Calling all high mileage xi owners (what has broken?) - Page 5 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 4.86 average. Display Modes
Old 09-16-2010, 10:04 PM   #81
djbradle
My Ride: 2002 325 xit
Since my first post I now have the front passenger regulator to do. Things I forgot to add were the fan coupling.
I decided to pull out the previous owners info and put it here. It was purchased around 30-40k miles.
46,000 - front/rear brakes, Front stabilizer links, Coil springs
75,000 - Inspection II, driver belts, front left and right outer CV boots
78,000 - final stage resistor, p/s pump, battery, alternator
djbradle is offline   Reply With Quote
Old 09-16-2010, 11:04 PM   #82
tylerrrer
My Ride: 2001 330xi
130,000 now
Right Front Axle
all four rotors
all four pads
all four sensors
brakes were my fault so cant blame the car there so only thing over 130,000 miles (i think i got lucky) is the axle good for me!
tylerrrer is offline   Reply With Quote
Old 10-16-2010, 08:45 AM   #83
ganicki
My Ride: e46 325xi, e36 344ic
at 150000 replaced frt suspension pieces (all), alternator, radiator and hoses, rotors, pads, pulleys--nothing out of the ordinary yet--but am waiting for something to hit--will wind up doing all axles soon boots are cracked--drive the car pretty hard 90% of the time--most of this stuff was changed at 120-130K--xi is lowered, bilsteins, urethane bushings up front. I absolutely love this car--AWD handles great--goes thru the snow with ease--can turn the DSC off when I want to have some fun--wish it had another 60+ HP & torque
ganicki
2001 325xi
1994 344ic
if you don't believe go to: http://s88.photobucket.com/albums/k1...cki/?start=all
ganicki is offline   Reply With Quote
Old 10-16-2010, 09:06 PM   #84
XIinSC
My Ride: 2004 M3 98 M3
I'm at 88k and have done the following...
CV Axles - needed when i bought it
Starter - worst job EVER!
Alternator
Belts
Tensioners
Valve cover gasket
Front and rear pads and sensors
Front and rear rotors- front were unturnable so went drilled/slotted all around
Did the zip tie fix for front window regulator
Still love the car so the cost of repairs was well worth it.
XIinSC is offline   Reply With Quote
Old 10-22-2010, 01:29 PM   #85
TX_Bullet
My Ride: 2001 325Xi
car is at 173k....since i owned it driver window reg, expansion tank, battery, fcabs and ccv. However when my father in law owned it and i had my coupe i replaced full cooling system, power steering pump, all the spark plugs, a few coils and the remaining 3 window regs.
I can already sense the remaining suspension needs replacement along with front cv boots as well as another power steering pump and the alternator is beginning to whine
Originally Posted by jbeurotech View Post
Sometimes the Cheapest quote is the most expensive in the end
Number of Destroyed Newb Destroyers- 1
The Mods
Power Flex FCAB
Much more coming.....
TX_Bullet is offline   Reply With Quote
Old 10-23-2010, 07:53 PM   #86
DasQvck
My Ride: '07 Silverado diesel
Recently bought my '01 330xi with 154k. Just broke 158k last weekend on a road trip. Half way there, the hood badge came flying off. Other than that, my crank case vent has gone bad, causing the car to burn oil, run rich, and throw a "Rich on bank 1 and bank 2" code. Also definitely needs front control arm bushings, like everyone else. And my alternator belt idler pulley occasionally makes noise. All part of the fun of owning a high-mileage car.
Doing my part every day to make anything I touch go faster.
DasQvck is offline   Reply With Quote
Old 10-23-2010, 08:39 PM   #87
Kubica
My Ride: 2003 325xi
Only things out of the ordinary for me has been crankshaft position sensor, starter, and front wheel bearing.
I'd get those pulleys swapped out soonish.
Old 10-24-2010, 09:47 AM   #88
shicobico
My Ride: f30
Bimmer newbie
First post!
6 speed 03 330xi sport and premium package.
Recent purchase. Repairs so far:
Rear struts and coil springs (both springs broken)
Valve cover gasket
Battery
Brake fluid flush (nasty)
Oil and filter
Rims and tires for sale! Make an offer!
