E46 Xi Forum
Old 02-14-2011, 09:24 PM   #1
White_Knuckles
My Ride: 2003 325xi
Sundaii's how to NOT install shocks
Edit: Removed the original thread. It was quickly annihilated by others.
This now would be a pictorial thread involving shock installation that went terribly wrong.
Note: This is narrated with crude "texting" style which may be deciphered to reveal deep, contemplated thoughts.
Please continue...
Last edited by White_Knuckles; 02-15-2011 at 12:36 AM. Reason: The original was stepped on
Old 02-14-2011, 09:46 PM   #2
LittleChrist12
My Ride: 2003 BMW 325xi
I put Eibach springs and Bilstein sport shocks on my 325xi. With everything else left as is, the car now sits at the level of a stock 325i. It dropped about an inch up front and 1.25" in the rear. As for the ride, the car rolls noticably less in the corners, but the ride isn't too stiff to be uncomfortable. I'm very happy with the results. Alternatively, you could just replace the shocks/struts with Bilstein HDs and keep the stock springs. They should be ok for another 80k miles.
Sent from my DROIDX using Bimmer App
2003 BMW 325xi
2010 BMW M3 Sedan
LittleChrist12 is offline   Reply With Quote
Old 02-14-2011, 09:48 PM   #3
Sundaii323ci
My Ride: Ri
Ok WTF do I do when this happens after you replace it with a new one 5 hrs later ????
Sundaii323ci is offline   Reply With Quote
Old 02-14-2011, 09:49 PM   #4
Sundaii323ci
My Ride: Ri
Can some one help me find out what went wrong over here Cus I'm ****ing piss right now
Old 02-14-2011, 10:47 PM   #5
Kubica
My Ride: 2003 325xi
Looks like your rear shock mounts have crapped the bed or you didn't install them properly.
Old 02-14-2011, 11:00 PM   #6
bmwstephen
My Ride: e46 325XI, e36 M3
he didnt install them properly. the top washer is mounted upside down. it cannot be fitted to conform to the rubber mount but rather against it. same with the bottom washer which appears he doesnt have because it would've distributed the energy throughout the rubber instead of concentrating it in the center to push it through the carrier
bmwstephen is offline   Reply With Quote
Old 02-14-2011, 11:13 PM   #7
Sundaii323ci
My Ride: Ri
I do have the bottom washer
Old 02-14-2011, 11:18 PM   #8
bmwstephen
your current setup:
{nut}
___________
/_Top Washer_\
(_Shock mount_)
_____________
\Bottom Washer/
is it also conforming with the rubber? this is the order you're supposed to install it in:
{nut}
______________
\_Top Washer_/
(_Shock mount_)
_____________
/Bottom Washer\
Old 02-14-2011, 11:22 PM   #9
Sundaii323ci
My Ride: Ri
How can you tell my order is all jacked up I'm a take a pic of the bottom of the car then let me know what you think
Old 02-14-2011, 11:25 PM   #10
bmwstephen
it's an easy mistake most mechanics miss. they install the washers to conform with the rubber. I bet you don't even have a dust cover sleeve on the rear shock now because if the bottom washer was installed incorrectly, the sleeve doesn't properly
Old 02-14-2011, 11:32 PM   #11
Sundaii323ci
My Ride: Ri
You MADD
Old 02-14-2011, 11:44 PM   #12
Sundaii323ci
My Ride: Ri
Old 02-14-2011, 11:47 PM   #13
bmwstephen
i will not help you further until you start your own thread or PM me. OP sorry for the thread jack
Old 02-15-2011, 12:07 AM   #14
Sundaii323ci
My Ride: Ri
:/ me don't know how be a dick face you like
Old 02-15-2011, 05:57 AM   #15
lotar_6
My Ride: '01 xi, '94 Rado
lol... epic
lotar_6 is offline   Reply With Quote
Old 02-15-2011, 05:08 PM   #16
Sundaii323ci
My Ride: Ri
Lmafo this is to funny
