Old 11-01-2010, 10:22 AM   #1
gbwindham
My Ride: 2002 BMW 330Ci
Looking for that elusive heater hose
I have a 2001 330i Sedan. I'm overhauling my heater hoses and am having a hard time verifying or identifying the three hoses I need. I already have the radiator hoses.
1) From the heater control valve to the firewall (64218376999, I think)
2) From the heater control valve to the very back of the engine (64218363198, I think)
3) From the other firewall connection to the middle of the expansion tank (64218376153, I think)
4) From the bottom of the expansion tank to the firewall (11531436410 for sure)
What's confusing is the diagram that everyone refers to (Pelican, RealOem, etc.) shows another hose, but then doesn't list the part number. What hose is that? There is no third connection on the firewall that I am aware of.
I hope to buy the aluminum water pump pulley but it is out of stock. My plastic pulley got chipped when I removed it. It was frozen on from ten years of attachment. Surprising, given that it's plastic. Couldn't budge it without a little prying, but like the rest of the plastic parts in the engine compartment, it gets brittle with age. Love my three BMWs, but hate the plastic.
Is the fancy Stewart water pump really worth two times the price of the BMW pump? Car is not raced.
I also need the pulley from the A/C tensioner. Doesn't look like the pulley is available separately from the tensioner itself. Can anyone find the pulley separately?
Last edited by gbwindham; 11-01-2010 at 10:36 AM. Reason: Found additional information to clarify my post.
gbwindham is offline   Reply With Quote
Old 11-01-2010, 02:30 PM   #2
///Flash
Banned
My Ride: a donkey
you need to remove your micro-filer and filter housing to get the heat control valve. basically it is underneath windshield
///Flash is offline   Reply With Quote
Old 11-01-2010, 03:13 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You want confirmation that the hoses are correct?
Sounds like you've been a realoem...there are, iirc, two heater hoses, two engine cooling hoses...and then, two hard pipes...which I didn't replace...and I also gave up on the hose from heater valve to rear of engine...another time...she got enough out of me that trip!
Four hoses is what I have, and would guess you too...plus, of course, upper and lower rad hoses...but those are hard to miss!
Let me know if I can help...been there, done that. For me...channel lock pliers!
Gentle wiggling or you'll be buying the plastic pipes too, I suspect. Know some have sprung a leak from there...prolly should've replaced 0-rings (which I think they have), but that'll be for another time too!
HTH
Doug
Facebook.com/DMAXstandup
Mangofy your E46!
Old 11-01-2010, 03:20 PM   #4
dmax
dmax's Avatar
Oh, sorry, just noticed you have one post. Realoem.com engine/engine cooling/ and heating/ac is where I think you'll find your hoses...let me know if you need a hand...need month/year model car to help
Mangofy your E46!
heater problems, hoses, pulley, tensioner, water pump
