How do I raise my lowered car? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 10-18-2010, 12:04 PM   #1
Enemy
My Ride: '03 ZHP & '01 740iS
Send a message via Yahoo to Enemy
Im a suspension mod noob.
Bought an '03 330i ZHP lowered on TC Klein S/A Coilovers in August. One tire on my 18" ASA's blew out this morning and I switched to my winter setup 17" BBS wheels with 225/50/17 Dunlops on em. Now the wheels/tires rub on my car cause it's too low.
How do I raise the car back up a bit?
Please help. Thanks!
Enemy is offline   Reply With Quote
Old 10-18-2010, 12:54 PM   #2
jpjp
My Ride: '08 335XI
The fronts can be done by first releasing the two collars with the special wrench that comes with the kit. You turn then in opposite directions to release the pressure. You then turn the top ring that the coil spring sits on up until you get the desired height.
The rear should have a pod that the spring sits on. You would loosen the set screw and rotate the outer part to regain the height you need to clear the tires. You will not have to remove the center bolt or the spring but you will have to jack up the car and release the lower shock mount.
Once you get everything set, remember to bring the bottom collar up to the top one and tighten them up and retighten the rear set screw as well.
You can do this with a jack and jack stands.
jpjp is offline   Reply With Quote
Old 10-18-2010, 01:02 PM   #3
w0w
My Ride: '02 M3 Vert
where are u rubbing?
daron
w0w is offline   Reply With Quote
Old 10-18-2010, 04:25 PM   #4
Enemy
Crap. I don't have the "special wrench" that you mentioned, or jack stands. All I have is a low-pro hydraulic jack and the stock the stock jack.
19mm socket for the lower shock mount?
Old 10-18-2010, 04:27 PM   #5
Enemy
At the fender right where you would roll them.
Old 10-18-2010, 08:14 PM   #6
Enemy
Here's some pics of my coilovers and the car. I don't have the coilover wrenches and the PO told me he still has them and will mail them to me. Will I truly need jack stands or can I do one corner at a time?
Front
Rear
Side profile
Front passenger wheel
Rear passenger wheel
I guess since I'm running the winter setup now, I would feel better with the car running a safe height. I realize it's not the lowest car, I've seen much lower, but I wanna be on the safe side. Possibly run stock height and proper alignment. It doesnt ALWAYS rub right now, but going over a low-medium bump is enough to make me scrape the tires somehow.
Old 10-22-2010, 10:08 AM   #7
jpjp
My Ride: '08 335XI
Originally Posted by Enemy View Post
.... I don't have the coilover wrenches and the PO told me he still has them and will mail them to me. Will I truly need jack stands or can I do one corner at a time?......
No, You don't need jack stands but it is safer to use them being you will have your head underneath the car. If the tools don't show up, you could always use a flat screwdriver and lightly tap the tabs on the collar to break them free.
The rears are done with the allen wrench. You don't need any sockets. This can all be done by hand.
You can do one wheel at a time but just don't tighten anything up until you are happy with the height.
jp
Old 10-22-2010, 05:53 PM   #8
BMW_Matt
My Ride: 135
Can I have your suspension? You can have mine.
BMW_Matt is offline   Reply With Quote
