Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average.
Old 09-09-2010, 05:02 PM   #141
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Smart move, dont play with it untill the dyno. Even if it stays around the same hp, the weight alone makes this worth it, I bet it weighs a good amount less than the magnaflow.
Edit: Speaking of weight, did you remove the rear seats? I did about a week ago along with a mini cooper battery and the car feels great. I'm going to get a custom mat to cover the seat. I'm getting it made by the same guy who did this
http://www.m3forum.net/m3forum/showt...ar+seat+delete
It's going to look similar except will say "bmw performance" and cover the entire bench part as well. Let me know what you think.
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 09-09-2010, 05:11 PM   #142
xixixi
Banned User
My Ride: 01 330x-xi
I'm gonna go out on a limb and say, you will have gains with that set up. The exhaust looks good.
Old 09-09-2010, 06:36 PM   #143
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Seats stay in. Baby needs a place to strap in!
On another note, I like the way it sounds at idle.
Old 09-09-2010, 06:54 PM   #144
Iceman00
Banned User
My Ride: E90 6MT
I told you I was worried about the Y pipe too. Should I throw in for a new one if this one doesn't work out?
Old 09-09-2010, 09:43 PM   #145
aggieE46
Keep it clean
aggieE46's Avatar
If this one doesn't work out, I'll gladly take donations for a better one!
Old 09-09-2010, 10:22 PM   #146
xixixi
Banned User
My Ride: 01 330x-xi
I was at my shop the other day.. I saw an OEM Y-pipe. I asked what it was from and my bro said it was from a later model e46. I'd assume bmw didn't switch for nothing. Either way before you dyno, I want your exhaust just pm me. I was going to make the exhaust you fab'd based on the oem y pipe. IE distance from the headers to the connection. I'm curious to see the distance from the headers to the Y pipe and how you chose that distance!!!
Old 09-10-2010, 07:07 AM   #147
aggieE46
Keep it clean
aggieE46's Avatar
BMW switched from a Y in the 323 and 328 to a dual in the 325 and 330. I don't understand your statement.
Old 09-10-2010, 07:55 AM   #148
McSpeed
My Ride: 2005 ZHP TT Stg 1
?? Brady, give him your exhaust!
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 09-10-2010, 09:36 AM   #149
xixixi
Banned User
My Ride: 01 330x-xi
I'm asking how you decided where to place the y pipe. what distance from the headers? Or was it just kinda a guess?
Old 09-10-2010, 10:00 AM   #150
aggieE46
Keep it clean
aggieE46's Avatar
The Y-pipe was already welded on when I got it. It's just installed as it was received.
I'm getting a little more used to it. It seemed like it droned a little more last night, but some of it has cleared up (after about 50 miles on it this morning).
Old 09-10-2010, 03:23 PM   #151
aggieE46
Keep it clean
aggieE46's Avatar
This may be a silly question, but I'll ask anyway. My headers are Swain coated, so they're getting some good insulation. Right when it hits the Y-pipe (which is going from around 2 inch to 2.5 at the merge and then opening up to 3) I would imagine the exhaust is starting to cool. I would think that would be a bad place for that to lose velocity. I have a roll of exhaust wrap. Does anyone think I would benefit from wrapping the y-section and back into the 3-inch by a foot or so?
Old 09-10-2010, 08:07 PM   #152
xixixi
Banned User
My Ride: 01 330x-xi
why not move the y pipe closer? To the headers?
Old 09-10-2010, 08:28 PM   #153
aggieE46
Keep it clean
aggieE46's Avatar
I don't think it can get much closer. If I get another Y, I can possibly move it up a couple inches.
Old 09-10-2010, 09:25 PM   #154
Iceman00
Banned User
My Ride: E90 6MT
I don't think it will help. You just don't want a massive pressure drop going from 2"-3" instantly. How does the butt dyno feel.
Old 09-10-2010, 09:52 PM   #155
aggieE46
Keep it clean
aggieE46's Avatar
Honestly, the butt dyno says I lost power. But, it might be my ears playing tricks on me. It used to sound really raw up top. It sounds more tame, now.
Old 09-10-2010, 10:52 PM   #156
TiAgTouring
My Ride: has a D-Pillar
Video or sound clip?
TiAgTouring is offline   Reply With Quote
Old 09-11-2010, 08:09 AM   #157
aggieE46
Keep it clean
aggieE46's Avatar
I'll get one on the dyno next week.
Old 09-11-2010, 11:27 AM   #158
mvrk10256
My Ride: E30 325i
i wish i had the cash to do this kind of thing to an e46. I cant wait to get an e30 so i can actually build it up and do so comfortably. cant wait to see the dyno sheet.
Old 09-11-2010, 03:22 PM   #159
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
hmm i just had a thought. How would you lose power when you bored out the TB? Since you didn't gain any HP, that means that there is a bottle neck somewhere in the manifold or the head. Which means that the same amount of air is going into the motor, therefore making the same amount of power. How is it possible to lose power? Am I right? I remember you saying the humidity was almost double your last run... that's probably what caused the drop in power, not really the tb.
...or did we all know this and i just realize it?
SL Blak Soldier is offline   Reply With Quote
Old 09-12-2010, 09:13 PM   #160
Iceman00
Banned User
My Ride: E90 6MT
To be honest, the major benefit you should be looking for is more mid range power than peak. Though even so, I don't expect a large change in peak power.
Rate This Thread
