Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 267 votes, 5.00 average. Display Modes
Old 11-17-2010, 03:16 PM   #81
Flybot
My Ride: E39 528
Originally Posted by Darkoz View Post
Just copy the data.zip file to your main Primo folder replacing the existing one.
Got it working. Thanks for the help. It turns out it was a bad Loading.bmp file (not 800x480). I replaced it with a 800x480 and all is good. Chase provided me with the file fix.
Flybot is offline   Reply With Quote
Old 11-17-2010, 04:03 PM   #82
Darkoz
My Ride: E46 325Ci
Originally Posted by thejames View Post
I acquired a copy of Primo earlier, but I think it's a generic one as the sys.txt is, well, empty pretty much.
[device]
type="navon_N480"
That's it!
Assuming what I have is a basic (no frills) version, what is the simplest sys.txt I can get away with for a Dynavin e46?
Thanks.
The simplest sys.txt you can get away with is not having one, Primo works fine without one at all as all these sys.txt you see floating around are made up by other people.
Darkoz is offline   Reply With Quote
Old 11-17-2010, 04:10 PM   #83
thejames
My Ride: e46 330ci Coupe Auto
Darkoz: Thanks
thejames is offline   Reply With Quote
Old 11-18-2010, 10:33 AM   #84
440films
My Ride: 2005 X5 4.4
Originally Posted by 440films View Post
After muting all sounds except Master and Voice Commands it seems to happen when the entering the freeway and when the different Exits appear on screen as well as when other navigation TTS directions would normally be.
I anyone else getting this issue?
440films is offline   Reply With Quote
Old 11-18-2010, 03:52 PM   #85
Darkoz
My Ride: E46 325Ci
I'm not really sure I understand what issue you're having, can you explain clearly what it is.
Old 11-18-2010, 04:14 PM   #86
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
From the Primo thread on the Dynavin forum (thanks to VasilisE):
Just put these lines in your Primo sys.txt
[sound]
ding=0
pause_mp3_sooner=1
queue_length=200
mute_os_key=1
maneuver_chimes=0
sound_muted=1;this one does the trick
voice_muted=0
wheelsound=1
dynamic_volume_type=0
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 11-18-2010, 05:01 PM   #87
440films
[sound]
ding=0
pause_mp3_sooner=1
queue_length=200
mute_os_key=1
maneuver_chimes=0
voice_muted=0
wheelsound=1
Thanks. Unfortunately that's already what I have. I think it's an issue with the Skin.
Old 11-18-2010, 07:52 PM   #88
440films
I am currently using the Dimka skin for Primo 1.1. I like it because it offers the look of iGo 8.3 but with some of the Primo advancements. When using turn by turn directions I usually turn the audio off. In this case by pressing the little speaker that is on the Map.
Although the Turn by Turn audio is muted whatever is playing in the background (iPod, Radio, etc) drops out periodically for about 2 seconds. Because of the Dynavin (V5) this happens in the front speakers only. I started to notice that the audio drops out when entering a freeway and when highway signs change from offramp to offramp. Every once in a while it drops out when navigation instructions would normally be if I hadn't muted them. This is my current sys.txt
[sound]
ding=0
pause_mp3_sooner=1
queue_length=200
mute_os_key=1
maneuver_chimes=0
sound_muted=1
voice_muted=0
wheelsound=1
[tts]
tts_buffer=131072
announce_exit_directions=1
tts_logics=3
priority="HIGH"
always_say_road_name=1
announce_street_name=1
skip_exit_numbers=0
Old 11-18-2010, 08:53 PM   #89
Darkoz
My Ride: E46 325Ci
Have you tried using one of the the default skins to see if it stil happens, if not then you know for sure that it's skin related.
Old 11-19-2010, 12:14 PM   #90
440films
I tried this morning. The Default Skin had no issues. But... the GJA v.2.20 skin did. The GJA skin dropped audio out of the front speakers every time (or turn) that voice commands would normally be announced had I not had the speaker button muted.
I know many of you are using the GJA skin. Is no one else having this issue?
Old 11-19-2010, 12:48 PM   #91
J&T Distributing
My Ride: BMW
hhhmmmm......thats the skin im using, it did what yours is doing when I first got it but changing those lines in the sys.txt that I mentioned earlier fixed it.....obviously something is different on yours...
Old 11-19-2010, 01:00 PM   #92
440films
Jeff, who's voice are you using? I'm currently using Holly.
Old 11-19-2010, 05:33 PM   #94
Flybot
My Ride: E39 528
Anybody have a link for a iGo Primo User Manual? Odd that you cant even get one on there web site.
Edit: Never mind. Found a link here: http://fixmygps.net/forum/showthread...d=9671#pid9671
The above link has most of the same stuff, but I still cant figure out what all the info is along the bottom edge of the screen, like "-DC-"
If anybody finds a better link Id be interested.
Old 11-19-2010, 06:12 PM   #95
Darkoz
My Ride: E46 325Ci
That's why I don't use any of these amateur homebrewed skins, too complicated, messy and too much potential for bugs.
Old 11-19-2010, 06:31 PM   #96
440films
What do you usually use?
Old 11-19-2010, 08:06 PM   #97
Darkoz
My Ride: E46 325Ci
The default skins work well for me so that's what I use.
Old 11-19-2010, 09:39 PM   #98
TRBOVNM
My Ride: 04 330 CI/04 Cobra
Send a message via AIM to TRBOVNM
I posted a link to one on the previous page of this thread I think and I posted it in another thread or two as well.
TRBOVNM is offline   Reply With Quote
Old 11-19-2010, 10:20 PM   #99
immigrant
My Ride: 2001 BMW 330CI
Send a message via MSN to immigrant
Hey is there any way to remove/hide the battery icon that shows up sometimes and also some of the extra stuff on the menu, like picture viewer and music player and a bunch of other stuff.
FS OEM BLAUPUNKT CD PLAYER (no mode)
FS 35W CANBUS BALLASTS (UMNITZA)
FS COMPLETE OEM LIGHTS: FRONT,CORNERS, REAR
FS PEAKE TOOL
FS 2001 LCM
P.M. me for anything you are interested.
immigrant is offline   Reply With Quote
Old 11-20-2010, 08:43 AM   #100
Flybot
My Ride: E39 528
Post #72, thanks. That has better graphics than my previous link.
