Old 10-01-2010, 11:59 PM   #1
lab rat
My Ride: '02 330iT
ESS TS1 - first impressions
I got my car back from my mechanic today who installed the Stage 1 TS kit on my 325. It's not really broken in yet so I will probably go for longer drive tomorrow.
So here are first impressions:
The good:
- the kit looks so stealth (black paint version)
- most of the pieces of the kit are incredibly well engineered
- it's very quiet
- it pulls really strong from 4K
The bad:
- there is no custom intake tube for the 325 - just adapter rings
- I expected more power in low and mid range (I'll get some diagnostic software and gauges to make sure I don't have a boost leak)
Overall I'm really happy, the car is pretty fast. I'll post update when I break in the SC and really get on it.
Old 10-02-2010, 12:07 AM   #2
Au2bahn
My Ride: 05 330i ZHP,09 HCHII
Cant wait to see posting after break in. Looking into getting TS2 soon. I want to get your feedback first hand.
Au2bahn is offline   Reply With Quote
Old 10-02-2010, 02:30 PM   #3
4dr05zhp6mt
My Ride: e66 Monaco Blue
Send a message via AIM to 4dr05zhp6mt
Congrats
2008 Monaco Blue e66
SOLD05 330i 4dr zhp 6MT Jet Black | AA C38-81 S/C, 80mm pulley, water/meth injection | AA headers | Vac Motorsport 248/256 FI cams |
https://www.4shared.com/account/home...edir=105531274 (link to INPA v5, GTv44, EDIABAS, EasyDIS
4dr05zhp6mt is offline   Reply With Quote
Old 10-02-2010, 09:52 PM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
Not exactly sure I understand this statement or why you feel it to be a negative.
Old 10-02-2010, 11:59 PM   #5
lab rat
My Ride: '02 330iT
Heh, sorry about my english, I didn't speak it for a month while I was in Europe
The tube is for 330 (bigger TB) and ESS provides adapter rings to make the diameter smaller. This is surprisingly low tech compared to the rest of the kit and could lead to air leaks. I think it would be pretty easy to design smaller tube.
Anyway, here is the update after breaking the SC in:
WOOOOHOOOOOO! Holy crap, the car is fast
I think the lack of the low end torque is just an illusion. I didn't drive my car for a month so I guess I forgot how gutless it was. Also I got spoiled by the torque of Ford 2 liter TDCi diesel while I was in Europe (it only pulled from 2K to 3K and there was some turbo lag but the power was impressive). Also my expectations were quite high. I picked the twinscrew to get good low end. It probably just seems slow compared to the madness that breaks out once it revs over 4K.
What I have to do is to drive stock 325, 325 with centrifugal SC and my car one after another to compare. Oh yeah and put the car on a dyno.
More good:
- the infamous M54 4000 RPM power dip is gone!
- it sounds really cool, there is distinctive whine but not annoying at all
- I forgot to mention how good ESS support is (I needed to troubleshoot missed step in the installation)
More questionable:
- the rev limiter seems to be still at 6500 (I'll verify this on the dyno)
- it throws code P0444 (EVAP purge valve C open), no CEL but I think it would fail emissions test (likely a mistake in installation)
- there is strange sound (kinda like valve tick) when coasting below 2500 and punching it hard. It smooths out within a second.
But don't get me wrong, I'm extremely happy with the kit. I just went for a drive and I had very hard time turning around and going back home. I see myself making all kinds of short unnecessary trips in next few weeks.
Old 10-03-2010, 10:55 AM   #6
TxZHP04
Ok, now I follow.
As for the rev limit, honestly, that might be a blessing considering the harmonic issues the M54 experiences at higher rpm. 6800 rpm is probably safe for very short periods as with street use but for extended periods on track, it's questionable.
I agree, the P0444 is likely installation related.
Could that "ticking" noise you describe be spark knock (detonation)? I would take it easy for 100-200 miles to allow for any adaptation then get it on a dyno to make sure everything is performing correctly (be sure to have them check AFRs).
Old 10-03-2010, 11:11 AM   #7
GG///M3
My Ride: Imola e46 m3
Give us some pics
GG///M3 is offline   Reply With Quote
Old 10-03-2010, 02:26 PM   #8
lab rat
My Ride: '02 330iT
I'm past the break in period. The ticking noise could be detonation, I'm just not experienced enough to recognize it. It only does it when going WOT from lower RPMs.
I can snap some pics today, there is just not much to see, it looks pretty stock
Old 10-03-2010, 02:56 PM   #9
GG///M3
I would be watchful with those ticking sounds. They can lead to issues which cause weeping. I still want to see the pics. Are you running any gauges to check your afr's, and boost?
Old 10-03-2010, 03:28 PM   #10
Iceman00
Banned User
My Ride: E90 6MT
Originally Posted by TxZHP04 View Post
Ok, now I follow.
I've only seen the 3.0liter with the said harmonic issues.
Old 10-03-2010, 03:38 PM   #11
Rayce185
Modifiziertes ///Mitglied
Rayce185's Avatar
More good:
Wait, this is only an M54 issue? My M52TU has this problem too...
dun dun duuuunnnn
Rayce185 is offline   Reply With Quote
Old 10-03-2010, 03:40 PM   #12
milKt
My Ride: air/fire
yup,
twinscrews KICK ANUS
Good choice.
milKt is offline   Reply With Quote
Old 10-03-2010, 10:00 PM   #13
Iceman00
Banned User
My Ride: E90 6MT
Originally Posted by rayce185 View Post
wait, this is only an m54 issue? My m52tu has this problem too...
disa
Old 10-03-2010, 10:42 PM   #14
lab rat
My Ride: '02 330iT
Oh I don't know, I never owned M52. They might have the same power dip.
All I know it's gone from my car.
The code P0444 is gone now - wrong connector plugged into the valve (ESS warned about this in their instructions but my label fell off the plug)
Old 10-06-2010, 12:26 AM   #15
lab rat
My Ride: '02 330iT
Ok here is a wrap. I put the car on a dyno today and it produced really nice flat torque line all the way to the redline. Compared to stock there are gains everywhere but mainly over 4K.
I'm happy, just need to buy a radar detector tomorrow.
Old 10-06-2010, 08:16 AM   #16
TxZHP04
Did the ticking noise go away?
Old 10-06-2010, 11:23 AM   #17
lab rat
My Ride: '02 330iT
Yes, by itself. Also I verified the redline is at 6800 now.
Old 10-06-2010, 12:05 PM   #18
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
Really good power for a 2.5 and stage 1.
congrats!
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
Old 01-14-2014, 09:15 PM   #19
dany325tim
My Ride: E46 325 ti
Hi lab rat, I know this post is quite old and also know you have made further mods to your car. Since I'm researching a lot to decide going FI on my 2004 325ti, I've noted that dyno run you showed here is quite far from what ESS TS1 is currently advertising (285 HP and 250 lb/ft, against yours 243 HP and 204 lb/ft)
Any chance of posting the wrong dyno run ? Or maybe ESS has upgraded his TS1 along this years? Any clue?
Tks in advance!
Sent from my GT-P5110 using BimmerApp mobile app
dany325tim is offline   Reply With Quote
Old 01-17-2014, 10:53 PM   #20
lab rat
My Ride: '02 330iT
Hi, actually the difference is in horsepower to the wheels and power at the crankshaft. Just about everyone advertises the higher number. If you take the typical 15% drivetrain loss you end up with:
285x0.85=242
250x0.85=212
So I guess I was down on torque a bit but dyno numbers vary. I took this on a Mustang dyno that typically reads less than the popular Dynojet.
Because sleeper
