Pulleys - 4 rib vs 5 rib - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-26-2010, 01:48 PM   #1
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
I noticed that the cranks shaft pulley from my engine swap has 4 ribs while my AC condensor pulley has 5 ribs.
Would I be able to use an AC belt with 4 ribs because my crankshaft pulley only has 4?
I figure the best option is to make sure I have both 5 rib pulleys or 4.
Would my engine balance be thrown off if I used a 4 rib pulley?
phamine is offline   Reply With Quote
Old 11-26-2010, 04:19 PM   #2
paraklas
My Ride: ESS TS2 320ci
The change was somewhere between 2002, when I did my engine swap, the new engine (Oct. 2003) came with the 4-rib AC pulley, which I had to swap with the 5-rib from the old engine. Obviously it was impossible to run 5 rib belt on a 4 rib pulley, it destroyed the belt in no time. I think, running a 4-rib belt on a 5rib pulley will most likely throw the belt off.
Old 11-26-2010, 04:38 PM   #3
Kris.R
My Ride: 2012 Dodge Charger
4 rib for your pleasure.
5 rib for hers.
- Kris -
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-Abraham Lincoln-
Kris.R is offline   Reply With Quote
Old 11-26-2010, 05:14 PM   #4
McSpeed
My Ride: 2005 ZHP TT Stg 1
I don't know hwow much it matters but:
The 4 rib (newer )crank pulley/harmonic damper does have a label on it that describes a wider damping frequency range than the 5 rib (older one) one. Can't remember the numbers but they're in a recent ATI SuperDamper thread I think.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 11-26-2010, 05:55 PM   #5
Steven747
My Ride: 05 330ci
5 rib for hers.
Old 11-26-2010, 08:08 PM   #6
phamine
Thanks - I'll look to swap out the 5 rib AC pulley for a 4 rib one.
Old 11-27-2010, 09:52 AM   #7
paraklas
I have a 4-rib one if you want it I can check for shipping cause it's a bit heavy