Rear Driver
Front Driver
shicobico is offline   Reply With Quote
Old 10-24-2010, 10:31 AM   #89
TiAgXi
My Ride: e46xi, e46m
I've replace the entire suspension except for sway bar end links. I replaced the axles, CA/CABs, springs/struts/shocks (dinan), tie rod endlinks, shock/strut mounts.
battery.
cooling system except for radiator.
Vanos seals.
one wheel bearing.
that's about it.
TiAgXi is offline   Reply With Quote
Old 10-25-2010, 02:12 AM   #90
solano0004
My Ride: 2003 330xi
I' m at 70000 on the clock now, got it a couple years ago when it had 41000 and so far i had:
Replace the battery (started to give trouble around 62000)
Replace the two front and pass side rear window regulators
The vapor barrier and door rubber seal on front driver side door
Vanos overhaul (beisan kit) along with valve cover gasket and bosch platinum spark plugs
Cooling system overhaul (no radiator) with metal impeller water pump (from ECS Tuning)
Ignition coil replaced by the dealer under warranty
Sunroof shade fix by the dealer under warranty
CV boots
Zimmermann drilled rotors w/ pagid pads and oem sensors
Cabin air filter
Wiper blade inserts
And of course regular oil/ filter change every 5000
solano0004 is offline   Reply With Quote
Old 06-08-2011, 10:56 PM   #91
Sixracer
My Ride: '01 325xiT, '85 M635
Originally Posted by Sixracer View Post
2001 XiT purchased with 89k, put about 5k on it.
Seller did 1 CV boot, I did other
I did cooling system(pump, thermostat, expansion tank, sensors)
Replaced belts
Replaced cabin air filter
Going to do spark plugs
Going to change trans and diff fluids
-did spark plugs
-did trans and diff fluid
-I ended up doing both CV joints and axles
-Replaced alternator voltage regulator, headlights pulse so doing it again
-replacing serp belt tensioner(mainly due to my wrenching, not faulty)
-replaced fuel filter
-replaced cracked intake boot
...................2001 325Xi Touring..................1985 M635Csi..................
Sixracer is offline   Reply With Quote
Old 06-09-2011, 09:40 AM   #92
SamDoe1
My Ride: 4cyl of fury
- DISA Valve
- Cabin Filter
- Air Filter
- Spark Plugs
- Front sway bar endlinks
- Tranny fluid
- Tires
- Rims (Not faulty, got a summer set)
- Oil/Filter change a handful of times
Still to do:
- Diff fluid
- TC fluid
- Shocks/Struts/Springs all around
- Fuel Filter
- Front driver window regulator
I've been lucky with the axles, CA bushing, and the usual stuff that goes wrong.
Old 06-09-2011, 08:48 PM   #93
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
a lot of you guys are posting regular maintenance items. things dont go wrong. the bushing, Control arms, endlinks, tierods, brakes, etc.. are wear items. The only broken things for me were a secondary air pump control valve, t-stat, and a busted axle boot.
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 06-17-2011, 02:27 PM   #94
03E46xi
My Ride: 03 325xi and 95 M3
178,000 in my 03xi
had to replace..
-lower control arms and bushings
-both rear axle shaft diff seals
-still need to replace the clutch
-still need to replace high pressure p/s hose
but besides maintenance items those are about it and its still running strong.
03E46xi is offline   Reply With Quote
Old 06-19-2011, 08:19 PM   #95
srm5161
My Ride: 325xi
At 106k (owned the car since 75k):
- Camshaft position sensor
- Coolant temp sensor
- Final stage resistor
- Both front axles
- Springs (passenger rear and driver front broke)
- Shocks and shock mounts
From what i gather from the forum my diff bushings are bad...and my passenger front window is slowly dying
srm5161 is offline   Reply With Quote
Old 06-20-2011, 11:02 AM   #96
latitude39
My Ride: 2002 325xi (163k)
122,500 miles; Purchased at 17,000 miles
Cooling system (105k miles):
  • Expansion tank and cap
  • Thermostat (replaced with an aluminum aftermarket)
  • Hoses (those 2 connected to thermostat and the one connecting lower expansion to engine)
  • Water temp sensor
  • Thermostat
  • Water pump
CCV (Crankcase ventilation and related pipes and hoses) - Done as PM - 110k miles
VANOS seals (Beisan) (110k miles) - done as PM - Valve Cover gasket and seals replaced
Oil Filter Housing (OFH) gasket (115k miles) - Was leaking onto front differential and PS hoses.
