Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 11-07-2010, 02:43 PM   #1
InDiGlOM3
My Ride: HPF M3 stg 2.5
TMS E46 M3 solid differential mounts
Does anyone have these? Im looking to upgrade mine because the front mount is starting to fail. My main concern is if I get these solid mounts will I have added noise in the cab? or does the subframe bushings block the noise still?
Old 11-07-2010, 04:24 PM   #2
FTWeisse
My Ride: has no hip-hop rimz
I would just get OEM bushings again. Think how much abuse those bushings take especially with the power you make. All the energy your bushings absorb is going to be turned into vibration and noise. If it was a track-only car it would be one thing - but I'd never use solid bushings on a street car.
Old 11-07-2010, 10:20 PM   #3
Blocked Out
My Ride: Imola 330i M-Sport
Frame that statement.
Original BMW Teile ///
====>>> E46 Coupe Airbags
IMG_1725
Old 11-07-2010, 10:42 PM   #4
TrippinBimmer
My Ride: ZHP Custom Stage 3.5
PowerFlex 90A Bushing FTW!
Old 11-08-2010, 09:18 AM   #5
ryanwhite74115
My Ride: 2011 Hyundai Sonata
Powerflex from Bimmerworld.
(\ /) or \(`–' )/
c('')('')
ryanwhite74115 is online now   Reply With Quote
Old 11-08-2010, 11:58 AM   #6
InDiGlOM3
Powerflex makes a e46 m3 "DIff" bushing kit?? I couldnt find anything from them.
Old 11-08-2010, 12:06 PM   #7
TrippinBimmer
Oh snap...overlooked it as for subframe
-TrippinBimmer
Old 11-08-2010, 02:04 PM   #8
ryanwhite74115
Call up turner or bimmerworld...see what they are using????
(\ /) or \(`–' )/
c('')('')
Old 11-08-2010, 02:35 PM   #9
FTWeisse
That's the mistake everyone keeps making - everyone thinks you're talking about your subframe.
Food for thought - I'm not sure what Turner and Bimmerworld run, but I know of at least one team who runs alongside them in Grand-Am that uses only rubber bushings on their BMW racecar. I, too, only use rubber bushings on my racecar with the exception of billet aluminum/delrin combo subframe bushings.
If racecars can get away just fine with rubber, it shows you that street cars really don't need any solid or polyurethane bushings. If I was going to upgrade any bushings in my street car to "solid," it would be the subframe bushings - and I'd replace them with the billet aluminum/delrin combos - just like my racecar. Everything else would be kept rubber - especially the "moving" bits like FCABS, RTABS, and Differential bushings.
I just don't see the advantage of polyurethane. I've had them and I didn't notice any discernible difference.
Ultimately, the call is yours, but I honestly don't see the benefit.
Just my opinion, though.
Good luck
Old 11-08-2010, 05:36 PM   #10
InDiGlOM3
Good luck
Its not really for the feeling or a notice in performance, just a wont go bad ever type of thing. My factory bushing, the center part got ripped free from the rubber.....so whats to say that wont happen again, the bushings isnt rotted at all so not sure why it happened. But I ordered the solid ones because Ive talked to a few others that say they dont hear it as long as the subframe bushings themselves arnt solid or delrin and they have the interior still in.
