Thread Tools Search this Thread Rating: Thread Rating: 67 votes, 4.99 average. Display Modes
Old 10-19-2010, 12:11 AM   #1
omarmarji
Banned User
My Ride: E36 332i
Complete DIY of everything!!!!!!!
DIY: Painting your exterior trim (without removing)
http://www.e90post.com/forums/showth...ghlight=window
DIY: Paint Your Interior Trim
http://forum.e46fanatics.com/showthread.php?t=798917
DIY: Replacing Door Hinge/Door Brake
http://forum.e46fanatics.com/showthread.php?t=351613
DIY: Painted Kidney Grille
http://www.bmw-m.net/techproc/grill.htm
DIY : Secondary Air Pump & Valve
http://forum.e46fanatics.com/showthr...ht=diy+seafoam
DIY: Stay Genuine And Enjoy Shorter Shifts
http://forum.e46fanatics.com/showthr...rt+shifter+diy
DIY: CDV Delete
http://forum.e46fanatics.com/showthr...hlight=diy+cdv
DIY: Change fuel injectors on a E46 325
http://forum.e46fanatics.com/showthr...do+it+yourself
DIY: Oil Change
http://www.my330i.com/lof.php#H
DIY: Factory Alarm Kit
http://www.my330i.com/mod8.php
DIY: BMW AUX AUDIO INPUT KIT
http://www.my330i.com/mod26.php
DIY: 12V Auxiliary Power / Secondary Cig. Lighter Under $10!!
http://forum.e46fanatics.com/showthread.php?t=791932
DIY: Grilles, Windshield Wiper Tank, Custom USB charger
http://forum.e46fanatics.com/showthr...967&highlight=
DIY: Refinish/Restore Curb Rashed wheels
http://forum.e46fanatics.com/showthr...071&highlight=
DIY: Sedan Rear Bumper Removal/Installation
http://forum.e46fanatics.com/showthread.php?t=358017
DIY: CF Roof Install
http://forum.e46fanatics.com/showthread.php?t=483306
DIY: Fender Rolling
http://forum.e46fanatics.com/showthread.php?t=598528
DIY: Complete M3 OEM Mirror Retrofit for the E46 Sedan
http://forum.e46fanatics.com/showthread.php?t=675377
DIY: E46 M3 mirrors retrofit onto E46 sedans/wagons instructions
http://www.rogueengineering.com/Merc..._Code=E46M3MIR
DIY: Convertible Top Interior Trim Flap Repair
http://forum.e46fanatics.com/showthread.php?t=520323
DIY: Dash Removal / Replace
http://forum.E46Fanatics.com/showthread.php?t=628898
DIY: OEM illuminated gear knob installation
http://www.argyrides.eu/bmw/accessor...knob/shift.htm
DIY: Cluster LCD replacement
http://forum.e46fanatics.com/showthread.php?t=670689
DIY: Shift Style alcantara Shift Boot / Ebrake Boot install
http://forum.e46fanatics.com/showthread.php?t=786558
http://forum.e46fanatics.com/showthread.php?t=751751
DIY: CCV, DISA, ICV, Oil Separator
http://forum.e46fanatics.com/showthread.php?t=643639
DIY: Brake Rotors and Pads
http://forum.e46fanatics.com/showthread.php?t=410638
DIY: Oil Level Sensor
http://forum.e46fanatics.com/showthread.php?t=366659
DIY: Front Control Arm Bushing (FCAB)
http://forum.e46fanatics.com/showthread.php?t=140066
DIY: Front Control Arms
http://forum.e46fanatics.com/showthread.php?t=421918
DIY: PowerFlex Rear Trailing Arm Bushing RTAB DIY
http://forum.e46fanatics.com/showthread.php?t=678004
DIY: Replacing Rear Differential Bushings Mounts
