Sponsored by BimmerWorld
Old 09-03-2008, 05:47 PM   #1
Paul Reinsmith
My Ride: 2002 E46
Brake Pad Warning after 27k miles
My girlfriend has a 2005 325XI and last weekend her brake pad warning light came on. She, although not a great driver, does not drive hard and has never put the car on a track. This seemed early to need pad replacement. Does anyone have insight if this is normal at this mileage level or year?
Paul Reinsmith is offline   Reply With Quote
Old 09-03-2008, 05:49 PM   #2
Colemanator02
My Ride: 2002 E46
27,000?
Colemanator02 is offline   Reply With Quote
Old 09-03-2008, 05:50 PM   #3
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
could be a sensor failure. only way to be sure is to get in there and check the brake pads.
BTW, moving this to the Brake forum, you will likely get better answers there welcome!
-Brendan
Old 09-03-2008, 05:50 PM   #4
keith_m3-4
My Ride: 02 325iT
This does seem ealry.. it's easy to check.. look through the spokes on the wheels and see how much of the pad is left.. maybe she rides the brakes a lot? If it's still very thick then perhaps the wear sensor wire broke thus triggering light.
02 Steel Gray VF ZSP 325iT
keith_m3-4 is offline   Reply With Quote
Old 09-03-2008, 05:51 PM   #5
TopasBlau46
My Ride: 2001 E46 325ci ZSP
Seeing as I believe these should be replaced at Inspection I (30,000) and Inspection II (60,000), and she is close to 30,000, I would say it is normal. She probably wore them out quicker than "normal" though, I'm not familiar with BMWs warranties though I would imagine they are covered.
TopasBlau46 is offline   Reply With Quote
Old 09-03-2008, 05:52 PM   #6
Colemanator02
My Ride: 2002 E46
Brakes are not covered
Old 09-03-2008, 05:55 PM   #7
keith_m3-4
My Ride: 02 325iT
Brakes are covered under maintainance plan.
Old 09-03-2008, 06:59 PM   #8
TrippinBimmer
My Ride: Just Fast!
x2....
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 09-04-2008, 03:29 PM   #9
Chris-TK
My Ride: Mk VI GTI
Could either be that she does need new brakes, or that the sensors are worn. Best way to check is to take a wheel off and check the pads and the front left and rear right sensors.
K.
Chris-TK is offline   Reply With Quote
Old 09-04-2008, 05:58 PM   #10
keith_m3-4
My Ride: 02 325iT
Sensors don't wear, they are either tripped or not.
Old 09-05-2008, 02:10 AM   #11
Chris-TK
My Ride: Mk VI GTI
Didn't mean worn, I mean faulty or tripped. My bad.
K.
Old 09-05-2008, 04:12 AM   #12
Gts
My Ride: E46 316i
I have ATE Power Disc on the front and Textar brake pads and the pads are worn after 16000 km
Is it because of the discs or is it Textar too soft ?
Power is nothing wihtout control so I bought a new accelerator cable
Gts is offline   Reply With Quote
Old 11-08-2010, 04:23 PM   #13
tfoxsf
My Ride: 2003 325i
My brakes just bit the dust after 25K miles. OEM rotors and pads. Not that surprised as I drive up and down steep San Francisco streets every day. I confirmed it was not a faulty sensor (in my case) and indeed the pads were less than 3mm.
tfoxsf is offline   Reply With Quote
Old 11-12-2010, 06:10 PM   #14
starkfu
My Ride: '05 M3 SMG
I had the issue where there was too much slack in the sensor wire and the wheel rubbed through it - replaced sensor and all was good.
starkfu is offline   Reply With Quote
Old 11-12-2010, 06:13 PM   #15
Chris-TK
My Ride: Mk VI GTI
Cool story.
K.
