Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 12-28-2010, 04:13 AM   #21
paraklas
paraklas's Avatar
My Ride: ESS TS2 320ci
I just got this in my (spam) e-mail!!!!!!!
http://www.argyrides.eu/makeyourownsig.jpg
Old 12-28-2010, 04:39 AM   #22
crazyxzer0
My Ride: 2004 330i
Send a message via AIM to crazyxzer0 Send a message via MSN to crazyxzer0
-Derek
BMW Perf. 6Pot Calipers|M3 LSD|GC Coilovers|HKS Exhaust|GruppeM Intake
My Build Thread
crazyxzer0 is offline   Reply With Quote
Old 12-30-2010, 11:48 AM   #23
Avet4
My Ride: 2004 330i 6spd
This is so awesome!!! So this replaces the entire diff right? no just the internals?
Also since all the ratios are the same price, what do you guys think is an ideal ratio for a 6mt?
Avet4 is offline   Reply With Quote
Old 12-30-2010, 11:58 AM   #24
TxZHP04
My Ride: ESS TS2+ ZHP
Pretty sure this is just for the LSD "guts" and not a complete final drive. You would still need to budget for having this built into a donor diff with whatever final drive ratio you want. You'll need to consult with a dealer to confirm.
Old 12-30-2010, 03:07 PM   #25
paraklas
paraklas's Avatar
Is it complicated for a mechanic to built this to a diff? I need to inquire for 3.38 availability
Old 12-30-2010, 03:11 PM   #26
TxZHP04
Complicated, no. But it is a bit of an art so I would only trust the job to someone who builds diffs on a regular basis.
Old 12-30-2010, 03:24 PM   #27
TrippinBimmer
My Ride: ZHP Custom Stage 3.5
It's not hard. Just gotta take ur time. Alot of trial and error to get the right backlash, preload/load on Bearings and correct wear pattern on the gear set. If you have the right tools. It's easy as pie.
-TrippinBimmer
Old 12-30-2010, 06:48 PM   #28
ritos530i
My Ride: 2004 E60 530i 6speed
Send a message via MSN to ritos530i Send a message via Yahoo to ritos530i Send a message via Skype™ to ritos530i
I use to change out ford and Chevy ring and pinion plus shim the gears which included jacking the car removal of wheels etc... then back on the road within 2 hours. It's not that complicated if i can do it trust me. LOL Just have to have all the right parts. I would go from 4.10s to 3.73s depending on where i would be going. It's probably more simple with a BMW because you take the whole diff out and can work on a table where i was doing this in a parking lot with a car jack and stands.
530i E60 Custom Turbo/Nitrous (PSI_unknown)
ritos530i is offline   Reply With Quote
Old 12-30-2010, 08:29 PM   #29
TrippinBimmer
^ that is correct but the tolerance on the BMW is much much tighter then the ford, jeep and chevy. Since, the diff is not under the car. You will need a case spreader. Won't be able to use a crowbar to pry out the diff. If not done correctly it will destroy a Ring and Pinion and Bearings. I have installed Eaton, ARB, Lincoln Welded, and Qualife LSD/Lockers.
TrippinBimmer
Old 12-30-2010, 10:24 PM   #30
FTWeisse
My Ride: has no hip-hop rimz
Interesting
Old 12-30-2010, 10:53 PM   #31
DavidHarsay
My Ride: 2002 330Ci
What took so long... seriously. But $1,300??
Need some competition and volume in this business.
I do have a case spreader dial gauges to set up an install. Installed a few TrueTracs in 8.8 diffs, they were $400!!
Has anyone ordered one of these?
DavidHarsay is offline   Reply With Quote
Old 12-30-2010, 11:10 PM   #32
bluejeansonfire
ninja editor
My Ride: shaken, not stirred
Send a message via AIM to bluejeansonfire
no case spreader necessary, these come apart, can be assembled in-diff, or that's the kaaz at least. This looks like it can too.
wait, it says lifetime!?!! does this not have clutches in it?
2001 330ci TT turbo
e46nonm.com | TechniqueTuning.com | Precision-Sport.com
bluejeansonfire is offline   Reply With Quote
Old 12-30-2010, 11:20 PM   #33
TrippinBimmer
Julio,
YEP LIFETIME! I am thinking about getting one
Are you sure you don't need a Case Spreader? Maybe you lucked out? or was it snug enough to lightly pry out with a prybar? I haven't open a 330i diff yet but if u say I don't need a case spreader. I will add one to mine
Nope, These use Gears no Clutches. Geared LSDs are more dependent on the torque and not on the speed difference between the output shafts Such differentials may not be adequate on extremely slippery surfaces such as ice.
-TrippinBimmer
Old 12-31-2010, 12:07 AM   #34
McSpeed
My Ride: 2005 ZHP TT Stg 1
IIRC: instead of 'clutches', they call the interlocking lobe faces 'cams'. I dunno about lifetime- I'd guess it depends on how often the cams are called into action- it's essentially a Quaife in the meantime though. But hey the warranty is lifetime so that's good
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque - updated
McSpeed is offline   Reply With Quote
Old 02-08-2011, 12:15 AM   #35
crazyxzer0
My Ride: 2004 330i
bringing this back up. anyone attempt to get this LSD?
-Derek
My Build Thread
Old 02-08-2011, 07:29 AM   #36
jabela
My Ride: 2002 325ci
I'm talking to my mechanic as we speak. I'll let you guys know how it goes.
2002 BMW 325ci /// Sport Pkg /// 5 spd
Modern Apothecary
jabela is offline   Reply With Quote
Old 02-08-2011, 11:40 AM   #37
crazyxzer0
My Ride: 2004 330i
can't wait
I just recently started the process to research LSD into the car.
-Derek
My Build Thread
Old 02-08-2011, 02:57 PM   #38
zhp M54
My Ride: 2004 330i
So is Quaife and Wavetrac the only option for aftermarket LSD? I'd like to buy the LSD unit alone to avoid the core exchange of buying a new diff
///M
zhp M54 is offline   Reply With Quote
Old 02-08-2011, 03:06 PM   #39
Kawabob
My Ride: 05 325Ci
No, there is OS Giken and Kaaz also.
Cheers,
Bob
Kawabob is offline   Reply With Quote
Old 05-24-2011, 11:36 PM   #40
crazyxzer0
My Ride: 2004 330i
bumpppp, did anyone get this? lol I can't do guinea pig on my daily driver.
-Derek
My Build Thread
