Thread Tools Search this Thread Rating: Thread Rating: 55 votes, 5.00 average. Display Modes
Old 01-18-2010, 03:03 PM   #41
kyle808
My Ride: 00 328CI
Originally Posted by n2Bimmer View Post
Great DIY, thank you. I really need to do this soon, I have a few questions, What exactly do we have to replace for the Vanos bolt?? Do i really have to remove the fan (auto)?, Can i rent the tool at pepboys?. Thank you. Also i assume we need to drain the oil first, no one mentioned it.
You will need a 17mm or maybe 19mm wrench for the Vanos bolt. I don't remember exactly.
I don't see how you can do it without taking off the fan. You really need the space.
No need to drain the oil.
not sure about rental at pep boys.
"I'm gonna die! Jesus, Allah, Buddha - I love you all!
-Homer Simpson
kyle808 is offline   Reply With Quote
Old 01-18-2010, 04:27 PM   #42
n2Bimmer
My Ride: Loves Corners
Thank you, Also i will need a new Vanos crush washer?.
Old 01-18-2010, 04:46 PM   #43
genuity
My Ride: 2001 330iS
I would replace it. I did...I went even as far as replacing that vanos hex bolt.
genuity is offline   Reply With Quote
Old 01-18-2010, 05:12 PM   #44
n2Bimmer
Thank you guys
Old 01-19-2010, 08:59 AM   #45
bmwFreakazoid
My Ride: 03 325 I
I recently got my filter housing gasket changed for $396 got it down from $980. I will have to check to see if the engine was cleaned thouroughly I like the pristine factory look in the pics above.
bmwFreakazoid is offline   Reply With Quote
Old 01-19-2010, 12:18 PM   #46
NoVaDreier
My Ride: 2001 325i
Who did the job in D.C. for $396?
NoVaDreier is offline   Reply With Quote
Old 01-19-2010, 06:22 PM   #47
n2Bimmer
Got my oil, fitler, washers and gaskets from the dealers today. I need only two crusher washers right?
Old 01-23-2010, 09:02 AM   #48
E-rock
My Ride: '01 330xi
Anybody have a PN for the washers? [edit] Should be 32411093596, right?
E-rock is offline   Reply With Quote
Old 01-24-2010, 07:33 AM   #49
NoVaDreier
My Ride: 2001 325i
Corrrect. That's the right part number and the washer is also required for one of the banjo bolts (#6) in the power steering lubrication system.
Old 04-12-2010, 09:44 AM   #50
rayv99
My Ride: 2002 330i
VERY Rough cold idle
Over the weekend I replaced the oil filter housing gasket, vanos tube,both belts, fan clutch, spark plugs and valve cover gasket - whew! Fired right up - no leaks, however after starting the car started to idle very badly - RPM's up and down - almost stalling. Under road conditions the car runs fine, at a stop sign the engine idle is rough. After the car warms up the idle smooths. I pulled the plugs - no signs of fouling, with the engine running (and warmed up - and ) I dissconnected each of the "coil connectors" to the plugs one at a time to see if one of them wasn't firing. Effect was same on each plug - I minor decrease in idle speed - my conlclusion - ignitition system is okay. I suspect I dissconnected "something" related to cold start and forgot to reconnect it - ANY IDEAS OUT THERE?
rayv99 is offline   Reply With Quote
Old 04-12-2010, 09:53 AM   #51
Focal E46
My Ride: is a DIYer
^ I just did mine this weekend too!
Sounds like your VANOS is shitting. Check/test here:
http://forum.e46fanatics.com/showthr...ght=vanos+idle
Focal E46 is offline   Reply With Quote
Old 04-12-2010, 06:34 PM   #52
rayv99
My Ride: 2002 330i
doh
I just don't want to believe it - but I think you're right - I'll do the test tomorrow but I oredered the repair kit (beisan systems) today. I was trying to understand WHY it started happening after all the repairs I made. The only thing I can think of is that there is some relationship to the fact that I changed the Vanos line (it was leaking)?
Another opinion needed - since I JUST changed the valve cover gasket over the weekend - I'm assuming that I don't need to REPLACE it when I do the Vanos repair since the rubber is nice and soft right now. Thoughts?
Old 04-13-2010, 06:42 AM   #53
Focal E46
My Ride: is a DIYer
Nah, you can reuse the valve cover gasket. I did mine last year and didn't do the nut seals and now one of them are leaking so I'll be back in mine this weekend, lol.
Old 04-13-2010, 02:23 PM   #54
rayv99
My Ride: 2002 330i
Okay - Thanks, I'll tackle the vanos this weekend!
Old 08-22-2010, 07:02 PM   #55
X-vert
My Ride: 01 330i & 04 Tahoe
Service Engine Soon Light????
Excellent DIY! Everything went really well. The hardest thing to do was to make lunch during the job!
No leaks and runs smooth but the Service Engine Light popped on. Any ideas before I take her to a dealer??
X-vert is offline   Reply With Quote
Old 08-28-2010, 09:10 PM   #56
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
How much oil came out after you removed the oil filter housing?
phamine is offline   Reply With Quote
Old 08-29-2010, 11:12 PM   #57
spencers
My Ride: 2006 330i
I'd like to know too.
spencers is offline   Reply With Quote
Old 08-30-2010, 11:41 PM   #58
island330i
My Ride: 2002 330i, 1990 M3
Just finished mine last week and only a little oil came out, nothing to worry about.
island330i is offline   Reply With Quote
Old 08-31-2010, 02:14 AM   #59
X-vert
Not much after a while. I "reset" the service engine light (key in on position and gas pedal).
Cleaned and degreased.
I still have a tiny leak.
Changed all the applicable gaskets and near by hoses. What else could it be? It's not ATF/Power steering for sure.
Old 08-31-2010, 04:05 PM   #60
kib
My Ride: bmw 04 e46 330 vert
a bit off subject but have any of you changed the small filter in the vanos and were is it .
thanks keith
kib is offline   Reply With Quote
