Old 10-15-2010, 02:53 PM   #1
Evil Twin Rob
My Ride: 2004 M3
MT's weak point
After all my praise of these tires, they finally let me down. After my tire went flat today, I discovered a split all the way around the inside, where the tread meets the sidewall. They still have a decent amount of tread, so I took it Discount to see about some kind of warrantee. They told me they have tried to have that issue warrantied before, with no luck. Guess i'll try to find another tire that hooks well and lasts a little longer.
HPF 2.5
Evil Twin Rob is offline   Reply With Quote
Old 10-15-2010, 03:12 PM   #2
bobm3
Senior Eurowerkz Member
bobm3's Avatar
My Ride: 2003m3smg
sorryto hear about that but you were lucky
that the tire did not come apart while you were driving high speed.....i think you luck out kind of on that flat.....
bob
bobm3 is offline   Reply With Quote
Old 10-15-2010, 05:45 PM   #3
Commanderwiggin
My Ride: 900rwhp Turbo M3
That's really unfortunate...has Jesse had any problems with his? I was thinking about pulling the trigger on these next year.
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 10-15-2010, 06:30 PM   #4
InDiGlOM3
My Ride: HPF M3 stg 2.5
Thats weird......I have still had no problems. if you got the added warranty with discount, then its discount that warranties you. not where the tire came from. they bullshittin you and you need to make them replace it.
Old 10-15-2010, 06:43 PM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
No warranty for a tread that's coming off? That's crazy...frankly, whether you had tread or not...but if it did have no tread, I'd understand them not wanting to just give you new tires...
Though, as those are, I also think you'd be crazy to have them warranty them by giving you the same tire. Maybe if you go back to place that sold you the tire and mention that you understand, but would hope they'd try again, coz otherwise you'll be mentioning this issue on the Internet...where you have 150K close friends!
I don't know what you were doing at the time, but will presume you hadn't exceeded speed rating of tire or did any drifting...but still... I won't be buying those tires!
Doug
Facebook.com/DMAXstandup
Mangofy your E46!
Old 10-15-2010, 06:49 PM   #6
BimmerDude18
My Ride: 1998 528i
I wonder if this is common, I've never heard of this before form an MT, but frankly all tires have some percentage of failure through sidewall separation.
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 10-15-2010, 07:13 PM   #7
funkboy316
My Ride: 2003 M3 vert
yeah if you got the discount tire warranty you should be able to have them replaced. hell they replaced this for me.........got really lucky i was in rush hour traffic at about 25-30mph when this happened....could have been real nasty at speed, had both of the little ones in the back seat and everything.
2003 TiAg HPF stage 2.5 SMG M3 vert
funkboy316 is offline   Reply With Quote
Old 10-15-2010, 11:14 PM   #8
Evil Twin Rob
My Ride: 2004 M3
I didn't figure they would last long enough to bother with a warranty.
HPF 2.5
Old 10-15-2010, 11:42 PM   #9
jtrejo
My Ride: e46 m3
extreme garage make over needed ASAP!!! just playin
2006 Vert AW/Cin. SMG SOLD
Custom Designed WON Direct Port Nitrous System
jtrejo is offline   Reply With Quote
Old 10-16-2010, 08:49 AM   #10
InDiGlOM3
No your not.....Def needs one. atleast a cleaning.
Old 10-16-2010, 10:29 AM   #11
MaverickM3
My Ride: gets badge
Thanks for the post Rob. This is what I was getting ready to order for my car since you and Taza had really good reviews for traction on them. Well this sucks..
MaverickM3 is offline   Reply With Quote
Old 10-16-2010, 01:49 PM   #12
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
Might just be a fluke, I wouldn't throw out these tires as a solution just from one tire doing this...
MSpired is offline   Reply With Quote
Old 10-16-2010, 04:06 PM   #13
Evil Twin Rob
My Ride: 2004 M3
Both tires did it, and the separation was even starting to occur on the outside. I will ask Discount if their warranty would have covered this. If so, I will buy another set with a warranty. If not, I want to try the Toyo r888.
HPF 2.5
Old 10-16-2010, 06:46 PM   #14
funkboy316
its just the shed, not where the car sleeps....lol if you can tell it has been alot of things, paint booth, fiberglass shop, cabinet shop, junk storage.....lol
Old 10-16-2010, 07:52 PM   #15
MSpired
Wow, both at the same time, that's crazy! A warranty would be worth it then
Old 10-16-2010, 09:53 PM   #16
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
There's a number on the tire that tells you the date it was made. Can you find that # and post it up?
Chris.
HPF Chris is offline   Reply With Quote
Old 10-16-2010, 11:24 PM   #17
UrineMachine
Banned
My Ride: Mysterious 5
Send a message via AIM to UrineMachine
That is consistent with sidewall rip from running low air pressure for sustained amounts of time.
What pressure did these see?
Honestly.
It also doesn't help that this is a large rim size - it's hard to tell visually that they're low on air.
Low air, soft compound, small sidewall, rip.
UrineMachine is offline   Reply With Quote
Old 10-16-2010, 11:32 PM   #18
BimmerDude18
My Ride: 1998 528i
Honestly.
I was thinking that. Soft compounds with lots of heat are good for traction, but the heat generated by running lower air pressure also can lead to sidewall separation (anyone remember Firestones and Explorers?).
I'm not saying there isn't an issue, but that it might require some investigation, MT's are beloved tires.
As a side note, a buddy with a GTO mentioned a newer goodyear drag radial has gotten a ton of respect from the GTO crowd.
-Tyler
Old 10-16-2010, 11:42 PM   #19
UrineMachine
Banned
A lot of people will run their cars on drag radials (R2 compound) or true slicks (whether nylon belted or bias ply) when dyno'ing on dual-roller units and be surprised when the tires are ruined in like 30 seconds of pulling. The heat generated by low air pressure or high load weight is remarkable. The only time you can REALLY get away with it on the street is on a 15 - 16" wheel where theres lots of material to transfer the heat to. But, if you drove down the street on ET Street Radials @ 10 psi on a 15" you'd melt them in a few miles too.
Old 10-17-2010, 01:07 AM   #20
InDiGlOM3
Rob also took these from wa to cali and back. I have takin mine (same size) from Tx to Az and back, 2k round trip.
