E46 Xi Forum
Old 09-10-2010, 07:50 AM   #1
pcdsl
My Ride: 2002 330xi
XI Control Arms Question
Hey Guys,
Could you guys help me confirm that these fit on the XI? They are listed as the performance kit. I was at the dealer and they told me these will fit. I always thought the XI only had one option and was with the original ones. But I checked on RealOEM and these are listed at working with all E46's
Part: 31120429578
http://www.realoem.com/bmw/showparts...=31&fg=95&hl=1
Thanks!
pcdsl is offline   Reply With Quote
Old 09-10-2010, 07:58 AM   #2
wdeerfield
wdeerfield's Avatar
My Ride: 2009 328i xdrive
will not work. youll have to go with the original ones.. TMS has a good deal on a whole kit for fcabs, ball joints, and control arms.
2009 MBM | ZPP | ZSP | ZCW | CA | 6FL | NAV | XENONS | 18x8.5 VB3s ET30/25
wdeerfield is offline   Reply With Quote
Old 09-10-2010, 08:21 AM   #3
pcdsl
My Ride: 2002 330xi
okay thanks, that's what I figured
Old 09-10-2010, 08:39 AM   #4
shanneba
My Ride: 2003 330Ci
Better to confirm --- it looks like they DO fit an Xi model, only if it has the Sports Suspension.
I used the part number you provided and did a "PART NR APPLICATION SEARCH" search on RealOEM.com and it shows it fits these models:
Part Cross-reference
RealOEM.com Home
Language:
Part 31120429578 (Retrofit kit, A-arm) was found on the following vehicles:
E46: Details on E46
E46 320i Sedan
E46 323Ci Coupe
E46 323Ci Convertible
E46 323i Sedan
E46 325Ci Coupe
E46 325Ci Convertible
E46 325i Sedan
E46 325xi Sedan
E46 328Ci Coupe
E46 328i Sedan
E46 330Ci Convertible
E46 330Ci Coupe
E46 330i Sedan
E46 330xi Sedan
E46 M3 Coupe
E46 M3 Convertible
It shows these 325Xi models (based on VIN:
E46 325i Sedan, M54 (AV33) : Retrofit kit, A-arm
E46 325i Sedan, M54 (AN37) : Retrofit kit, A-arm
and these 330Xi:
E46 330xi Sedan, M54 (EW53) : Retrofit kit, A-arm
E46 330xi Sedan, M54 (ES53) : Retrofit kit, A-arm
These are listed as models with the "Sport Suspension"
If your VIN is different then NO.
Join BMWCCA
Old 09-10-2010, 08:42 AM   #5
ChasCan
My Ride: 2001 330xi
AutoPart International sells the proper control arms for an xi, if yor happen to have one of their parts stores around you. Chas
ChasCan is offline   Reply With Quote
Old 09-10-2010, 08:45 AM   #6
pcdsl
My Ride: 2002 330xi
I'll see if I could e-mail from one from BMW directly to confirm... it's kind of confusing.
Old 09-10-2010, 08:48 AM   #7
winston330xi
My Ride: 2001 bmw 330xi
I dont think that will fit as the xi's use separate inner ball joints. It would be nice to have lighter aluminum control arms compared to the heavy arms stock to the xi.
winston330xi is online now   Reply With Quote
Old 09-10-2010, 08:54 AM   #8
shanneba
My Ride: 2003 330Ci
If you don't know if you have the sports suspension, look at your control arms and see how the ball joint looks at the "bend".
Compare the pictures on Turner Motorsports to see which ball joint type you have.
The AN3 VIN indicates a 325 model built in South Africa ..... they might be different
I don't have the VIN info for AV3, EW5 and ES5 in my spreadsheet.
Join BMWCCA
Old 09-10-2010, 10:04 AM   #9
MileHiXi
Banned
My Ride: '02 330xi
XI's with sports package never came with a sport suspension.
XI's have a completely different front subframe and the only CA's that are going to work are the ones that came on the car in the first place. They consist of a separate inner ball joint that won't be compatible with the ZHP arms.
MileHiXi is offline   Reply With Quote
Old 10-14-2010, 01:51 PM   #10
ECSTuning
ECSTuning's Avatar
My Ride: BMW
We have developed kits to help aid in the refreshing of E46 Xi's key suspension components.
Our kit has been specifically assembled by us to include the common wear items on your E46 BMW.
Change the way your E46 feels & while saving money over the BMW dealer.
This E46 suspension rebuild kit includes the following:
* Left control arm assembly
* Right control arm assembly
* Upgraded control arm bushing
Best,
Joe
800.924.5172
Old 10-26-2010, 06:43 PM   #11
rew7602
My Ride: 04 330xi
The arms first listed in the beginning of the thread to not fit. I have looked at them and they appear to be zhp arms or at least they are aluminum which I beleive is why they are saying they are performance arms. I ran into the same thing looking at the ETK one day. excitement turned to sadness when I saw what they actually were...
rew7602 is offline   Reply With Quote
Old 11-09-2010, 11:19 AM   #12
SILVRRONIN
My Ride: 2003 325.xit
FPGroton has amuch better deal! cheaper, lifetime garunte and screw those stock bushings!...they are crrap!...spend $60 for powerflex!.....
SILVRRONIN is offline   Reply With Quote
Old 11-09-2010, 11:20 AM   #13
SILVRRONIN
Meyle or even Liemfroeden are good too!