http://forum.e46fanatics.com/showthread.php?t=521636
DIY: 5 to 6 Speed Swap
http://forum.e46fanatics.com/showthread.php?t=574363
DIY: neil1138's 5 Speed Swap - Great information on the parts and process of the swap
http://forum.e46fanatics.com/showthread.php?t=659314
DIY: Power Steering Pump
http://forum.e46fanatics.com/showthread.php?t=575499
DIY: UUC Under Drive Pulley Install
http://forum.e46fanatics.com/showthread.php?t=483472
DIY: EMP Stewart Water Pump + Expansion Tank + Deflector Pullies + Coolant Flush
http://forum.e46fanatics.com/showthread.php?t=634490
DIY: Differential Swap
http://bokchoys.com/differential/diy_diff.htm
DIY: 02 Simulator install
http://forum.e46fanatics.com/showthread.php?t=654222
DIY: Installing Adjustable Lower Control Arms
http://forum.e46fanatics.com/showthread.php?t=675565
DIY: Intake boot replacement
http://forum.e46fanatics.com/showthread.php?t=754766
DIY:Angle Eye Install
http://www.fastm.com/m3/angeleyes.html
DIY: Corner / Parking Light Delete
http://forum.e46fanatics.com/showthread.php?t=278132
DIY: Corner / Parking Light Delete - without risking damage
http://forum.e46fanatics.com/showthread.php?t=694015
DIY: Taking your headlight apart (excludes facelift coupes)
http://forum.e46fanatics.com/showthread.php?t=609558
DIY: Headlight removal for facelifted coupe
http://forum.e46fanatics.com/showthread.php?t=639475
DIY: Changing Xenon Bulbs on 04+ coupe
http://forum.e46fanatics.com/showthr...66#post8288566
DIY: Changing Xenon Bulbs on all e46 models (except 04-06 coupes)
http://forum.e46fanatics.com/showthread.php?t=609544
DIY: Installing LED interior lights
http://forum.e46fanatics.com/showthread.php?t=640683
DIY: Parrot Bluetooth using Connects2
http://www.bokchoys.com/differential..._bluetooth.htm
DIY: OEM Navigation Retrofit Guide
http://forum.e46fanatics.com/showthread.php?t=203145
DIY: Build Your Own Paddle Shift Kit
http://forum.e46fanatics.com/showthread.php?t=56234
DIY: Build Your Own Paddle Shift Kit - For an X5
http://forum.e46fanatics.com/showthread.php?t=63211
DIY: BMW 16:9 Widescreen NAV Retrofit
http://forum.e46fanatics.com/showthread.php?t=121982
DIY: Carputer
http://forum.e46fanatics.com/showthread.php?t=409009
DIY: Inspection II walk through
http://www.bimmerfest.com/forums/sho...d.php?t=109846
DIY: Fuel Filter
http://forum.e46fanatics.com/showthread.php?t=265683
DIY: Oil and Engine Service Light Reset for 99-00 e46 - OBD I
http://forum.e46fanatics.com/showthread.php?t=145270
DIY: Post-Cat O2 Sensors + Pre-Cat O2 Sensors
http://forum.e46fanatics.com/showthread.php?t=293116
DIY: Camshaft Sensor
http://forum.e46fanatics.com/showthr...ghlight=sensor
http://forum.e46fanatics.com/showthr...sensor+exhaust
DIY: ATF Flush
http://forum.e46fanatics.com/showthread.php?t=438667
DIY: Coolant Flush
http://forum.e46fanatics.com/showthr...ht=coolant+DIY
DIY: Belt Replacement
http://forum.e46fanatics.com/showthread.php?t=522832
