The Showroom
Old 07-17-2010, 10:53 PM   #41
djnekkon
My Ride: MB3ci & z33 HR
Almost a year with this set up, no problem during winter time, no aligment or drivetrain components so far..
25mm rear
Switched from 12mm to 15mm front (Stav 15mm)
tires: 225 all around on OEM 68's
Old 09-21-2010, 03:49 PM   #42
Zach McAfee
My Ride: 2001 330ci
Keepin' it alive!
I just bought some 10 or 12 mm spacers from a friend at work. I'll post pics this week.
2001 BMW 330ci
1987 325is Spec E30
1988 325i 'vert
www.sim-seats.com
Zach McAfee is offline   Reply With Quote
Old 09-21-2010, 04:56 PM   #43
zk369
My Ride: '00 328ci
so I cant think of the tire sizes right now but if i wanted to have my 68's nearly-flush what size spacers do i need to run?
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.” - Jeremy Clarkson
zk369 is offline   Reply With Quote
Old 09-21-2010, 07:20 PM   #44
DTMdan
My Ride: 2004 M3
Send a message via AIM to DTMdan
Depends on your tire sizes and drop...
DTMdan is offline   Reply With Quote
Old 09-21-2010, 08:08 PM   #45
///M3Turk
My Ride: M6 ,X5, R6, M5, M3
Send a message via AIM to ///M3Turk Send a message via MSN to ///M3Turk
25mm rear
Not anyore
Firat
///M3Turk is offline   Reply With Quote
Old 09-22-2010, 12:14 PM   #46
BMW_Matt
My Ride: 135
Originally Posted by Zach McAfee View Post
Keepin' it alive!
Hope they aren't 10's.
BMW_Matt is offline   Reply With Quote
Old 09-22-2010, 05:00 PM   #47
Zach McAfee
My Ride: 2001 330ci
I just picked them up - I got two 15mm spacers, so I'll put them in the rear. I also got the BavAuto camber kit for the rear. That will help pull the top of the wheel back out where it should be.
2001 BMW 330ci
1987 325is Spec E30
1988 325i 'vert
www.sim-seats.com
Old 09-23-2010, 08:55 AM   #48
Zach McAfee
My Ride: 2001 330ci
Here are some crappy cell phone pics on the way into work.
15mm rear spacers. I'll need something up front eventually, but if I don't sell my spare rear tires I might run a square 8.5" setup. So, I'll wait till then and see what size spacers I need up front.
Hopefully my camber correction kit will bring out the rear a bit more.
ID:	376769   Click image for larger version
ID:	376770   Click image for larger version
2001 BMW 330ci
1987 325is Spec E30
1988 325i 'vert
www.sim-seats.com
Old 09-23-2010, 09:28 AM   #49
DTMdan
My Ride: 2004 M3
Old 09-23-2010, 10:39 AM   #50
BMW_Matt
My Ride: 135
Originally Posted by DTMdan View Post
A note about 10mm spacers: Any 10mm spacer is considered a custom fitment. The stock hubcentric lip on BMWs can stick out by as much as 11mm. This leaves a gap between the spacer and the hub which seriously compromises safety. We recommend using a larger spacer (12mm and larger do not have this issue) or check that the lip sticks out less than 10mm.
It's not that big of a deal, but I'd go with 12's just for that extra comfort.
Old 09-23-2010, 12:20 PM   #51
DTMdan
My Ride: 2004 M3
Ah okay... well I had H&R 10mm & 20mm spacers before and I know that there is less lip on the 10mm spacer but it never gave me any problems.
Old 09-23-2010, 01:24 PM   #52
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
15mm f 12mm r
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 09-23-2010, 01:38 PM   #53
BMW_Matt
My Ride: 135
Originally Posted by Activ3 View Post
15mm f 12mm r
15mm front? Or did you reverse that?
Old 09-23-2010, 01:46 PM   #54
Gheybe
Gheybe's Avatar
My Ride: F80 M3
Only picture I have on my phone right now. I'll go outside and take a few shots after work.
15mm rear, and I have 12 in the front.
This is a shot of the rear, on Eibach Sportline suspension.
(yes, I know the idiots put the wheel weights on the outside. Trust me. I know it's there.)
Gheybe is offline   Reply With Quote
Old 09-23-2010, 02:49 PM   #55
Activ3
It's 15mm front. I have that spacer setup for my regular wheels, and just left them on when I ran the m68s temporarily. I need the 15mm to clear the bbk, and I run the 12mm just to look a little better lol
Old 09-23-2010, 02:51 PM   #56
BMW_Matt
My Ride: 135
What size tires are in the front and back?
Old 09-23-2010, 02:52 PM   #57
BMW_Matt
My Ride: 135
Pics of the front?
Old 09-23-2010, 03:24 PM   #58
Activ3
Originally Posted by bmw_matt View Post
what size tires are in the front and back?
225/245
Old 09-23-2010, 03:32 PM   #59
BMW_Matt
My Ride: 135
Whats your camber in the front?
Old 09-24-2010, 12:33 AM   #60
KingOfThaSouth
My Ride: E46 330Ci
Send a message via ICQ to KingOfThaSouth
front 10mm, rear 10mm
M54B30...What else
///GERMANY
KingOfThaSouth is offline   Reply With Quote
