Adding sub - line-level outputs? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BAVSOUND
Old 09-01-2010, 01:42 PM   #1
carmand
My Ride: 2005 M3 Competition
I'm installing an amp w. external sub this weekend. I've done this before several times, most recently on my '00 Audi S4. I've ALWAYS used line-level outputs (low level) vs. speaker-level (high level) outputs. My sub amp accepts either (low or high), so its not a show-stopper.
However, tapping into the low level outputs (signal coming from the headunit into the stock amp) as a source, bypasses the existing stock amp and thus provides a cleaner source for the sub amp.
I've looked high and low, and can only find a DIY for tapping into speaker-level outputs - not low level outputs.
Anyone out there know where I can find a wiring diagram or pics?
Thanks!
2005 M3 Competition
carmand is offline   Reply With Quote
Old 09-03-2010, 09:56 PM   #2
radarcontact
My Ride: 2006 330CiC/ZHP
There are lots of wiring diagrams on the forum. I'll see if I can find you a link over the next few days.
I have been asking similar questions about the line voltages. The universal answer seems to be "use the HU leads into an LOC", unless your amp takes differential balanced inputs as even the HU leads (prior to the amp) can put out as much as 11 volts! Few amps do...I thought mine did till a few days ago; they don't. So I'm getting an LOC!
radarcontact is offline   Reply With Quote
Old 09-03-2010, 10:04 PM   #3
radarcontact
Look for a thread I started called "WANTED: Technical...."
I updated my original post with info I found that includes pin outs.
Hope that helps!
(I'd just send you the link but can't figure out how through BimmerApp, which I'm using right now)
Old 09-06-2010, 12:04 AM   #4
Don-Faheezy
My Ride: 2001 330i
http://forum.e46fanatics.com/showpos...6&postcount=12
this what you need? its pin 8 16 and 29 37
quick question... how are you tapping into the wires? im going to be installing a sub soon too. u think t taps will be ok?
Don-Faheezy is offline   Reply With Quote
Old 09-06-2010, 12:12 AM   #5
howie
My Ride: CLK55 AMG, E90 335i
Send a message via AIM to howie Send a message via Yahoo to howie
Does ur sub amp not have a switch for high/full/low???
howie is offline   Reply With Quote
Old 09-06-2010, 12:58 AM   #6
radarcontact
If ur gonna tap, try to find some "posi-taps"... They are awesome. NAPA maybe?
Old 09-06-2010, 07:42 AM   #7
jammykam
My Ride: 2003 330Ci Step Vert
I've used t-taps and they were fine (although I did later solder them in, but only cos I was diagnosing another problem and ruling things out). The the sub install link in my sig.
///Kam
jammykam is offline   Reply With Quote
Old 09-08-2010, 08:18 PM   #8
radarcontact
I'm just gonna cut 6" on both sides of the amp. If I ever need to "undo" my install, I'll use bullet connectors to put it all back.