DIY: Blower fan
http://forum.e46fanatics.com/showthread.php?t=418987
DIY: Rear Wheel Bearing on the Cheap
http://forum.e46fanatics.com/showthread.php?t=581164
DIY: E46 Front Wheel Bearings
http://forum.e46fanatics.com/showthread.php?t=610725
DIY: Manual Transmission Fluid Change
http://forum.e46fanatics.com/showthread.php?t=491209
DIY: Oil Change
http://forum.e46fanatics.com/showthread.php?t=483444
DIY: Made non-folding, OEM M3 mirrors auto fold
http://forum.e46fanatics.com/showthr...&highlight=diy
DIY: Sub installed in ski pass
http://forum.e46fanatics.com/showthr...ht=sub+install
DIY: How To Remove And Install Cams Without Any Special Tools
http://forum.e46fanatics.com/showthread.php?t=799650
DIY: Remove Alternator..Auto-Trans..no need to remove fan. Red Battery light
http://forum.e46fanatics.com/showthr...190&highlight=
DIY: Final Stage Resistor - Cabin Fan controller
http://forum.e46fanatics.com/showthr...&highlight=fsr
DIY: ZKW-R lens into Bosch/AL Bi-xenon projector
http://forum.e46fanatics.com/showthread.php?t=801408
DIY: DIY Flex Disc (Guibo)
http://www.bokchoys.com/differential/diy_guibo.htm
http://www.bokchoys.com/differential/diy_diff.htm
DIY: E46 Rear Brake Job
DIY: E46 3 Series Cabin Air FIlter Replacement
DIY: E46 Valve Cover Gasket Replacement
DIY: Spark Plug Removal and Installation
DIY: BMW E46 Spark Plug Boots
DIY: Airbox Removal
DIY: BMW E46 Gauge Cluster Removal
DIY: Checking / Adding Coolant on a BMW
DIY: BMW Oil Mileage Service Reset
DIY: E-46 AWD FRONT AXLE SWAP
DIY: E46 Sock Mod DIY
DIY: BMW 3 series (E46, E36) dashboard test
omarmarji is offline   Reply With Quote
Old 10-19-2010, 12:21 AM   #2
thesheikh
My Ride: 2003 Benzo E500
i like this. we should add to the list.
thesheikh is offline   Reply With Quote
Old 10-19-2010, 12:30 AM   #3
steel330i
My Ride: E46 330i & '90 318i
nice nice nicely done...definitely going to "CTRL+D" this bad boy...
My "Painting Your Interior Trim" DIY- http://forum.e46fanatics.com/showthread.php?t=798917
E30's FTW!!!
steel330i is offline   Reply With Quote
Old 10-19-2010, 12:40 AM   #4
mvrk10256
My Ride: E30 325i
add stuff from my sig as you like.
Old 10-19-2010, 01:33 AM   #5
G-Hots
My Ride: ///M3 & 328ci
Send a message via AIM to G-Hots Send a message via MSN to G-Hots
you should add my one and only diy too lol
G-Hots is offline   Reply With Quote
Old 10-19-2010, 10:30 AM   #6
omarmarji
Banned User
My Ride: E36 332i
thx guys, anymore DIY???
Old 10-19-2010, 10:36 AM   #7
alwaysbored786
My Ride: M3
my sig, how to refinish rims
*NO F-BOMBS IN SIGS*
How to refinish rims
2004 Noble M12 GTO 3R
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
1998 Honda Civic - Sister Totaled
2002 330CI - SOLD
2006 CBR 600RR - SOLD
1995 M3 Coupe - SOLD
1988 325E - SOLD
1996 Cherokee - SOLD
alwaysbored786 is offline   Reply With Quote
Old 10-19-2010, 10:39 AM   #8
Dan99
My Ride: 2001 330xi
omg, mods please sticky this!
