undo the two harnesses. Pry a hold-down sleeve for the small one, and a wedge shaped lock to push the harness aside for the larger one.
Take a look at the new seat cover to get familiar with the wiring supplied and ignore this if you don't have heated seats.
7. There are 5 tabs of various sizes holding the control panel pry upward on all 5 at the same time (or use bits of cardboard to keep them from locking again)
Several tabs on the seat control panel:
1 under the curved section, 2 larger tabs as circled and 2 smaller tabs
You only need to pull the control panel away from the seat it is not necessary to disconnect.
8. Finally there is a base under the seat controls that is held to the seat by 4 torx screws. Remove these screws and pull this panel away.
9. Push away the U-shaped channel holding the seat cushion to the perimeter lip of the seat frame.
10. Once this is done all around the cushion, the back part will pull from under the seat back and the bottom cushion will pull out so you can do the hog ring removal at a bench.
Cut the hog rings and make sure all of these are thrown away - any traces of the metal can cut the new vinyl.
BMW requires you to recycle the wire rods. Push these through the sewn sleeve. You'll notice that there are no prepunched holes for the zip ties. I used my needle nosed pliers to poke a hole.
11. I positioned all my zipties into the foam cushion so I would be pulling outward.
Use needle nose pliers to cinch the wire rods into the cushion with the zipties. At the back there are 4 more holes in the cover that need to be ziptied. Work systematically so you don't cover up one of the zipties. Cut off excess as you work.
Near the back u-channel, there are 4 prepunched flaps that need to be ziptied to the cushion. I kept the hog ring as an anchor for 2. For the other 2 I pushed the ziptie through about an inch of foam to prevent pull through.
12. Pull the back flap under the seat back.
You then need to attach to the seat frame by folding the u-channel and reattaching the cover, all the way around the frame.
13. Reconnect electrical.
14. Screw base of panel back on and click tabs in place.
15. Put seat back. Reconnect main power and reattach belt anchor and 4 seat fasteners. Reconnect battery and test heated seats. Refasten seats.
The OEM replacement is worth the expense and effort. The vinyl is fresh and there is perfect color and grain match. Gives a factory look to the tear repair and also gives a new seat heating pad. Due to the battery disconnect , you get 3 ABS/ Brake lights that go away on driving. Note I did not do the seat back, only the bottom.
Last edited by xi_ter; 12-01-2015 at 03:02 PM. Reason: Unacceptable OEM seat covers post 2014.
Old 08-25-2010, 06:12 PM   #2
xi_ter
My Ride: 2003 325xi
RealOEM.com pages for seat covers - gives a rough idea of cost
See seats group
http://www.realoem.com/bmw/showparts...84&hg=52&fg=10
Old 08-25-2010, 07:37 PM   #3
iansanderson
My Ride: 2001 330CiC
nice write-up. You are correct that the OEM cover really is the best option. It fits, looks correct and should last a long time. I will need to replace mine in the near future as some stitching is coming apart. Hopefully the extended leg-zone won't be too much of a problem.
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
iansanderson is offline   Reply With Quote
Old 08-25-2010, 08:29 PM   #4
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
$800 for each replacement cover... damn! That is almost $1600 per seat.
wow!
3 SEAT COVER LEATHER LIGHTGELB 2 09/2001 52108267614 $739.35
4 Cover backrest, leather BROMBEER 2 52107048432 $739.35
delmarco is offline   Reply With Quote
Old 08-25-2010, 08:54 PM   #5
xi_ter
My Ride: 2003 325xi
wow!
BMW Replacement Parts is not too kind to leather owners, even shift boots are nearly $100. There are a few sellers at eBay.de that pull off the seat covers as described in this DIY and sell all the leather covers for around $1000.
http://translate.google.com/translat...6r&sl=de&tl=en
My German is horrible so I use Google translate. Some sellers ship world wide.
