Old 10-09-2010, 12:26 PM   #21
323tom
My Ride: 2 turbo e46's
What's the trick I don't want to have to send my ecu if I don't have to its not like I dyno weekly anyways
Originally Posted by yellowssm View Post
forgot to tell you about that. Theres a way to trick it into letting you do it but to late now. GL, youre gonna surprise a few people im sure. TAKE SOME VIDEOS!!!!
323tom is offline   Reply With Quote
Old 10-09-2010, 02:24 PM   #22
Viral@ActiveAutowerke
Past Site Sponsor
My Ride: E46 M3
Make Sure you get some Videos congrats buddy
Viral@ActiveAutowerke is offline   Reply With Quote
Old 10-09-2010, 02:58 PM   #23
///M3-QTR
My Ride: IR M3
1) car off
2) turn key to position 2 (everything on but engine off) and wait a couple seconds that the lights on the cluster finish turning on/off.
3) hold DSC button 8 seconds
4) press sport mode
5) start the car
6) rev car to limiter (it will stop at 6.5k, still)
7) turn off car
8) repeat 1) to 5). The car will now be able to rev all the way to 8k
I've done it and it worked ! it works only on pre 03( or 02/4 IIRC) M3's.
///M3-QTR is offline   Reply With Quote
Old 10-09-2010, 04:22 PM   #24
323tom
Sweet I'm going to try that soon, my car has a 02 motor/ecu but I don't have DSC, I have my stock ASC will this still work for me? I can still try it off the dyno as the car won't rev past 6500 in idle correct? Don't want to get to the dyno again try and not have it work and pay for another dyno session lol
Originally Posted by ///M3-QTR View Post
1) car off
4) press sport mode
5) start the car
7) turn off car
Old 10-09-2010, 05:11 PM   #25
GG///M3
My Ride: Imola e46 m3
I would say go from about 3,800 rpms slowly letting of the clutch then hammer the right paddle, and hold on for dear life. At the end you will thank me.
GG///M3 is offline   Reply With Quote
Old 10-09-2010, 05:40 PM   #26
323tom
Ya next friday I will start from 3k and go up by 100-200 rpms untill I get upto 3800... I am sure it will be fun either way
Old 10-09-2010, 05:50 PM   #27
GG///M3
Will this be your first trip to the strip?
Old 10-09-2010, 06:41 PM   #28
323tom
Yep : )
Old 10-09-2010, 07:12 PM   #29
battaM3
My Ride: 2003 m3
Gotta start somewhere. I'm scared of 1/4 mile. I break
everything. So I don't know if me and 1/4 mile will mix well. Good luck.
battaM3 is offline   Reply With Quote
Old 10-09-2010, 07:42 PM   #30
GG///M3
Yep : )
Mine will be in afew weeks as well I hope. In nov its over for the season in my neck of the woods.
Old 10-09-2010, 07:59 PM   #31
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
If it's your first time skip the water box, and no burnout, just take off like you were at a traffic light, racing. Don't worry about cutting a good light. You're not really racing yet, reaction time isn't important yet. Learning how to drive the car at the track is. For your first couple of launches, just focus on getting off of the line smoothly. Don't forget to make sure DSC is turned off. Then start to increase the rpm's on your launch. Getting off the line is one of the most important aspects.
You are going to be anywhere from 2-3 seconds slower than your best time of the day when you start.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 10-10-2010, 01:04 AM   #32
BadBoostedBmwM3
My Ride: 323i & e36 Turbo M3
I don't think 3K will spool that 67mm.
It will probably bog then go.
This is my signature....
BadBoostedBmwM3 is offline   Reply With Quote
Old 10-10-2010, 02:32 PM   #33
323tom
Thanks for the Comments gents, as for 3 k not spooling it don't the smg guys launch at 3k max?
Old 10-10-2010, 02:34 PM   #34
323tom
Oct 22 is my babys hibranating time : ) going to te track, change oil after and clean her and tarp her for the winter...
Old 10-10-2010, 09:33 PM   #35
BadBoostedBmwM3
correct. BUT, they are having problems. You can talk to scott (racerm3x) about that.
Old 10-10-2010, 09:52 PM   #36
BMW_Matt
My Ride: 135
Don't miss.
BMW_Matt is offline   Reply With Quote
Old 10-13-2010, 06:37 AM   #37
bobm3
Senior Eurowerkz Member
bobm3's Avatar
My Ride: 2003m3smg
i was told years ago to lower your lbs of air in the rear so
Originally Posted by Activ3 View Post
Like M5chas said, don't do a real burnout, just spin them a little to clean any debris off of the tires. Also definitely avoid the water box when staging.
I think lowering PSI in the rear tires does make a difference, but it will depend on what profile tire you're running as well. My best ET was done with tons of weight in the trunk and with the tires nearly 10psi below what I run on the street.
the tires could expand and that way you would get a wider patch of rubber on the ground so the tire would grip better.....
bob
bobm3 is offline   Reply With Quote
Old 10-13-2010, 10:06 AM   #38
323tom
Ya that's with slicks not street tires aparently
Old 10-13-2010, 10:21 AM   #39
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I tried a LOT of things back in 2006 to get better traction, and not everything you think would work does.
I remember at one point swapping from a 245 street tire, to a 275 "R" compound and spinning more. I also ran the car down to 10kms left in the tank, then filled the tank up and ran identical ETs, but with a slightly slower MPH.
My favorite was buying a jug of VHT traction compound, and applying it directly to my tires.
I still have the jug.
Tire pressures did help, but only once I figured out how to let out the clutch slowly on launch, and feed in the power. It's a lot harder than it sounds. Basically, I launched at say 1/4 throttle, then progressed to 1/2 throttle while feeding in the clutch. Once the clutch was all the way out, I'd add a little more throttle while "feeling" the tire spin. Most of the time the peddle would be all the way out and I'd have to shift into 2nd....no chance to add more power. 2nd gear was a little easier.
Eventually I got sick of spinning....and moved to slicks.
2009 I had too much traction.
