Bavarian Soundwerks' Mobile Electronics Forum
Have all your A/V and electronics questions answered here. Ipods, A/V, Radar Detectors Oh My! Sponsored by Bavarian Soundwerks |
Rating:
Display Modes |
#61 |
I hope this will help someone in the future. I was able to get everything working. My issue was the first line in the SYS.TXT:
app="StorageCard/iGO Primo" I didn't need it. I had tried to delete the SYS.TXT file in testing but I was getting different errors and the whole process was getting confusing to keep track of what I tried and what I didn't. I can confirm that formatting my SD Card in a MAC was and is not an issue. Thanks to all on this board (especially Darko) for their help. |
#62 | |
The white screen with the three options is the Windows CE interface, so that's also part of the firmware. Think of this screen as your "Windows Desktop". If you go into settings, you can set the navigation program to automatically start when you hit the NAV button. In that respect, hitting the NAV button is like double clicking on an icon and starting iGO Primo. Sometimes you might not see this screen because iGO is started automatically and it'll already be at the iGO loading screen. The custom loading screen is only for when iGO Primo is loading. It is purely software and has no relation to the firmware side of the headunit. |
#63 |
DK Jack Sparrow
My Ride: 328Ci | Range Rover
For primo, can someone suggest a good green sports car?
![]() Everything you need to know on muffler deletes : http://forum.e46fanatics.com/showthread.php?t=745244 Back Up Camera for E46 : http://www.youtube.com/watch?feature...&v=ckrDiAClGgM Muffler Delete on E46 : https://www.youtube.com/watch?v=ofYhRq0T3eI ![]() |
#64 | |
#65 |
#66 |
where?
~Lu
Transmitido en espaņol por SAP ![]() |
#67 |
Press the NAVI button at the bottom right of the Dynavin, then choose Setup/Navigate Setup, then check to start automatically
#68 | |
#69 |
I'm having a bit of an issue with the sound dropping out while in navigation mute. I get short audio drop outs when the voice directions or other navigation beeps and audio would normally be. This is when I have the audio muted in the main screen on the little speaker icon in the diMkaWA skin.
Below is how my sys.txt is written. [sound] ding=0 pause_mp3_sooner=1 queue_length=200 mute_os_key=1 maneuver_chimes=0 sound_muted=1 voice_muted=0 wheelsound=1 dynamic_volume_type=0 [tts] tts_buffer=131072 announce_exit_directions=1 tts_logics=3 priority="HIGH" always_say_road_name=1 announce_street_name=1 skip_exit_numbers=0 Thoughts? Last edited by 440films; 11-15-2010 at 09:09 PM. |
#70 |
Primo TTS Nuance Voices
A member recently requested a write up of getting TTS (Text To Speech, which pronounce street names during navigation) voices working on Primo 1.1.
There are two different types of TTS voices for Primo, one is Loquendo and the other is Nuance. I prefer the Nuance TTS voices since they sound more natural and consume less memory which is good since the Dynavin unit has only 64MB of memory. Firstly you need to download the Nuance TTS voices, there are three different English voices available (I personally prefer the Great Britain, Holly voice)......... Australian - Karen Great Britain - Holly US - Samantha Download Australian - Karen (Nuance TTS_AU.zip) and Great Britain - Holly (Nuance TTS_UK.zip) here....... http://fixmygps.net/forum/showthread.php?tid=1244 And download US - Samantha (MobileNavigatorTTSNuance-English.rar) here (password to open this downloaded file = MOBILEPASSION.ORG) http://www.fileserve.com/file/XRgyQ3...ce-English.rar Once you've downloaded the files you need to extract them to a folder on your computer using Winrar or Winzip. Now you can copy the files to your Primo folder, so for instance using Karen AU as an example, the following folder and file structure should be like this (folders are in bold text)......... Primo\ vautov5.dll Primo\tts_nua_v5\common\speech\components\ pp.dat Primo\tts_nua_v5\ena\speech\components\ apdb_Karen_NNG.dat apdb-cs_Karen_NNG_f22.dat depes_ena.dat depes_ena_Karen.dat phonmap_ena_Karen.dat sapi5_conv_ena.dat synth_Karen_dri40_vssq5_f22.dat sysdct_ena_cfg2.dat tokentn_ena.dat uselect_Karen_dri40.dat Primo\tts_nua_v5\ena\speech\vautov5\ vauto_pipeline_ena_karen_22_dri40_vssq5f22.hdr vauto_sapi5_phonmap_ena.hdr Primo\Content\Voice\ Voice_TTS-nua-Eng-au-Karen V1.1.zip That's it, now you