Old 11-12-2010, 06:43 AM   #1
carguy61
My Ride: 2001 330CI
Backup camera
I saw a backup camera that replaces a license plate light on Ebay. Has anyone used one?
carguy61 is offline   Reply With Quote
Old 11-12-2010, 07:24 AM   #2
relentlessone
My Ride: '03 BMW 530i
Send a message via AIM to relentlessone
I have one of these. Make sure you get the shallow one, the tall one will not fit our cars even though the sellers claim they do. Even the shallow one requires slight modification to fit, but fits well once complete. I'll post a pic later when I'm on my computer.
relentlessone is offline   Reply With Quote
Old 11-12-2010, 07:57 AM   #3
Jmanscotch
My Ride: makes my pants tight
Carguy - I have one of the shallow ones (that Relentlessone noted is needed) I purchased off ebay but never got around to installing. PM me and I'll send it your way.
-Jake
2004 325CI - 2003 3.0 Z4 - 1994 325i - 1967 1602 - 2008 328XI - 2009 135i - 2007 Jeep Wrangler - 2014 *Loading*
Jmanscotch is offline   Reply With Quote
Old 11-12-2010, 08:11 AM   #4
BoogetyBoogety
My Ride: 2010 SL550
I have to say, I always thought backup cameras were gimmicky and useless... until we got the R-Class with one... and then the Odyssey Touring... and now, I'm a huge fan. Miss it in our other cars without one...
BoogetyBoogety is offline   Reply With Quote
Old 11-12-2010, 09:02 AM   #5
TRBOVNM
My Ride: 04 330 CI/04 Cobra
Send a message via AIM to TRBOVNM
check out the ICE forum as well. some good info and pics in there.
TRBOVNM is offline   Reply With Quote
Old 11-12-2010, 09:20 AM   #6
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
As you can see, it's almost invisible
Close up
Timeless Motor Group
Old 11-12-2010, 09:49 AM   #7
mal1110
My Ride: 2001 325i
nice chase!
mal1110 is offline   Reply With Quote
Old 11-12-2010, 10:18 AM   #8
relentlessone
This is the one I got:
Hey Chase did you have to modify yours to fit at all? I had to grind down the tabs that hold it in place to fit over the thick plastic, and then cut part of the trunk handle where the camera mounts.
Old 11-12-2010, 10:21 AM   #9
2000_328CI
2000_328CI's Avatar
Yep, had to dremel is a good bit to get it to fit. Was a bit of a pain but well worth it. The only issue I have had is that it didn't fit super snug so there is a little big of room for water and other cr@p to get in there... giong to have to figure out how to create a seal around it.
Old 11-12-2010, 10:32 AM   #10
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Translucent bathroom silicone sealant.
GoingNuts is offline   Reply With Quote
Old 11-12-2010, 10:40 AM   #11
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
is that tiny replacement light bright enough for the plates? or will it look bright on one side (where the original light is) and dim on the side where the camera and replacement light is?
delmarco is offline   Reply With Quote
Old 11-12-2010, 10:49 AM   #12
autothug
My Ride: MB sprinter, E92
Send a message via AIM to autothug
^^^good question and is there a way to record (which will be cool) or are people just using it to back up (which is why its called a backup cam)
autothug is offline   Reply With Quote
Old 11-12-2010, 10:54 AM   #13
delmarco
why would u want to record the pavement behind your car as it is reversing.
Old 11-12-2010, 10:56 AM   #14
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Yes, there is a way to record. See recording in post #6.
Old 11-12-2010, 11:35 AM   #15
2000_328CI
2000_328CI's Avatar
Great suggestion
Good question.
The LED in the backup camera side is about as bright as the OEM halogen in the other side... and they look about the same color and intensity.
I was running a hyperwhite led in both housings prior to the backup camera but, for some reason, the LEDs started acting up and i just replaced it with a cheap halogen.
LED hyperwhite license plate bulbs are FTW but I would rather have camera and slightly less sexy license plate lights.
This. I suppose people may want to have the reverse camera on while driving and maybe record idiots tailing them or something... but this seems stupid.
Old 11-12-2010, 11:42 AM   #16
autothug
I would not say its stupid chase. we are always trying to get more out of something simple. I would like to have recordings of like a caravan to a meet, etc.
Old 11-12-2010, 11:43 AM   #17
relentlessone
OK good, just wanted to make sure I didn't do anything unnecessary. Yeah I have a gap between the camera and trunk handle. I think I might stick a piece of foam weatherstripping in there to block any water. The back of the camera is sealed, but it would still be possible for water to reach the license plate light connection. I'm just going to avoid spraying it directly with the pressure washer.
Only problem with the silicone is that it's not really convenient to remove the camera. Not that you really need to remove it, but just in case. I'm going to experiment with some foam weatherstripping.
I'd say it's of equal brightness to the stock light, but a shade or two whiter. I think there are three LEDs in there. Doesn't bother me enough to change it.
Old 11-12-2010, 11:56 AM   #18
Stuttgart330
My Ride: 05 330CIC ZHP
I've got one that is in place of the keyhole. Works good, but I like the one 2000_328Ci has..Like the distance lines in it and you get to keep the keyhole.
2005 330CiC ZHP Hellrot - (mine)
2006 F350 Diesel CC - (Toy Hauler)
2009 528i Spacegrau Metallic - (wifes)
Stuttgart330 is offline   Reply With Quote
Old 11-12-2010, 02:10 PM   #19
jonesro
My Ride: 2003 330cic
can you get these to work with oem nav.?
jonesro is offline   Reply With Quote
Old 11-12-2010, 02:34 PM   #20
mal1110
My Ride: 2001 325i
I want to get one if itll work with oem nav but i have the 4:3 screen