Old 08-25-2010, 09:18 PM   #6
delmarco
http://www.leatherseats.com/3Series_leather_kit.asp
Old 08-25-2010, 09:57 PM   #7
John in VA
My Ride: 328i/325xi
From Tischer BMW:
52108267614 List Price Core Price Your Price
SEAT COVER $603.00 $0.00 $482.40
52107048432 List Price Core Price Your Price
COVER-B.REST $658.00 $0.00 $526.40
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
Old 08-25-2010, 09:58 PM   #8
delmarco
Originally Posted by John in VA View Post
From Tischer BMW:
thanks.
Old 09-07-2010, 06:01 PM   #9
xi_ter
My Ride: 2003 325xi
After driving with the new covers a few days, it's pretty amazing how much the heated seat grid had degraded over time. The new bottom cushion now heats up very quickly and is more uniformly warm than the upper part that was not replaced.
There are good reasons that BMW incorporates the cover and the heating grid... if the vinyl is cracking, the heating grid is probably getting bad as well.
Old 09-20-2010, 09:15 PM   #10
kap09
My Ride: 2014 S4 DSG
sorry to bump this old thread, but what description should i look for on realoem? i don't see leatherette as an option...
2014 S4 | DSG | Ibis White | Sport Diff | 19'' Peelers | MMI | Carbon Atlas | B&O | Side Assist | SC Badged
GIAC Stage 2 v2 | GIAC DSG | Roc-Euro Intake | Magnaflow Res'd X-Pipe | OE Sport | Alu Kruez | H&R Sways | ECS Flush Kit | 40% Pinnacle Tint | Hoen Endurance | VCDS Mods | Escort 8500 x50
Past Rides
2013 S4 6MT//2010 A4 Quattro//2000 BMW 323i//1991 Integra//1990 Jetta//1993 Civic
kap09 is offline   Reply With Quote
Old 09-20-2010, 09:38 PM   #11
carsos
My Ride: '03 325Ci
damnit. this makes me want to add another thing to my diy queue.
carsos is offline   Reply With Quote
Old 09-20-2010, 09:44 PM   #12
kap09
right? doing this and replacing my busted seat cover is at the top of my list as soon as i get the right part number and can place the order.
Past Rides
Old 09-21-2010, 10:18 PM   #13
carsos
My Ride: '03 325Ci
if it's really just the stitching that's the problem, you can fix that easy. curved upholstery needles and some heavy duty thread, a couple bucks at a craft/fabric store.
Old 09-23-2010, 05:05 AM   #14
xi_ter
My Ride: 2003 325xi
On realoem.com the leatherette is referred to as vinyl.
Old 12-17-2010, 07:27 PM   #15
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Xi ter,
Missed checking up on this old thread...so looks like I'll be getting to this...
Do you happen to have an opinion or recollection about whether the seat covers for the bottoms in the front are symmetrical? I'm planning on just stealing the pass seat bottom with working heating grid to my seat.
Doug
Facebook.com/DMAXstandup
Mangofy your E46!
Old 01-07-2011, 05:36 PM   #16
xi_ter
My Ride: 2003 325xi
^^ The seat bottoms are symmetrical. Your plan will work. ...Sorry last couple of weeks were busy.
Old 01-11-2011, 03:08 PM   #17
dsblk93gt
My Ride: '01 325i
I need to do this to my car, I have been looking for a whole seat with not much luck since it is a sport seat and tan with no power.
'01 325i Sedan - Alpine White, Sport Package, 5spd - daily driver 144k miles
'93 Mustang LX 5.0 - Reef Blue, 5spd, Vortech Si-Trim and alot more....
dsblk93gt is offline   Reply With Quote
Old 01-16-2011, 08:08 PM   #18
xi_ter
My Ride: 2003 325xi
Power/ no power will have the same seat bottoms and backs. Will expand the possible sources.
Old 04-07-2011, 12:35 PM   #19
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Thanks for the thread. Going to do this soon.
Old 10-26-2011, 08:41 PM   #20
beberle
My Ride: 2009 328 wagon
It's only been a year, but the prices for these covers appears to be skyrocketing. ECS tuning has the same bottom cover for $359 right now and BMW of South Atlanta at $415. Supply shrinking & demand growing??
note: just bought the vinyl bottom at Tischer for $332. Ouch!
beberle is offline   Reply With Quote
