Old 01-13-2011, 05:16 PM   #1
DBrown
My Ride: BMW 325 Ci
Simple question regarding valve cover gasket
I'm about to change my valve cover gasket. Ive read a few DIYs, but none of them say anything about draining the oil. Based on pictures I've seen I'm assuming that it needs to be drained, but a friend of mine claims that he did his valve cover and didn't need to drain the oil. I was wondering if I have to drain the oil or if I only need to drain around 1 or 2 liters (because I recently changed the oil approximately 900k ago).
If anyone also has any other sugestions about making this DIY a little easier then feel free to post. I'm already going to use high temp sealant for the areas prone to leaking.
DBrown is offline   Reply With Quote
Old 01-13-2011, 05:30 PM   #2
beef1020
My Ride: 00 323i
You don't need to drain the oil. When the engine is off all the oil drains down the engine into the pan, or most of it. So there is no spillage when you take the valve cover off.
beef1020 is offline   Reply With Quote
Old 01-13-2011, 05:33 PM   #3
blow me
My Ride: 04 Coupe
You don't need to drain any oil. Here is a DIY video that shows you step by step process. Hope it helps.
blow me is offline   Reply With Quote
Old 01-13-2011, 05:57 PM   #4
Jmanscotch
My Ride: makes my pants tight
You need to drain the oil...not for the VCG but because 900K even surpases BMWs "lifetime" recommendation
-Jake
2004 325CI - 2003 3.0 Z4 - 1994 325i - 1967 1602 - 2008 328XI - 2009 135i - 2007 Jeep Wrangler - 2014 *Loading*
Jmanscotch is offline   Reply With Quote
Old 01-13-2011, 06:18 PM   #5
grafiksguy
My Ride: 2010 328xi
grafiksguy is offline   Reply With Quote
Old 01-13-2011, 07:51 PM   #6
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
That's not so nice, you know. The OP is in Canada, so he probably means kilometers, so only 560K miles!
You don't need to change the oil, OP...we're assuming you mean 9,000 kilometers or miles...either way, you don't have to. But, if miles, then pretty soon. No one really knows when here...bmw knows it's around 15K miles, but most here kind of freak about going that long. Me? I'm probably going to do it soon...around 10-12K miles.
GL with vcg...stuff something around engine when you start removing the brittle gasket. Also, I'm sure you know to replace the grommets, and that many here also do Vanos (for that, you do get oil dripping down a bit, so have some covering over the belts if you do that.)
HTH
Doug
Upcoming comedy shows: Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 01-13-2011, 08:48 PM   #7
moiz21
My Ride: 1999 323i 5-SPD
Some good advice that was given to me is run the car for a while before doing the work. By the time ur rdy to remove the valve cover the temp will have dropped enough so it wont burn to the touch. But what this does is help make the vcg easier to remove and less likely to snap if it's turned into plastic.
Good luck
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 01-13-2011, 08:56 PM   #8
jdstrickland
My Ride: '94 325iC & '00 323i
You DO NOT need to drain _any_ oil to change the valve cover gasket.
Old 01-13-2011, 10:06 PM   #9
DBrown
My Ride: BMW 325 Ci
I mean 900 kilometers ago. Sorry forgot to put in the "m" (900km). Even if I can see the oil in my filler cap I don't need to drain it ?
Old 01-13-2011, 10:10 PM   #10
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Unless you've over filled your engine with so much oil that it is flowing out of the oil cap...don't need to drain any oil.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 01-13-2011, 10:13 PM   #11
BimmerFerret
My Ride: 08 G37S, 07 Sky RL
I just did my VCG and there is only a light coating of oil underneath the valve cover.
2008 Infiniti G37S - Big Brakes, Limited Slip, etc.
2007 Sky Redline
1998 Honda Civic EX Sedan
Originally Posted by Roxlo View Post
Class of '03, yet you're still an idiot. Whats your point? Do you really think that you're somehow a god because you joined a site before someone else? ****ing nerd.
BimmerFerret is offline   Reply With Quote
Old 01-14-2011, 12:18 AM   #12
beef1020
My Ride: 00 323i
VCG would be the least of his worries
Old 01-14-2011, 02:02 AM   #13
bigjae1976
bigjae1976's Avatar
So who's gonna be the first to say "class of 2010 fail"?
diy, oil level, problem, valve cover gasket