Dan99 is offline   Reply With Quote
Old 10-19-2010, 10:40 AM   #9
Riverbmr3
My Ride: MB E350 & BMW 325i
HERE:
http://forum.e46fanatics.com/showthread.php?t=519743
Riverbmr3 is offline   Reply With Quote
Old 10-19-2010, 11:38 AM   #10
alwaysbored786
My Ride: M3
/thread
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
2002 330CI - SOLD
1988 325E - SOLD
Old 10-19-2010, 01:58 PM   #11
G-Hots
one of the best diy's ever!! top 5 imo
Old 10-19-2010, 02:00 PM   #12
OrientBlau
My Ride: 2003 330i
Subscribed
OrientBlau is offline   Reply With Quote
Old 10-19-2010, 03:24 PM   #13
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
Here are mine:
Oil Level Sensor - http://forum.e46fanatics.com/showthr...&highlight=diy
Tweeters on A-Pillar - http://forum.e46fanatics.com/showthr...&highlight=diy
Fuel Level Sensor/Sending Units - http://forum.e46fanatics.com/showthr...&highlight=diy
Door lock relays - http://forum.e46fanatics.com/showthr...&highlight=diy
Ugly yellowing washer tank blacked out - http://forum.e46fanatics.com/showthr...&highlight=diy
Inspection Service reset for older models (1999 - 2000) ALTERNATE METHOD - http://forum.e46fanatics.com/showthr...&highlight=diy
DIY: Made non-folding, OEM M3 mirrors auto fold. - http://forum.e46fanatics.com/showthr...&highlight=diy
Sub installed in ski pass - http://forum.e46fanatics.com/showthr...ht=sub+install
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 10-19-2010, 08:30 PM   #14
alwaysbored786
My Ride: M3
Thanks!
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
2002 330CI - SOLD
1988 325E - SOLD
Old 10-19-2010, 09:58 PM   #15
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
My diy vids ftw
Old 10-20-2010, 08:04 AM   #16
paraklas
My Ride: ESS TS2 320ci
In-Car PC Project
Blower Fan Replacement
Engine Stalling fix (Official Documentation)
Lower Seat Tensioner
Gauge Rings
Alarm Shock Sensor install
Bi-Xenon flicker/warning fix with no coding
Door rattle fix
Rear parcel shelf rattle fix
Speakers install
Treating rubber seals
Sub install
Antenna booster replacement
Window regulator on sedan
OEM M3 mirrors with autofold retrofit
Door lock actuator DIY
Heater valve replacement
ESS TS2 Oil change
90 angle OBDII adaptor
Water pump - Expansion tank - Tensioners - bleeding - refilling
3rd Engine cover diy
Thermostat replacement
Brake replacement
Electric leather seats retrofit
M3 fuel buffle fixture DIY on non-M
330 Front brake conversion
Genuine armrest install
OEM electric rear blind install
Clutch Delay Valve removal
Powerflex bushes install
Eibach pro-kit springs install
ESS TS2 Install
Meyle control arms and bushes install
VANOS Seals replacement and VCG
Hotchkis Sway bar kit
Hotchkis front endlinks diy
Oil catch tank
Turner rear shock mounts install
AEM Wideband sensor install
Driver's compartment light mod (EU models only)
3000K HID Fog light install
Additional lighting in trunk
Angel eyes install
All of the above plus updates hosted on my own site here
Old 10-20-2010, 08:13 AM   #17
Darkoz
My Ride: E46 325Ci
Well done, Stephen Hawkings would be proud
Darkoz is offline   Reply With Quote
Old 10-20-2010, 08:24 AM   #18
millerb
My Ride: 99 323i
AC compressor DIY?
millerb is offline   Reply With Quote
Old 10-20-2010, 09:21 AM   #19
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Got Darn! This is a long list!
Originally Posted by paraklas View Post
In-Car PC Project
Gauge Rings
Door rattle fix
Speakers install
Sub install
ESS TS2 Oil change
Brake replacement
ESS TS2 Install
Oil catch tank
Angel eyes install
delmarco is offline   Reply With Quote
Old 10-22-2010, 12:55 AM   #20
skeet
My Ride: 2001 330ci
everything i ever need
i like thumbs ups and high fives!
Photobucket
skeet is offline   Reply With Quote
