Sponsored by BimmerWorld
Old 12-21-2010, 06:58 PM   #1
alpine003
My Ride: BMW
Exclamation WARNING: FK Coilover Owners....
Cliff Notes at the bottom.
I know a lot of us don't ever inspect rsm's on the regular basis unless your car is gutted most of the time or if you are making adjustments a lot.
I wanted to post a warning to FK owners to check their RSM's often as mine were shot in less than 1 year use and 7k miles of driving. I've never had rsm's go out as fast as these.
Note: this was a daily driver for the wife with no auto-x or DE days whatsoever.
I only discovered this because I was readjusting the dampening rates for the winter.
I discovered that one is barely hanging on to some rubber while the rubber bushing on the other side is completely torn off from the metal collar itself.
I've been told replacements are over a month away. The OTS(off the shelf) OEM units will not work with the FK's since it has a larger diameter piston size as I've discovered.
I've contacted ECS Tuning and a couple people were helpful but nothing they can do except recommend me to the head guy over there which I have yet to hear back from.
At this point, I can't recommend FK CO's to future owners if they don't want to worry about future RSM issues due to these points:
1. FK uses non standard rear shock piston diameters incompatible with OEM mounts
2. FK seems to use a harder rubber compound that is less compliant and flexible than OEM leading to premature wear
Not feeling so great in the fact that this is a daily driver that my wife uses to drive our 3 and 18month old around and we plan on doing some holiday traveling.
I'm hoping I can get some resolution before something happens and will update accordingly.
CLIFF's NOTES: FK owners, inspect your RSM's
alpine003 is offline   Reply With Quote
Old 12-21-2010, 07:10 PM   #2
RAFF112
My Ride: 325ci M3 cbr 600rr
Thats your RSM's fault not the coilovers.
VCSL Front 18/13 Spacers Full Borla V2 K&N drop-in w/custom tube LED Interior air horn BMW performance shift Knob Seibon Hood LED DRL Dynavin Depo corners RE rear camber arms and Vogtland Springs.
Originally Posted by hayabusa55 View Post
I used to think love exists. Turns out it's a manifestation of insecurities and boredom.
RAFF112 is offline   Reply With Quote
Old 12-21-2010, 07:11 PM   #3
alpine003
My Ride: BMW
These are FK RSM's that came with the FK Coilovers in the kit if you didn't know that.
I never said the CO's were faulty themselves.
Old 12-21-2010, 07:15 PM   #4
InLoveWithE46
My Ride: e46 non-M, e36 ///M
Send a message via AIM to InLoveWithE46
^^^ Oh that changes things. Just curious, but what set of coilovers did you get? I was contemplating getting FKs but want to make sure I can use my choice of RSM if this is the case. Sorry about the problems.
~Leslie~
~euro.techniks~
InLoveWithE46 is offline   Reply With Quote
Old 12-21-2010, 07:19 PM   #5
TheRusski
My Ride: gone...
You just got unlucky...hope everything resolves
TheRusski is offline   Reply With Quote
Old 12-21-2010, 07:20 PM   #6
alpine003
My Ride: BMW
I currently have the FK Sport Editions. I bought them about a year ago(at full retail :sad) so I'm not sure if the materials or manufacturing of the RSM's have changed since then.
Bottom Line: if you use FK Coilovers, you gotta use their RSM's which may or may not be available when you need them the most.
Old 12-21-2010, 07:26 PM   #7
InLoveWithE46
Ok, that I was unaware of. Damn.
~Leslie~
~euro.techniks~
Old 12-21-2010, 09:05 PM   #8
franz
My Ride: 03 330i
There are other large diameter RSM's I believe, perhaps Turner can help?
franz is offline   Reply With Quote
Old 12-22-2010, 03:09 AM   #9
AL330CI
My Ride: 330Ci
The Bilstein B16 Coilover (w/ Electronic Ride Control) also uses a larger diameter hole on the rear shock mount (12mm vs. 10mm). Turner sells a 12mm version.
AL330CI is offline   Reply With Quote
Old 12-22-2010, 01:21 PM   #10
alpine003
My Ride: BMW
Update: Did some digging and measured the FK's to be 12mm and as stated, the Bilstein B16 and some Koni's use the 12mm shafts too.
I found Turner Motorsports, Rogue Engineering, and AKG Motorsports to carry aftermarket 12mm RSM's.
Bottom Line: If you don't want to hassle with checking the condition of your FK RSM's every few months, expect to budget ~$100 extra for aftermarket 12mm RSM's in the purchase and be done with it.
Still haven't heard back from ECS Tuning with a resolution yet...
Old 12-22-2010, 01:45 PM   #11
franz
My Ride: 03 330i
What do you mean by resolution? Buy good aftermarket RSM's, I have the Turner ones in std diameter and they seem to be well made and working fine.
Old 12-22-2010, 02:51 PM   #12
alpine003
My Ride: BMW
FK CO's come with their own RSM's and their entire system has a Lifetime Warranty on them. Resolution meaning warranty claim.
Ideally when something has a lifetime warranty, one would expect replacement in a reasonable time period and one shouldn't need to buy other alternate parts to compensate. "Ideally"...
Old 12-22-2010, 03:00 PM   #13
TopazKD
My Ride: blue zombie
I bought fk highsports and then bought RE RSM's no complaints so far
"///M3 drivers have no friends!" -Jeremy Clarkson....
TopazKD is offline   Reply With Quote
Old 12-22-2010, 03:26 PM   #14
alpine003
My Ride: BMW
Picking up AKG units locally.
Old 12-22-2010, 03:34 PM   #15
M3Inline6
aka...Dark Snow
My Ride: '17 Nardo Grey M4
That is some serious deterioration.
Originally Posted by Qwel on "Manhattan Project"
You heard of me.....burgandy and outlines like murder scenes; Germany..took ferns and flat whites for blurring greens.
M3Inline6 is offline   Reply With Quote
Old 12-29-2010, 11:43 PM   #16
Blocked Out
My Ride: Imola 330i M-Sport
You can swap your old rear shocks in a matter or minutes, you dont even need to jack the car up, so you can go holiday traveling.
Then make whoever sold you this product pay for a replacement. Dont take no for an answer.
Original BMW Teile ///
Original BMW Parts for Sale - DISA, MAF, SAP, Coils, MS43 much more PM ME
IMG_1725
Old 12-30-2010, 12:53 AM   #17
FTWeisse
My Ride: has no hip-hop rimz
Has nothing to do with brand - has everything to do with setup and stiffness.
Old 01-05-2011, 11:28 PM   #18
alpine003
My Ride: BMW
I'm not sure what you mean by this but I do know the FK supplied RSM's are junk regardless of setup or stiffness.
Old 01-05-2011, 11:48 PM   #19
FTWeisse
Interesting - good call. I made the statement under the assumption the OP used OE bushings. Either way, RSMs of that design don't last long at all, especially with the additional load.
So, OP, what RSMs are you using?
Old 01-14-2011, 04:17 PM   #20
shogun
My Ride: 325I TOURING
yeah i have fk's but kept my z4/m3 rsm and my pss9 rear shock.
love wins.
shogun is offline   Reply With Quote
