Sponsored by BimmerWorld
Old 11-03-2010, 08:29 PM   #21
cbrommer
My Ride: 2004 325i
The new ones look like they are drilled and slotted.
Sent from my Droid using BimmerApp
innovative concepts :: e46fanatic :: cbrommer
cbrommer is offline   Reply With Quote
Old 11-03-2010, 08:33 PM   #22
WALKD U
My Ride: Just Fast!
Originally Posted by Brian N View Post
Whats different about the new version? Are they still even floating rotors? I can't tell.
They are Triple Drilled and Slotted Rotors. I believe they are Semi Floating Rotors. Just a Different Design.
-TrippinBimmer
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 11-03-2010, 08:43 PM   #23
Brian N
My Ride: 2001 330i Jet Black
-TrippinBimmer
They do look better but I would probably rather have full floating. Unless there is an advantage to semi-floating rotors? I don't even know what a semi floating rotor is.
Brian N is offline   Reply With Quote
Old 11-03-2010, 09:03 PM   #24
WALKD U
My Ride: Just Fast!
Solid Rotor = A single piece of metal is bolted to the wheel.
Semi Floating Rotors = You have a center piece and a separate outer part that the brake pads touch. The two are connected by a bunch of round "buttons" that allow a small amount of movement between the two.
Full Floating Rotors = The braking surface is relatively loose so that it can move around to hopefully become in perfect alignment with the pads. Full floating rotors are less likely to pulse than solid or Semi Floating rotors. Full floating rotors make noise at low speeds as the parts move around, since they're kind of loose.
-TrippinBimmer
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 11-03-2010, 09:49 PM   #25
Brian N
-TrippinBimmer
Thanks for all the info!
Old 11-04-2010, 07:32 PM   #26
franz
My Ride: 03 330i
It appears Turner Motorsport still has them in stock for $179/pr fronts, not a bad price at this time.
I got a pair from them and a pair from Tischer, the first set is working really well so far.
franz is offline   Reply With Quote
Old 11-04-2010, 10:52 PM   #27
Brian N
Yup I ordered a full set of them yesterday from Turner fronts for 179 and rears for 150. Which is still a really good deal if you ask me.
