Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
Rating:
#221 | |
Next thing, Iceman00, your statement is :The Single 3" pipe has just a bit more surface area than dual 2" pipes, and when the merger is designed correctly, there should be no loss in power. Period. Could you than explain me why header designers for our cars, when they merge 3 pipes into 1, don't use your logic, and the surface area of the pipe after merge =/= 3 x surface area of pipe before merge? Well, I can tell you why. That's because exhuast is not as simple as 2 + 2. And it can't be well designed just with a use of intuition. An example? Sure, let’s take headers for euro s50b32. Pipes before merge are 1,8” and the pipe after is 2,4”. That gives us a diameter ratio of 1,33 (note we merge 3 into one, NOT 2) and surface area ratio of 0,6 (far from 1:1). Do you think they made mistake? If so, give them a call, they should know … at the end, we all want our bimmers to be as good as possible, right? Now something about placing Y joint. For me, there is only one reason why the Y joint is so far in both HKS and 323 designs. And it’s simple. It’s because they are designed to pass emission tests, which mean a use of two catalyctic converters (again, as Hoveringuy demonstrated, one is not enough). If an Y joint close to the headers is bad, why than hoveringuy’s and partially bimmerworld’s systems seem to work? And for the end, as it goes about bimmerworld’s graph. I agree, you can’t exactly say, when the dyno operator pushed the pedal to the metal, but I’m pretty sure, that if their design was beneficial in the whole rpm range, they wouldn’t forget to tell us about it. |
#222 |
Sorry about my cheapo y-pipe. I didn't put much effort into that part since I live in California and I'm stuck with using stock headers so no matter what I get pretty crappy exhaust flow. Also I remember looking at that Burns Stainless y-pipe and then crying when I saw the price...
...so I just tried copying them. |
#223 | ||
single 0.065" wall, 3" diameter is 2.04 pounds per foot Roughly around 24% lighter per foot for roughly the same cross sectional area. Brady's exhaust is significantly lighter than a 70 pound ZHP exhaust. Quote:
single 3": 2*pi*(radius)=2*3.14*1.5in=9.42in dual 2": 2*2*pi*(radius)=2*2*3.14*1in=12.57in |
#224 |
3" -> 1,5" * 1,5" x 3,14 = 7,065
2 x 2" -> 1" x 1" x 3,14 x 2 = 6,28 |
#225 |
oh, he means cross sectional area, lol. You can't really say surface area with out a surface. I thought was was talking about actual surface area of the pipe, because that kinda came into my equation when trying to figure out a y-pipe design.
#226 |
Banned User
I don't think the hks system uses cats i think those are resonators. The 323 has the cats in the stock headers. I'm not saying the design of the oem y pipe on a 323 is the best design. I do think the placement of the y pipe in the exhaust system was put there for a reason. The y pipe location has nothing to do with emissions. Just my .02 cents
#227 |
This is what we have in europe: (323 exhaust)
European versions don't have cat'ed headers and they also run Y pipe like US. What is the relation between y pipe and emissions -> if you place your Y farther, you can run cats parallel, which is the only way to make them work efficiently. They need a proper temperature (HOT!). Now if you place Y pipe closer to headers, you have to run one cat behind the other. Second one won't work as good as it could. |
#228 |
Banned User
interesting... I think we all agree the y pipe needs to be moved back
#229 | |
#230 |
Banned
#231 | |
My reasoning being that the proper positioning of the first set of collectors and the second set of collectors is probably going to be determined based on some physics that optimizes the exhaust to suit the needs of the engine. Measurements like "around the driveshaft" are probably not going to work when the only gains at this point are going to come from very careful engineering. It'd probably be more worthwhile to figure things out before chopping up that exhaust which was so laboriously fitted and welded together. |
#232 |
Are you arguing OEM header mergers? You are aware that even factory BMW exhaust don't use a merger after the headers of ANY sort, at least not the E46 M54. In fact, only the S54 uses a merger (H pipe).
Secondly, you can't use larger diameter pipes right off the exhaust ports...well you can, but I wouldn't recommend it. Smaller primaries and collectors allow for more exhaust velocity, using a lager diameter tube would surely compromise power some place. Ask Supersprint, which is why the developed a Stepped header design (smaller diameter pipes off the exhaust ports, that gradually 'step' into larger primaries, then a collector) to produce a broader torque curve without sacrificing to much top end power, like smaller primary pipes would. Third: piping after the collector doesn’t matter. http://my350z.com/forum/7412469-post2.html For any system "Y-back" you can't have too large of tubing. There is no compromise of TQ by going larger and larger. With one exception, the only thing a Y-back can do is "potentially" reduce HP if there is excessive back pressure. The one exception would be a diffuser or megaphone which can reduce pressure drop below that of an open pipe. TQ is determined by the diameter of tubing upstream of the end of the Y-pipe. So in other words, TQ is determined by the Y-pipe primary diameters and a few inches past the merge collector. Anyhow, Active Auto's 3" race exhaust has the cross over in what would be after the factory cats ![]() The S52B32 is closely related to the M54B30, sharing crank and stroke. |
#233 |
So you've seen an M54 with a dual to single? According to realoem, even the earliest M54 runs dual pipes from the manifold back.
#234 |
Banned User
? what ? my 01 330 doesn't have a y pipe. it's dual all the way back oem. The 323's have a y pipe, I'm not sure about the 325's. Iceman, I don't really like that graph. That m3 has top side mods to be rapping out to 7500. I'd rather see their exhaust on a bone stock car/bolt on car. Either way good info here.
#235 | |
I wouldn't rev an S52 up there for long. |
#236 |
#237 |
Banned User
#238 |
What I'd like to change if it was mine
is the two 90 degree bends and they are real close to each other. 90's slow the flow. the oem exhaust shows 45's.but on the other hand the increase in size may make up for it? didnt you increase the throttle body as well, or did you dyno with the other exhaust sorry i missed it |
#239 |
Piping after the collector doesn't matter.
#240 |
Keep it clean
Keep it coming.
| Rate This Thread | |