O2 sensors (all 4) - 110k Pre-cat - 120k Post-cat
Front axles - Replaced right and left one time each; rebooted a time or two.
Front control arm bushings (CAB) ~75k miles
Front subframe-to-control arm ball joints - Replaced after mechanic split open the boots with a pickle fork. 115k miles
EBOX fan that ventilates the EBOX into passenger compartment - 110k miles - This fan starts to "chirp" lightly and sounds like a little bird is in your ventilation system. $100 fan. Simple install.
Auto Transmission service (ignoring the "Lifetime" fill sticker) - new filter and replace 6 quarts ATF(110k miles); drain and fill 5 quarts ATF at 120k miles (done twice in order to get a more complete fluid replacement) - Done as PM - Redline D4 ATF
Differential drain & fill - front and rear - Redline gear oil - PM
Transfer case drain & fill - Done twice (110k miles & 122k miles) in order to get a more complete fluid replacement - PM
Power Steering hoses and reservoir replacement (120k miles) - Done as PM - The leaking OFH gasket (above) leaked on the rack-to-cooler line, making the PS appear leaky.
Alternator voltage regulator/brushes assembly replacement (120k miles) - done as PM
Sunroof shade clips
Window regulator - driver's
Spark plugs, fuel filter, tires, battery, brakes, etc - all replaced at normally expected times and "Inspection I & II" times.
latitude39 is offline   Reply With Quote
Old 06-20-2011, 02:43 PM   #97
nogoer
My Ride: 02 330XI
I got halfway through page 2 and was about to post shocking comments about other guy's 02s and thier low mileage when i realized someone revived an old old thread!
Guess i'll toss in my issues while i'm at it. 02 i bought at 80K now has around 125K 4 yrs later. Previous owner ignored goddam EVERYTHING on the car. Just yesterday i finished replacing the RTABS and now she's all done.
Outside of normal tune up/maint shite...
rear shocks
front struts
control arms
fcabs
sway links
rear shocks
rtabs
front ball joints
thermostat
drive belts (cause of thermo)
valve cover gasket
passenger front cv axel
Oh and the comment about Xi's part pricing i agree with. It's total bs our parts cost so freaking much. Especially when theres more of them to replace!
edit: shoot forgot about both rear springs and radiator hoses done as PM as well from thermo
nogoer is offline   Reply With Quote
Old 06-21-2011, 01:11 AM   #98
xi_ter
My Ride: 2003 325xi
50000 km rear spring broke
60000 km Valve cover gasket
60000 km both front CCV boots ripped and needed replacement.
70000 km ball joint in front control arm ripped.
70000 km all shocks lost pressure and needed replacement to Koni Yellows pairs with new Eibach ProKits.
Old 06-24-2011, 12:36 AM   #99
mooseX
My Ride: 03 330xi 6 gears
105k...nothing out of the ordinary except the ABS is messin with me now but that's about it
I got the car at 100k and the last owner said it was bullet proof AND the only things he did was REGULAR MAINTAINANCE and parts that WEAR OUT...so I won't mention any of that. He worked at a dealership as a salesmen..seemed like a straight shooter
I trust this car to drive to the moon..OR Texas maybe hehe
mooseX is offline   Reply With Quote
Old 06-26-2011, 09:59 AM   #100
sidct
My Ride: 2004 330Xi
I have 102340 miles on my 2003 330Xi, usual routine services and mantainence items and: secondary air pump and valve at 38K, Brakes_ rotors and pads twice, tires ( currently 2nd set), water pump and belts, ATF changed twice ( @ 50k & 100k). No issues currently, runs great!!
sidct is offline   Reply With Quote
