Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 10-26-2010, 01:09 AM   #41
HP Autowerks
Past Site Sponsor
My Ride: E36 M3
No questions?
HP Autowerks is offline   Reply With Quote
Old 11-07-2010, 03:01 AM   #42
GreenD
My Ride: Bucket
Originally Posted by HP Autowerks View Post
No questions?
can you explain a little more about what needs to be machined? Maybe provide pics?
GreenD is offline   Reply With Quote
Old 11-08-2010, 07:05 AM   #43
HP Autowerks
Past Site Sponsor
My Ride: E36 M3
The bottom seat that the front spring sits on needs 1MM shaved off the circumference. KW's seats are 61MM, and the springs we use are 60MM. I'll see if I can dig up a pic.
Old 11-12-2010, 07:42 PM   #44
j30a1
My Ride: E$^M#
They can fit on there without machining. It fits.
j30a1 is offline   Reply With Quote
Old 11-14-2010, 05:43 AM   #45
HP Autowerks
Past Site Sponsor
My Ride: E36 M3
Did you use 60MM or 65MM springs? Can the spring move freely on the seat? What springs did you use?
Old 11-16-2010, 04:04 PM   #46
j30a1
My Ride: E$^M#
Swift 60. Its a little snug but it fits.
Old 11-16-2010, 04:39 PM   #47
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
THE ONLY KW SYSTEM that is NOT progressive are the CLUBSPORTS.
Is this Harold btw? We've met at Cal Speedway a while back. We talked about Scott's 135i etc.
I actually have KW CS and I can affirm that it actually does come with progressive springs for the rears (KW2003) . Least for the E46 non-M kit I have.
I documented some of the findings here.
But in regards to the theme of this thread, yes, linear springs are so much better. I switched to Hyperco all corners. At some pt I may need to Swift them out.
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
Old 11-16-2010, 07:31 PM   #48
HP Autowerks
Past Site Sponsor
My Ride: E36 M3
See, that's the problem. They need to be able to rotate freely or your spring rate will spike. That is why we use Swift thrust bearing with all our coilovers and spring conversions.
Old 11-16-2010, 07:34 PM   #49
HP Autowerks
Past Site Sponsor
My Ride: E36 M3
This is Tyler actually.
Thanks for the info on the KW's. I wasn't aware that they were still running progressive springs on their top of the line coilover offering. Hmm. That link had some good info in it.
The linear springs make such a difference as you've felt/seen. Let me know if you ever want to make the jump from Hyperco to Swift. There are performance gains to be had from the testing we have seen from indpendent research.
Old 11-21-2010, 08:29 PM   #50
HP Autowerks
Past Site Sponsor
My Ride: E36 M3
Bueller?
Old 11-22-2010, 05:00 PM   #51
GreenD
My Ride: Bucket
Placed an order with Harold this morning.
Old 11-30-2010, 01:01 PM   #52
beepers90
My Ride: 04 325,MBkomp,vw,xj
anyone know if Swift, Hyperco, or TCK springs will work with the turner tracksports? I think they are very similar if not revalved H&R rss clubsports.
Langsam 04 325i
MS45.1 Shark, 2 CG locks, Turner Tracksport Plus, 3.46, hawk,slotted,Treehouse,blk m68, BMW p. ssk,dynavin,escort x50, fupersprint heddurs, RE clutch stop, angel I's, eurowise sticker.
beepers90 is offline   Reply With Quote
Old 12-10-2010, 02:55 PM   #53
j30a1
My Ride: E$^M#
That you should talk to Harold about. Looking at the pictures I doubt it though because it looks like the spring beehives. I think those manufacturer only has linear straight springs.
Old 02-23-2011, 05:31 AM   #54
ideal_vx6
My Ride: 2.8L
Send a message via AIM to ideal_vx6
Bump.
ideal_vx6 is offline   Reply With Quote
Old 02-25-2011, 01:44 PM   #55
TalkingToilet
My Ride: estoril e46
wow, some great info here. I was one of those that believed KW was a top tier system out of the box
TalkingToilet is offline   Reply With Quote
Old 02-27-2011, 04:56 PM   #56
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
I was apparently duped as well. Everyone told me go KW V2 when I first joined the forum, and even locals all told me KW V2.
I'm aware they're not the BEST setup, but the OP makes it sounds as if I bought rebranded racelands.
I'm not going to go get Moton's or Ohlins for my 95% street 5% track car.
Old 02-28-2011, 12:22 PM   #57
z_man93
My Ride: 328ci
I bought my e46 328ci a few years ago and it came with KWs. I'm not sure what version. The shocks are purple non-adjustable... if that helps. In the past year I've been getting into AutoX and HPDE, so I'm focusing more on performance. I have absolutely no problem spending $400, or even more, for new spring, rather than having to shell-out the $3k for AST4200s. My question is regarding the performance of the shocks in my KW system. Lets say I upgraded to Swift, or other top-brand, springs. Maybe I went as far as to have my current shocks revalved for the new spring rate. Would I have a competitive system or would the KW shocks still be holding me back?
Anthony Colin Bruce Chapman: Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere.
z_man93 is offline   Reply With Quote
Old 03-04-2011, 12:59 PM   #58
z_man93
My Ride: 328ci
Bump
Wow. Apparently I just killed this great thread. Sorry 'bout that. Any thoughts on the "Shock" aspect of the KW Coil-Over system?
Old 12-06-2011, 07:16 PM   #59
Devious1
Invalid User
My Ride: 330ci
Send a message via AIM to Devious1
can anyone confirm the direct replacement size needed for a non-m kw v2 coilover set?
from what i've gathered...
front:
h- 170mm
id- 61mm
rate- 340lbs
rear:
h- 180mm
id- top 89m/bottom 69mm
rate- progressive
can anyone confirm this?
Devious1 is offline   Reply With Quote
Old 12-06-2011, 09:09 PM   #60
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
front:
h- 170mm
id- 61mm
rate- 340lbs
rear:
h- 180mm
rate- progressive
Call Harold at HP, I'm quite sure he can confirm it / or not. When You figure it out, post your findings.
Good luck.
PS. Harold at HP is great to work with, I bought a Quaife LSD for him; it was a very good experience.
SUMMIT POINT WV 1:24:229 SCCA
Rob43 is online now   Reply With Quote
