eas | Macht Schnell – e46 M3 Stage 1 Intake Charge Kit - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-22-2010, 02:59 PM   #1
david @ eas
Past Site Sponsor
My Ride: E46 M3
Gentlemen,
Factory BMW intake systems are well known to be very efficient – particularly on the M models. Transform your highly engineered and efficient Original Equipment (OE) air box into a beast by replacing its two most restrictive pieces with the Macht Schnell S54B32 High Performance Panel Air Filter and the Intake Charge Pipe in a high value, high performance package. The Macht Schnell Stage 1 Intake Charge Kit will rival all the current so-called “cold air intakes” at a more reasonable cost. This combination has shown gains of over 10 rwhp/7 ft lbs tq on a chassis dyno.
Intake Charge Pipe Features:
The stock plastic intake elbow on your BMW E46 M3 is a good functional piece, but leaves power on the table. The sharp corner and accordion sections of the stock piece creates flow turbulence right before the critical entry into the engine’s air plenum. The shape of the stock part is less than optimal. The Macht Schnell S54 Intake Charge Pipe (ICP) is designed using the same features as the intake sections on the World Challenge class racecars.
This high quality silicone replacement hose adds real power and throttle response that you can feel. With a reshaped profile that creates a secondary air reservoir, more filtered air volume is available and essentially creates more plenum volume. This intake pipe combined with a performance panel filter such as the Macht Schnell High Performance Filter or other performance intake systems that do not replace the factory plastic elbow will create a super efficient intake system. High quality 5-layer silicone construction will withstand anything you can throw at it for years to come.
Macht Schnell is proud to offer a high quality, high performance and high protection original equipment direct replacement air filter – specifically for your S54 powerplant. Each filter is designed to the specific requirements of your engine it will be protecting to deliver top-level performance with maximum flow and filtering. Pleat depth, quantity and filtering media configuration are tuned to provide the best possible performance without compromising the protection required for today’s high tolerance engines.
Our High Performance Panel Filter is the ultimate first step for someone that wants to maintain and improve upon the highly engineered stock intake systems. This is an engineered filter constructed specifically for your BMW to deliver maximum airflow. Maintaining proper CFM flow and particle capture efficiency is a delicate balancing act and filters that flow well usually do not protect as well. Macht Schnell has mastered the formula to achieve this elusive perfect balance and so your engine assets will perform better without sacrificing protection.
Features of the S54B32 High Performance Panel Filter:
- Direct replacement for your original equipment filter panel
- Washable/reusable cotton gauze which allows more airflow
- Sturdy sidewall construction ensures filter will last the life of the vehicle
- Tight leak proof seal with your factory air box
- Deepest multi-layered pleats increase air flow and maintain critical protection levels, while still providing maximum air delivery
- Maintains OEM filter’s 99% debris collection efficiency to meet ISO 5011 standards
- Maintains BMW engineered pressurized air box and OEM appearance
YES, you can buy them separately. But why would you do that if you can save a bit by buying the kit!
Models Supported:
2000-2006 BMW M3
Intake Charge Pipe:
http://www.europeanautosource.com/pr...oducts_id=3128
Macht Schnell Intake Charge Kit:
http://www.europeanautosource.com/pr...oducts_id=3129
If you have any questions, please feel free to ask!
david @ eas is offline   Reply With Quote
