Old 07-09-2009, 12:08 PM   #21
hoveringuy
My Ride: e30
Originally Posted by HighBoostin330 View Post
As AJ said, there is an easier way of just using software to fixed it than using hardware and cutting wires in your engine. Thank you for your suggestion.
Who has adjusted it through the instrument cluster?
hoveringuy is offline   Reply With Quote
Old 07-09-2009, 12:31 PM   #22
HighBoostin330
My Ride: 2002 Stock 330Ci
I would give it a shot. However, my car isn't here right now.
For those that would like to try it, I found this from Google search. Seems like you need to use Test 19 to unlock the tests, then enter into Test 20 and then change the correction factor.
http://forums.bimmerforums.com/forum...p/t-61718.html
From what I understand, it is correction factor based. So, X.XX (One . Tenths Hundredths). Similar to that of a dyno.
So go fill up your gas tanks at the gas station. Reset the OBC's MPG readout on the instrument cluster and the odometer mileage. Drive around the way you usually do until you have consumed about 50-75% of your gas tank. Go back to the gas station and refill your gas tank. Then it is a two step process.
1) Read out what the OBC says the MPG is.
2) Manually calculate what your MPG from the odometer mileage divide by the amount of gas you put in your car.
You will find that the MPG you calculate will be lower than what the OBC says. I am assuming that the correction factor is percentage based.
Correction Factor = 1 - [(OBC Readout - Calculated MPG)/Calculated MPG]
Can anyone confirm this hypothesis? My car isn't with me at the current moment. Thanks.
HighBoostin330 is offline   Reply With Quote
Old 07-09-2009, 12:37 PM   #23
hoveringuy
My Ride: e30
Looking through the WDS the OBC doesn't have a discrete fuel consumption signal wire, it is computed by the cluster directly from data off the CAN bus.
If that is the case, the ONLY way to correct would be through software.
CAN is 1/2 the reason I converted my M54 to OBD1.
Old 07-09-2009, 01:10 PM   #24
HighBoostin330
The correction factor is in the instrument cluster, not the OBC. So using what you said, I am trying to change how the instrument cluster calculates the data off the CAN bus to display to the driver. What am I missing here?
In any case, I'll try this when I get my car back. Although I do have INPA to try it with if this doesn't work.
Have fun with your OBDI.
Old 07-09-2009, 01:19 PM   #25
paraklas
My Ride: ESS TS2 320ci
I will give it a try..
470km = 55 Liters of RON 98 gas
100km distance comes to 11.70 Liters (Real measurements)
My OBC shows: 9.7 L/100
Therefore my correction factor should be 1 - [(9.7-11.7)/11.7] = 1.17
Done in US friendly units:
1 liters = 0.264172052 US gallons
Therefore: 11.70L = 3 US Gallons / 62.5 miles
Comes to 20.8mpg average (aggressive driving + ac always on)
Old 07-09-2009, 01:32 PM   #26
NickG@TechniqueTuning
Past Site Sponsor
My Ride: E46 330ci Turbo
The OBC is part of the instrument cluster on the E46
NickG@TechniqueTuning is offline   Reply With Quote
Old 07-09-2009, 01:38 PM   #27
Lemonsqr
My Ride: 2001 TiAg 330i
Please report back to see how accurate this method is. I wonder if the correction factor is based on driving style....????
Lemonsqr is offline   Reply With Quote
Old 07-09-2009, 02:10 PM   #28
HighBoostin330
Having a correction factor of 1.17 would increase your gas mileage wouldn't it? That wouldn't make sense unless your car is more efficient now with the TS.
Well that confuses things a little bit. hoverguy says calculation is done in the instrument cluster and not the OBC. However, the OBC is inside the instrument cluster. So how does the data get to the driver? OBC->Instrument Cluster->Driver?
Old 07-09-2009, 02:16 PM   #29
HighBoostin330
Okay, I'm not familiar with the metric system of gas consumption, but isn't 9L/100km equal to 26.13MPG. So if you calculated 20.8MPG, then isn't that a correction factor of 0.74?
Old 07-09-2009, 02:33 PM   #30
Maestroxl
My Ride: 330CI
Send a message via MSN to Maestroxl
I think fuel consumpton is calculated in litres per 100 km and then converted to miles per gallon.
So in order to get the miles per gallon down, the litres per 100 km have to go up.
Maestroxl is offline   Reply With Quote
Old 07-09-2009, 03:44 PM   #31
paraklas
Correct
Old 07-09-2009, 05:52 PM   #32
HighBoostin330
Correct
Okay, I guess that makes sense then. Let me know if it works then!
Old 12-28-2009, 05:57 PM   #33
lkstaack
My Ride: 04 330iZHP, 05 325iT
I haven't been able to change my MPG correction factor through the instrument cluster; has anyone else been able to? Test 20 does not indicate any data with the tests locked or unlocked. Neither am I able to access sub-menus to input data. Has anyone else tried it with success?
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
Old 10-06-2010, 11:15 AM   #34
lab rat
My Ride: '02 330iT
I think it's time to dig this thread up. What are you guys doing about OBC being way off?
Old 10-06-2010, 12:26 PM   #35
TxZHP04
My Ride: ESS TS2+ ZHP
Nothing. The avg mpg and mte readouts are nice but not essential and I really don't use them anyway so I haven't taken the time to explore the correction factor mentioned above.
Old 10-06-2010, 01:17 PM   #36
lkstaack
I haven't found anything I can do. I would really like my OBC to function as designed; I'm willing to pay for the option, but can't find a way to do it. It's one of the unadvertised trade-offs you have to put up with when you go FI.
Lars
Old 10-06-2010, 01:26 PM   #37
Au2bahn
My Ride: 05 330i ZHP,09 HCHII
Just obtain it the old way by filling up, run, divide miles accumulated by the gallons after fill up.
Au2bahn is offline   Reply With Quote
Old 10-06-2010, 01:32 PM   #38
lkstaack
Of course. But I want my OBC back.
Lars
Old 10-06-2010, 03:28 PM   #39
lab rat
My Ride: '02 330iT
I tried the function 20 in OBC but it doesn't come up with a value
Old 06-04-2015, 12:07 PM   #40
rkneeshaw
My Ride: 330i ZHP
Anybody ever have success in finding a solution?
If the correction factor isn't available in the instrument cluster like it is in other BMW models then I guess the only option is making an adjustment in the DME, but as AJ points out, with MS45 DME's this can be risky or down-right buggy.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
