Sponsored by BimmerWorld
Old 08-28-2009, 03:45 PM   #21
n2Bimmer
My Ride: Loves Corners
the arms may be good and the bushings bad. Dont do both at 20k, find out whats bad.
Old 08-28-2009, 11:47 PM   #22
gunbeem
My Ride: E46 M3 SMG
I did confirm that the control arm failed. Even the dealership was shocked that they went bad with low miles... They showed me the parts after being removed. I got my car back... it feels like a new car...
Thank you
gunbeem is offline   Reply With Quote
Old 09-03-2010, 10:24 AM   #23
TerraPhantm
My Ride: M3 & ZHP
Old thread, but I just want to post this for others to know: The ball joint on my right front ZHP control arm finally developed excessive play at 109k miles. The left one is still within the allowance of PA inspections, but I'm sure that can use replacing too. I've ordered a new set of arms and bushings from Tischer, and plan to install them sometime next week
I've never actually seen anyone post the mileage at which their ZHP arms wore out (if they ever did) so I thought I'd post this.
Old 09-03-2010, 10:31 AM   #24
alwaysbored786
My Ride: M3
good to know, i also purchased the same kit and installed it about 3 weeks ago, feels so much better now!
*NO F-BOMBS IN SIGS*
How to refinish rims
2004 Noble M12 GTO 3R
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
1998 Honda Civic - Sister Totaled
2002 330CI - SOLD
2006 CBR 600RR - SOLD
1995 M3 Coupe - SOLD
1988 325E - SOLD
1996 Cherokee - SOLD
alwaysbored786 is offline   Reply With Quote
Old 09-12-2010, 08:19 PM   #25
krispl
My Ride: 2002 BMW 525
I just replaced worn out stock lower control arm bushings on my girlfriends 325i. She was experiencing clunking noise when going over bumps and light steering wheel shaking at around 40 mph. We got the Meyle HD bushings for replacement. I finished it yesterday and clunking noise is obviously gone but now shaking at higher speeds, e.g. above 50 mph is crazy! It actually shakes more then before replacing busted bushings! From reading these comments I'm leaning towards statement that these Meyle bushings must be too hard or sth. What do you guys think?
krispl is offline   Reply With Quote
Old 09-14-2010, 11:52 AM   #26
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Originally Posted by gunbeem View Post
After researching, I am still confused. I have a 2003 330i ZHP and the control arms need to be replaced.
Would the Meyle HD control arm fit?
Should I just order the OEM ZHP control arms instead?
Thank you in advance!
MEYLE HD arms will fit. We have never had any issues with MEYLE any components.
Our kits have been specifically assembled by ECS to include the 1st stage of common wear items on your E46 BMW.
Not only does this ECS E46 suspension rebuild kit replace those common wear items we upgrade your units with Meyle upgraded all metal ball joints & Meyle upgraded suspension bushings.
Change the way your E46 feels & even upgrade further than with parts from your BMW dealer. These control arms feature replaceable ball joints.
This ECS E46 suspension rebuild kit includes the following:
* Meyle all metal ball joint control arms (left & right)
* Meyle upgraded control arm bushings
* Meyle related hardware
Best,
Joe
Old 09-28-2010, 02:46 PM   #27
My Ride: Lexus
Joe@ecstuning, how do ZHP control arms compare to the Meyle HD arms? Specifically the balljoints. Are they the same size/material/stiffness? Please give us your honest opinion. If cost were not an object, which would you put on your own personal car? Thanks.