just choose the TTS voice you want in the Primo settings. Note that when you choose a TTS voice the confirmation test sound takes a little longer than the regular non TTS voices. On a side note, for a bit of fun and to impress your friends, (or make them think you're a complete knob) you can edit the Nuance TTS voice to say your name when you are over the speed limit. Go to your main Primo folder then go to the content\voice folder Then double click on one of the Nuance TTS voice .zip files, I use Winrar to edit .zip or .rar files which I find better and easier than Winzip, when you double click on a zip or rar file with Winrar you're not actually extracting the file (which you don't want to do here), you're just opening it to edit it. Now that you've opened the Nuance TTS voice zip file (I'm using UK Holly here as an example) you should have this screen...... ![]() Now Open the info.ini file by double clicking on it and you will have this....... ![]() I've shown an arrow next to the line that you can edit so the voice will say your name when you are speeding, of course you can type whatever you want in there but keep it short otherwise it may have problems. So play around with it and see what works, when your finished editing you then need to save the file by choosing File at the top left and then choose Save. You'll then get a small dialoge box pop up asking if you want to update the archive, choose Yes. Note that the only downside with TTS voices is that for whatever reason they are not as loud as the regular voices, I found this entry that you can copy into your Primo sys.txt file which increases the voice volume although I haven't tried it myself yet so I can't confirm whether it hepls or not so give it a shot and see if it helps and if it doesn't then just delete it from your sys.txt file. **EDIT - I can confirm that it certainly does increase the TTS voice volume quite a bit ** [dynamiccompressor] compressor=1 a0=56806 thrs=24703 ratio=8 gain=12 And that's about it, I've tried to make it a clear and easy step by step 'cause we know some of you are slightly um 'challenged' with this sort of thing ![]() Have fun.
![]() Last edited by Darkoz; 11-16-2010 at 06:36 AM. |
#71 |
Awesome. Thanks Darko.
#72 |
Also, since I just searched and looked through 25 pages of another thread, here is the link I found for the Primo manual. I haven't tried downloading, so hopefully it is still there. I will try when I get home and in the future if the link doesn't work, someone could pm me and I should be able to email or put it on photobucket or something to be downloaded.
http://uploaded.to/file/llbc52 |
#73 | ||
I currently have the WinCE Patch running with the stock iGo 8. But when I swap mem chips with the Primo it wont run because of the resolution. . Last edited by Flybot; 11-16-2010 at 11:32 AM. |
#74 | |
~Lu
#75 | |
#76 | |
Thanks very much for this! Very clear and with pictures! ![]() John
![]() 2001 M3 Convertible, Carbon Black - Daily Driver 2007 328i Convertible, Atlantic Blue - Wife's car 2003 X5 4.4i - Grocery-getter |
#77 |
Darko,
I ended up getting the Primo from Chase and it works much better than the one I tried putting together. There must have been a file or something missing in what I downloaded. I looked at the sys.text file and it has the dynamiccompressor section in there, but not as much info. He did have some TTS stuff in the program, but it never worked he said and I never tried it. Here is what he has in it [dynamiccompressor] compressor=1 ratio=9 gain=9 I was just going to replace it with what you included in your post above. That is corrrect right? I do have a backup of what I got from Chase. I am changing a copy of it. |
#78 | |
You'll then need to experiment with the master and navigation voice volume settings in Primo to a level that suits you.
#79 | |
You can download it here, assuming you're not a member of this file hosting site so choose slow download (this is for Primo v1.1 only)......... http://www.rapidshare.com/#!download...1115.rar|40516 Just copy the data.zip file to your main Primo folder replacing the existing one.
#80 |
I acquired a copy of Primo earlier, but I think it's a generic one as the sys.txt is, well, empty pretty much.
[device] type="navon_N480" That's it! Assuming what I have is a basic (no frills) version, what is the simplest sys.txt I can get away with for a Dynavin e46? Thanks. |
