Old 01-15-2011, 11:42 PM   #1
iwannagofast
My Ride: 01 330ci
Send a message via AIM to iwannagofast
calling solidjake or dmax
or any other of the diagnostic gurus on here..... i have a quik ? for all of you..... my car has developed a ticking noise... i thought it was a sticky lifter but i notice that when i engage the clutch the ticking goes away... as soon as i let off of the clutch the ticking slowly comes back.... throw out bearing? what do you guys think it is
thanks guys
xbox live: stopthisfall
iwannagofast is offline   Reply With Quote
Old 01-17-2011, 12:23 AM   #2
iwannagofast
My Ride: 01 330ci
Any1?
Sent from my PC36100 using BimmerApp
Old 01-17-2011, 12:31 AM   #3
e36-2.0
My Ride: 330xi
why not PM them...
'02 330xi
Konigsport/Ground Control/DPE/BMW Motorsport/Eurosport/Turner Motorsport/PowerFlex/RacingDynamics/Hotchkis/UUC/Beisan/Bimmerworld/Dinan/Conforti/RPI/GroupN/Technik/Dynavin
Alberta's BMW enthusiast forum.
-Projecttechnik.com
e36-2.0 is offline   Reply With Quote
Old 01-17-2011, 09:35 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Well unfortunately for you I do not have a manual car. It does seem like that can be the culprit. Much cheaper than changing the entire clutch kit. Post in the general E46 section and they will help you out.
Old 01-18-2011, 02:20 AM   #5
///M3Turk
My Ride: M6 ,X5, R6, M5, M3
Send a message via AIM to ///M3Turk Send a message via MSN to ///M3Turk
Firat
///M3Turk is offline   Reply With Quote
Old 01-18-2011, 02:56 AM   #6
iwannagofast
My Ride: 01 330ci
lol thanks... i always see u and doug in here helping people out so i figure i would ask
Old 01-18-2011, 04:09 AM   #7
TerraPhantm
My Ride: M3 & ZHP
Can you post a video of it? Most manual cars I've driven made some weird noises with the clutch engaged, but I can't say any of them sounded like a sticky lifter
Old 01-18-2011, 07:27 PM   #8
DontWriteGraff
My Ride: E36///M.TchnoHrdtop
Well unfortunately for us I do not have a manual car or a low one at that. It does seem like that can be the culprit. Much cheaper than changing the entire clutch kit. Post in the general E46 section and they will help you out.
fixed
DontWriteGraff is offline   Reply With Quote
Old 01-20-2011, 05:40 AM   #9
iwannagofast
My Ride: 01 330ci
ill try to go into my garage or something to see if my cell camera can pick it up. but its a ticking noise that speeds up with the rpm
Old 01-20-2011, 09:47 PM   #10
Blocked Out
My Ride: Imola 330i M-Sport
Your car is equipped with a dual mass flywheel. It will make ticking/chatter noise when at idle. Also let me guess, when you shut your car off and the clutch is not depressed, your car sounds like its falling apart, correct? and if you simply depress teh clutch while shutting the car off, no sound.
A
Am I right or wrong?
I dont usually play guessing games but I think I know the problem and I'd like to help you.
Original BMW Teile ///
IMG_1725
Old 01-20-2011, 10:07 PM   #11
iwannagofast
My Ride: 01 330ci
next time i get in my car ill check that out and report back.... i appreciate that btw. thanks for your help
