Rating:
Display Modes |
#1 |
*video* Idling seems rough.. feels like it wants to stall
Hey guys,
another post by me, and im very thankful that you are all a great help. So, I noticed that when I give my car gas in idle, when coming down to the 1500 RPM, it stops, then goes down slower.. I also recently noticed that it feels like it wants to stall when its idling and i just barely tap the gas.. the power feels like it wants to cut. any idea as to what this can be? I posted a video below, but it doesnt do any justice.. u need to be there to see it. |
#2 |
Mod
Oh please, that's nothing
Mine goes under 500 sometimes
Follow my cross country drive to Bimmerfest West 2013
http://forum.e46fanatics.com/showthread.php?t=987217 ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
#3 |
I am just wondering why it slows down when its going back to normal rev idle when i rev it up... also, why does it feel like its gonna stall when i just barely touch the gas in idle? anybody have any ideas?
#4 |
Mod
Next time I go for a drive I'll show you my needle (no pun intended)
#5 |
haha no problem.. i think i may just need to check the intake rubber boot.. it still feels abit weird.. maybe im just too seeing things as this is my first bmw..
#6 |
Whats the problem?
#7 |
the problem is when i rev it, it feels like at 1500 rpm it stops and then drops slowly... and when its in neutral (car is manual) and i give it just abit of gas, it feels as if it wants to stall and turn off
#8 |
Platinum Plus Quality
If anything, clean your ICV. but other than that, your idle fluctuation is perfectly normal. When you let your foot off the gas, the engine speed will obviously go down. The computer senses the dip in idle speed and adds fuel to stablize the idle. It's working exactly as intended. Stop worrying and enjoy your car. Trust me, you'll have real problems to ask us about down the road.
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#9 | |
___________________ |
#10 |
I have post same vids for my car has the same prob exactly, plus it can be happen when turn the AC off ( it will dip to 500 ).
every body said that this normal. but in my openion this is not normal at all. there is somthing wrong. it wasnt like that before right? so how it's normal?!! Maybe it's not big problem, but it's not normal too. I didnt have time to chech my ICV, but I have checked for vacum leak, found nothing. Please update us if find the cause or the selution of this. Thanks,
![]() Last edited by maxi; 11-06-2010 at 05:43 AM. |
#11 | |
![]() Just when I thought nobody is really so stupid like people from Jersey Shore... |
#12 | |
Your 100% right pal, that's not normal at all. I know because my current e46 works perfectly and doesn't give a **** about it if I turn AC on or off, there's not even a slight change in engine operation nor fluctuating idle or such. But my previous car did exactly what you described. The first person who ever solves fluctuating/rough idle and roughing with AC on or when the whether is high will be celebrated as a ****ing hero.
#13 |
huh mine idles at 700ish, I have no idea why though =/ yours is perfectly fine
#14 |
Stay stock my friends!
OP...your little dip might be a very early...very early indicator of icv with a little dirt on it. Nothing serious...looks like to me anyway.
But, when it starts surging up and down...then search 'idle surge'--there's a massive thread on it...some had mixed results...I posted after I took a trip to throttle body myself and fixed my issue. Don't know when I did that trip...but been idling steady at 700 since...cleaned everything in my path and have written about it a lot...evidently too much...so I'll just let you search! Doug
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#15 |
thanks guys, im going to get my ICV cleaned and hopefully solves the minor problem!
#16 | |
You up on all other maintenance? filters, plugs, fluid changes, etc? Just saying...I love recommending maintenance...and use SolidJake's vid for icv...the hot bikini babes really make it worthwhile viewing in any case! Doug
#17 |
Hey,
Yup, did every fluid change possible on the car and spark plugs! I have an AEM filter for more air flow (removed the stock air box)... questions, where is that video your talking about and im a noob to this other question, when people refer to "vacuum leak" is that where the intake boot (hose) is? |
#18 |
Jake linked the vid in the other icv thread you'll find right next to yours.
The lower intake boot, if cracked, causes unmetered air to enter engine and the car doesn't know where it came from, coz the maf (mass air flow sensor) didn't register it, so it will add extra fuel to compensate and you'll run lean...at some point, this may trigger 02 sensors who see lots of unburnt fuel, coz mixture was bad...and you'll get the CEL...and if unattended, will end up shortening the life of your cat. There are a number of vac lines around...one runs the instant mpg gauge in your car, others work in the emissions control system...and I'm sure there are others too...but don't quiz me...would be guessing even more! LOL Oh...this air filter you have...is it an oiled kind? If so...don't seem to like all the stories we hear about them messing up the MAF...so clean that. And finally, since we had a guy blowing up his intake manifold...after you clean the icv (remove to clean!) let it dry thoroughly before starting the car...and don't spray TB cleaner into TB...either just wipe with a rag with cleaner on it (parts or TB cleaner) or remove it and spray it well. Assuming you didn't plan to do TB...I think I'd prolly leave it on...or search for whether guys seal it with touch of rtv. You want all that stuff on intake side sealed...and that might be the vac leak you're talking about...air can suck into through the disa, I know (again, unmetered air) coz there is a vacuum inside engine...slight, but enough to suck in air...so get things sealed up well is all I can say. If you can, pull things off and replace rubber behind...if you have a car that drives to go and get what you need from dealer...which may or may not have these things...suspect they prolly use rtv...but don't know if they'd use anything at all. Doug
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax Last edited by dmax; 11-07-2010 at 06:01 PM. |
#19 | |
This forum would be nothing without you
#20 | |
Anyway...I'm just a current messenger and there are many of us...never enough...but many...and most know far more than me about lots. But, I'll take credit for typing quickly and writing as thoroughly as I can...much to the dismay of many! Anyway...will take that as your appreciation for fanatics....the forum, the people, and the search feature! LOL Doug
