E46 Xi Forum
Old 12-16-2010, 11:39 AM   #1
dishrags
My Ride: 03 325xi
DSC lights are on
I just bought this damn car and there seems to be so many things going wrong!
I was just driving along on the highway today and the warning lamp, ABS, and Brake lights come on.
Is this something that's normal? The car is an 03 and has about 65k on it. I'm wondering now if I bought a lemon.
dishrags is offline   Reply With Quote
Old 12-16-2010, 12:38 PM   #2
infinite012
My Ride: White '08 STI
Return it.
infinite012 is offline   Reply With Quote
Old 12-16-2010, 12:39 PM   #3
SalM
My Ride: Shhh
Yes return it asap. I was reading a few months back same thing happened to this one guy and it leads to some really fvcked up ****.
SalMPhotography
SalM is offline   Reply With Quote
Old 12-16-2010, 12:48 PM   #4
dishrags
My Ride: 03 325xi
I tired to find some other threads on this (on this site) and didn't find too much. But some did say it could just be a sensor. - Thoughts?
It doesn't sound like this is a "normal" thing, so does that mean someone just really jacked up the car or did it just roll outta production with a few problems?
Old 12-16-2010, 12:50 PM   #5
SamDoe1
My Ride: 4cyl of fury
The thing is 7 or 8 years old now, there are things that are going to fail at this point. Just a fact of life.
As far as what's wrong, I would check wheel speed sensors and ABS sensors first before you dig more. Should be fairly easy to check by taking each wheel off and checking the sensor. If you just bought it then take it back to the dealership and tell them to fix it. If it was private party then better roll up your sleeves and get to work.
PS: http://www.bimmerfest.com/wiki/index...illuminated.3F
Read it, learn it, love it.
Old 12-16-2010, 12:54 PM   #6
Master Po
My Ride: E46 no more
There's no such thing as "roll out of production with a few problems". If it did, that was 7 years ago.
Why do you say it's normal to have a light on? The lights tell you that something needs attention. Maybe you're trying to ask "how deep in the hole am I?"
Only a mechanic can tell you for sure. Now if you want us to speculate... give us some more details. Like get a Peak tool and get the error codes.
Master Po is offline   Reply With Quote
Old 12-16-2010, 12:56 PM   #7
SalM
My Ride: Shhh
I forgot where I read it but He said it lead to some real fvcked up ****.
SalMPhotography
Old 12-16-2010, 01:08 PM   #8
Kubica
My Ride: 2003 325xi
Scan codes- probably a wheel speed sensor.
Old 12-16-2010, 01:08 PM   #9
dishrags
My Ride: 03 325xi
I know what the lights are for, I'm asking if these kinds of issues are from normal wear an tear.
Old 12-16-2010, 01:12 PM   #10
SKIPPY PB
My Ride: YZ125
Talk to a mech.
DSC w/ BRAKE light on means the system disabled itself because the car isnt caluclating right. Just be lucky you werent relying on the DSC for the LSD effect and has it go on mid turn like I did.
ABS is seperate, maybe its just fuses. Research or take it to a shop.
SKIPPY PB is offline   Reply With Quote
Old 12-16-2010, 01:15 PM   #11
dishrags
My Ride: 03 325xi
Thanks Sam. I suppose my fault though, I didn't do a pre inspection prior to buying the car. It was exactly what I wanted and there was only ONE other one in the NW for sale.
There are a few maintenance records and I'm just wondering now if all this is an on going problem that couldn't be fixed (why they got rid of the car).
Old 12-16-2010, 01:35 PM   #12
Ivanhoe
My Ride: BMW 330 xi 2005
Originally Posted by SKIPPY PB View Post
Talk to a mech.
+ 1, this is a start point
Ivanhoe is offline   Reply With Quote
Old 12-16-2010, 01:45 PM   #13
dishrags
My Ride: 03 325xi
Thanks everyone. I think I'm just freakin' out a bit.
Old 12-16-2010, 02:22 PM   #14
drumbum624
My Ride: 325xi
Send a message via AIM to drumbum624
I got in a pretty nasty accident last summer, my car was actually in park it was the craziest freak accident, but long story short my left rear wheel got hit with a tree. (will post the story another time)
ANYWAY: my left rear control arm was bent and this triggered the same lights that you are seeing. I think it had to do with what Kubica said which is the wheel speed sensor. Maybe go get an alinement done? that could give you some hints
drumbum624 is online now   Reply With Quote
Old 12-16-2010, 03:58 PM   #15
Master Po
We don't know what issues you have yet, do we?
Old 12-16-2010, 05:45 PM   #16
ChipDouglas27
My Ride: 2003 325xi
Send a message via Yahoo to ChipDouglas27
This may be unrelated, but I had a ABS light pop up on my VW about a year ago and it required a new ABS control. The VW part was about $800. Not certain if this is your issue or if this may be the price to fix it. You may be able to find a re-manufactured unit as well.
ChipDouglas27 is offline   Reply With Quote
Old 12-16-2010, 05:56 PM   #17
TrickTizzle
My Ride: 325i
Get the codes pulled. DSC + ABS work together.
They will both be disabled not one of the other.
Check power steering fluid and brake fluid levels.
Old 12-16-2010, 10:04 PM   #18
Gottalovethexi
Gottalovethexi's Avatar
My Ride: 03 xi & 72 Bav
i know that when i would unplug my battery when I used to show my car at indoor car shows, at the end of the day when I plugged it back in my abs/dsc/brake lights would go on but turn off after driving around afterwards...
doubt that helps tho lol
Old 12-16-2010, 10:30 PM   #19
Kubica
My Ride: 2003 325xi
+1.
Yeah mine does the same anytime I disconnect the battery. They turn out after I drive about ten feet.
OP- did the place you bought it from do any work on it before you bought it? Maybe new brakes, axle, bushings, etc.? If so, they probably chewed up one of the sensors.
For a problem like this you need to scan codes first and foremost though.
Old 12-17-2010, 10:14 AM   #20
pjo33us
My Ride: 03 330xi
+1... OP, you might try to disconnect the battery for half an hour and then reconnect. The DSC/ABS etc will be on when you start driving for a few miles at most if the system is normal. You might check all the fuses while you are at it but I doubt this is the issue.
If that does not clear it up, you have an issue in the system that is impossible to diagnose over the internet. You can either take it to the BMW dealer (I would not use an indy here unless you are sure they can read the BMW specific codes) or buy yourself a Peake tool and scan the codes (either way it is going to cost you the same).
Also, fair warning... you will do more maintenece on your BMW than most cars you have owned. Around 65k to 75k seems to be when a lot of it is needed too. More things are considered maintence items as well (colling system, control arms, VCG etc)... This is the price you pay for driving a sports car. Good news is that these cars are very easy to work on compared to most other modern cars.
pjo33us is offline   Reply With Quote
