Old 01-31-2011, 06:53 PM   #1
Elwin
My Ride: 330i ZHP
My car works fine and has no problems. Is it normal?
Hi,
I have E46 330i ZHP 2004.12.
I checked everything on the car today and unfortunately every bit of the car works fine. There are no problems what so ever! Nothing is broken, nothing scratched. No weird engine or steering or transmission or fuel pump or exhaust noises. All electrical systems are fine. Car's ULF is working perfectly with my android phone. Voice commands are working, navigation is working. The car is clean. My CarPC connected through TV module and AUX + I-BUS works perfectly fine.
What should to do now?
Should I just drive it and enjoy the ride?
Did something like that happened to anyone before?
Elwin is offline   Reply With Quote
Old 01-31-2011, 07:00 PM   #2
Gwood 86
My Ride: 02 BMW 325i
Sport Classics -Sumitomo - K&N - Magnaflow
Gwood 86 is offline   Reply With Quote
Old 01-31-2011, 07:03 PM   #3
SKIBUMM
My Ride: 328i
You better do some preventative maintenence so you can screw something up.
SKIBUMM is offline   Reply With Quote
Old 01-31-2011, 07:04 PM   #4
snowskateskate
My Ride: 2001 330ci man.trans
You must not be a real enthusiast. There is always someone wrong; you're just not looking hard enough.
OH...and you didn't knock on wood.....you're in for a world of sh*t. Better be prepared to bust out the mastercard and bend over in front of a mechanic.
snowskateskate is offline   Reply With Quote
Old 01-31-2011, 07:06 PM   #5
depinhob1
My Ride: 2001 325ci
Send a message via AIM to depinhob1 Send a message via Yahoo to depinhob1
+1
depinhob1 is offline   Reply With Quote
Old 01-31-2011, 07:06 PM   #6
destroyeerr
My Ride: e46 ///M3 6spd
haha something is going to happen to your car now that you made this thread.
my cars is in perfect working order right now too "knock on wood"
destroyeerr is offline   Reply With Quote
Old 01-31-2011, 07:10 PM   #7
Top_Bunk
My Ride: Ram-Air Nylon
This is absolutely not normal, you should get it checked out immediately.
Put your car on jackstands first. Not on the jackpad, put the jackstands on your sideskirts.
I recommend changing your oil - use nothing but non-synthetic Sunoco 15W30 and a Purolator filter.
Your air filter could be a problem as well, I recommend changing it out for an extremely well-oiled K&N. Install it immediately, do not allow the oil to soak into the filter medium. A turbonator will need to be installed immediately in front of the MAF.
Lastly, you are going to have to drain your gas tank. Fill it up with nothing but Costco 87 Octane. I hear this is spectacular gas.
Take it for a test run and make sure you shift no lower than 6000RPM until your engine warms up. This will hopefully solve your problem.
Hope that helps. Report back with results.
Top_Bunk is offline   Reply With Quote
Old 01-31-2011, 07:12 PM   #8
babym0bile
My Ride: 03 325i
Send a message via AIM to babym0bile
I also recommend rolling your windows up and down, non stop for hours at at time.
-Alyssa Disney
-2003 325i
-Low and Slow.
babym0bile is offline   Reply With Quote
Old 01-31-2011, 07:14 PM   #9
hudatder
My Ride: 2001 330i
Take your car to the dealer, there is a problem with you not having a problem! Might have to fork out some major cash for fixing a no problem, problem =[
hudatder is offline   Reply With Quote
Old 01-31-2011, 07:16 PM   #10
SalM
My Ride: Shhh
*Knock On Wood* I've never ever had any problems with my 2000 328i... Then again it doesnt leave my garage and has 51k miles
SalMPhotography
SalM is offline   Reply With Quote
Old 01-31-2011, 07:41 PM   #11
Silver01
My Ride: 2001 330i
I love it. Great thread.
2001 330i Sport Package
BIR Sport compact proving grounds
Silver01 is offline   Reply With Quote
Old 01-31-2011, 07:46 PM   #12
alwaysbored786
My Ride: M3
*NO F-BOMBS IN SIGS*
How to refinish rims
2004 Noble M12 GTO 3R
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
1998 Honda Civic - Sister Totaled
2002 330CI - SOLD
2006 CBR 600RR - SOLD
1995 M3 Coupe - SOLD
1988 325E - SOLD
1996 Cherokee - SOLD
alwaysbored786 is offline   Reply With Quote
Old 01-31-2011, 07:50 PM   #13
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
Bimmer4Lyfe is offline   Reply With Quote
Old 01-31-2011, 07:54 PM   #14
daguzz
My Ride: 04 330i
who da funny guy now?!....
daguzz is offline   Reply With Quote
Old 01-31-2011, 07:55 PM   #15
wlmmn
My Ride: '13 Infiniti G37x
We should hire a comedian to record these lines for an audiobook.
wlmmn is offline   Reply With Quote
Old 01-31-2011, 07:58 PM   #16
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Something is seriously wrong. You must fix it until it breaks. Then you can come ask if the ebay parts are the best for replacements. Once your car is completely f*cked up, you can tell us it's all BMW's fault, and something about their marketing was the main culprit for your troubles. After, you can go back to owning a honda, since like most here, you are probably a former honda owner anyway.
GoingNuts is offline   Reply With Quote
Old 01-31-2011, 08:01 PM   #17
sea6speed
My Ride: 2010 335i Msport 6MT
The dealer will find something to repair.
sea6speed is offline   Reply With Quote
Old 01-31-2011, 08:02 PM   #18
danewilson77
My Ride: 2004 zhp
+2
danewilson77 is offline   Reply With Quote
Old 01-31-2011, 08:04 PM   #19
GoingNuts
Just Nuts
My Ride: 2004 330Ci
I am not a real enthusiast either. My car works better than the OP's and costs cheaper than a honda to run.
Old 01-31-2011, 08:05 PM   #20
RAFF112
My Ride: 325ci M3 cbr 600rr
+1
VCSL Front 18/13 Spacers Full Borla V2 K&N drop-in w/custom tube LED Interior air horn BMW performance shift Knob Seibon Hood LED DRL Dynavin Depo corners RE rear camber arms and Vogtland Springs.
Originally Posted by hayabusa55 View Post
I used to think love exists. Turns out it's a manifestation of insecurities and boredom.
RAFF112 is offline   Reply With Quote
