E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
Old 02-04-2011, 01:14 AM   #1
ixtoxi
My Ride: 02 330xi, 88 325iX
Can't get front axle back into differential
Hey fellow iXers. I had a bad front right axle and have removed the old one and am in the process of installing the new one. I am having trouble getting the new front passenger side axle to seat into the differential. The splined shaft with new circlip gets about 3/4 inch from where it needs to be, but I can't get it to snap into place. I installed a new radial seal and everything is clean, but it still will not go. Any hints? Seems to be binding up on the outboard bearing.
ixtoxi is offline   Reply With Quote
Old 02-04-2011, 08:01 AM   #2
Rickna
My Ride: '01 330xi - '09 IS-F
I read somwhere that the gap in the circlip should be at 12 o'clock when you insert the new axle. BTW-what brand is the axle?
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 02-04-2011, 08:33 AM   #3
SILVRRONIN
My Ride: 2003 325.xit
look at my past posts..! I went through this s*** this past august when I redid mine! except one of mine got jammed into the gearbox and then WOULD NOT COME OUT!. USE THE OLD CIRCLIP FROM THE OLD STOCK BMW AXLE!...and make sure it is in the twelve oclock position..RICKNA is correct. And DONT POUND IT IN!...gently tab and havesomeone watch to see if it moves into the gearbox...you dont want to knock a gear outta place in the transfercase gearbox. Lemme know how it goes..been there done that!
SILVRRONIN is offline   Reply With Quote
Old 02-04-2011, 08:57 AM   #4
Rickna
Good point-I forgot that...
2001 BMW 330xi
2009 Lexus IS-F
Old 02-04-2011, 09:44 AM   #5
Mark M
My Ride: e30 M3 / e90 335d
I've never done this job, but will in the next month.
However to the OP, I'd imagine the shaft has splines on it that fit into the receiving end inside the gearbox. Have you tried rotating the shaft slightly so as to line up the splines for mating into the box then putting pressure on it?
Mark M is offline   Reply With Quote
Old 02-04-2011, 10:57 AM   #6
MiniXP
My Ride: 08 335i & 01 325xi
Make sure that the part going into the differential is lined up right. I spent forever trying to get mine to go back in and I ended up just having to reach in to lift up the part close to the differential then push to make it snap in.
MiniXP is online now   Reply With Quote
Old 02-04-2011, 11:16 AM   #7
athayer187
My Ride: 2004 330xi
The trick I use is to get the splines seated (confirm by twisting the axle and making sure the wheels turn). Once they're seated, put the outboard splines into the hub, and use the motion of seating the strut to push teh circlip back in. There isn't any surface that you'll want to use tools to pound it in, so I found this to work well.
1988 535is - 10.5:1, PB N31 cammed M30B35, Miller WAR and MAF, style 29's and style 5's, urethane everywhere, revalved Bilsteins
500/450 Coilovers, Vorshlag camber plates, UUC SSK, Mason Eng. strut bars
Hella H1/H4's, Schroth Rallye 3's, Dinan 25/19 sways, e32 750i brakes, Bav Auto headers, M5 clutch and FW
athayer187 is offline   Reply With Quote
Old 02-07-2011, 09:35 PM   #8
ixtoxi
OK you guys. This was not a case of just lining things up and sliding the axle in until the circlip engaged. I went through 3 cycles of partially installing and then removing the new axle before I got it to seat. It seems that the main resistance was the outboard bearing in the extension of the differential on the passenger's side. There is no way that you (I) can (could) easily push the axle in and have it just click into place, and I don't consider myself a weakling. The outboard bearing fits VERY snugly onto the axle shaft. This took quite a bit of "coaxing" to get it to its fullest insertion point. I have done a LOT of DIY work on e30s and e46s, including full rebuilds of the front end, and this one was the most psychologically taxing. I even tried the old axle, and it bound up the same way the new one did. After quite a bit of teeth gnashing and physical encouragement, it has found its way home. Glad to FINALLY be done with this beotch! Thanks to all who posted tips.
Old 02-07-2011, 09:38 PM   #9
gurov
My Ride: 2004 325XI Turbo
Send a message via AIM to gurov Send a message via MSN to gurov
yes, this was one of the more challenging parts of the axle swap. yelling and throwing **** ensued.
2014 X1 - m-sport - stock
2004 325xi top mount turbo - megasquirt3 for engine, 5 speed swap. build thread
1994 supra MKIV - single 72mm - bc272 cams - super spec twin plate clutch - aem v2, 1000CC ID, dual denso pump, j&s ultrasafeguard
2004 SE-R SpecV turbo - megasquirt3 j&s ultrasafeguard - SOLD
gurov is offline   Reply With Quote
Old 02-08-2011, 09:24 PM   #10
dephantn
Location: Toronto Canada- Family's EX :745i & X5 - 525i-323i
My Ride: 740iL-325xi
Get service manual before DIY, very worthy for $65. ( even $35 if you buy PDF file ).
I bought 5 for 5 cars, never regret, save ton of $$$ & time.
dephantn is offline   Reply With Quote
Old 02-08-2011, 11:48 PM   #11
ixtoxi
I have the service manual.
Old 11-04-2012, 03:52 PM   #12
bikesandcars
My Ride: 2002 325xi-sport pkg
I'm bringing back this old post because I just had the same issue.
The spring clip on the replacement axle was noticably larger than the OE. I swapped them out
I completed the job with a sledge-hammer... not joking. I screwed the axle nut onto the axle then tapped the end gently with an 8lb sledge palmed in my hand. I made sure the axle was supported and straight before tapping. You need the inertia from a sledge to move the heavy axle into position, you dont want to hit the axle hard enough ruin something. A small hammer would likely ruin the axle end without seating the axle. Just my $.02
bikesandcars is offline   Reply With Quote
Old 11-04-2012, 08:17 PM   #13
325xittt
My Ride: 2003, 325 XIT
There are notches on the side of the housing that the three lobed bearing ride in on the axle shaft. You can place the blade of a large screw driver or dull flat chisel on these notches and tap the axle into place. Tap tap done
325xittt is offline   Reply With Quote
Old 11-06-2012, 11:26 AM   #14
mcopenha
My Ride: '01 325xi, '73 2002
I also used this method without any issues. The GKN axles had the notches. A previous brand I used (cardone?) did not.
The more difficult task I found was getting the other end of the axle into the steering knuckle. For that I used a large, square piece of wood on the knuckle and a large sledge hammer. Once I could thread on the axle nut a bit, air gun handled the rest.
mcopenha is offline   Reply With Quote
Old 11-13-2012, 08:32 AM   #15
bikesandcars
good pointers on axle tap... not sure why (besides not having many hands) I decided to take the axle out by using the notches, but put the axle in using the sledge... it just seemed easier at the time to line up the axle by palming the CV and tap on the tip of the axle palming the sledge (that way I didn't have to hold a screwdriver in addition to an axle).
I experienced same thing with "homing" the outer stub-axle in the upright. I used anti-sieze on the splines and a dead-blow hammer on the upright to get enough bite on the nut. then finished with an impact and final hand torque
Bonus tip: Don't forget to inspect the new / replacement CV sealing surfaces on the inner joints, and don't forget to grease those seals (old or new) before inserting the axle. Suggest new seals of course.
Old 09-23-2015, 07:03 PM   #16
BigMaineWomen
My Ride: 2002 330XI
I'm having a really hard time getting the hub end of the axle in. I just can't get it to slide on. The old one slid right off by hand.
I was using the same method as mcopenha, starting the splines and using a block of wood on the hub with a sledge to pound on it. I was finding that i really had to beat on it to get any movement from the spline. I got it far enough that the threads were even with opening, another quarter inch and i probably could have used the impact to put the nut on. But when i rotated the shaft i noticed that my opposite tire wasnt rotating any more. I was immediately afraid i knocked gears out of the transfer case and used the axle puller to remove it from the hub. I can spin the opposite tire in all gears but it doesnt spin in neutral. I'm pretty sure i was spinning it in neutral before (at least getting some movement) and now it has no movement whatsoever.
Does someone have a better method for getting the hub side on? I really dont want to beat on it like i was before.
BigMaineWomen is offline   Reply With Quote
Old 09-23-2015, 08:26 PM   #17
jmo69
My Ride: 03 325xi 98 328is
I've done this job twice, the first time I beat on the hub with a 3lb. mini sledge, got it in but mushroomed the hub and made it hard to put the wheel on and off. The second time I held onto the outer cv joint and pounded on the hub with my dead blow hammer. Took a while but it finally went on far enough to get the nut on. Used a ratchet for a few turns before using my impact. Can't speak about the other axle turning because mine's an auto and was in park. Any kind of lube on the splines can't hurt, not sure if I put some anti-seize on the last time but I'm pretty sure I did on the right front one.
jmo69 is offline   Reply With Quote
Old 09-23-2015, 08:31 PM   #18
BigMaineWomen
My Ride: 2002 330XI
Thanks jmo. If you mushroomed the hub without breaking anything in the transfer case I guess I will try the same method again. If anyone else has advice I'm open to it. Thank you.
Old 09-23-2015, 08:43 PM   #19
jmo69
IDK if I did anything to the axle by beating on it but if you are doing the left side the inner joint ends up being real close to the dif. You could put something in that space so the axle is against the dif housing and the force isn't being transferred to the internals.
Old 09-23-2015, 09:16 PM   #20
BigMaineWomen
My Ride: 2002 330XI
I'm working on the passenger side for now. Hopefully I can finish it up tomorrow morning in time to not be too late for work. Driver side is this weekend but it's more as PM.
