Closed Thread
Old 02-15-2011, 12:07 PM   #1
VECTOR
My Ride: 2004 330CI auto vert
Question Oil Sludge?
When I went to add some oil the other day I noticed what appeared to be a layer of built up oil. I ran my finger inside the valve cover and came back with a small amount of what I would call built up sludge.
I am getting ready to change my oil, so I am wondering if there is a product(not snake oil) that you all use to reduce/eliminate the build up of oil film/sludge just before changing the oil?
VECTOR is offline
Old 02-15-2011, 12:16 PM   #2
alwaysbored786
My Ride: M3
if its like this:
http://forum.e46fanatics.com/showthr...&highlight=oil
Than you have nothing to worry about.
If its yellow gunk stuff that almost looks like mayo, than you have something to worry about.
*NO F-BOMBS IN SIGS*
How to refinish rims
2004 Noble M12 GTO 3R
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
1998 Honda Civic - Sister Totaled
2002 330CI - SOLD
2006 CBR 600RR - SOLD
1995 M3 Coupe - SOLD
1988 325E - SOLD
1996 Cherokee - SOLD
alwaysbored786 is offline
Old 02-15-2011, 12:41 PM   #3
Mclovin1458
My Ride: 2005 325ci, zsp/zpp
...no
"yellow gunk stuff" on your oil cap is normal if you do alot of short trips. Few nice 20-30 min hwy runs will get rid of that. This happens on all cars.
Mclovin1458 is offline
Old 02-15-2011, 12:58 PM   #4
VECTOR
Originally Posted by alwaysbored786 View Post
if its like this:
It was on the internal engine metal I could reach with my finger, not the cap itself. It came off like a paste more than a lite film of oil. I cannot say it looked like mayo, but lets assume for the moment it is. What do you guys use(if anything) to loosen or break it down right before an oil change?
What is there to worry about as you put it if it is more like mayo, and what is typically done to get rid of it?
VECTOR is offline
Old 02-15-2011, 01:03 PM   #5
antonmn
My Ride: 02 325Ci
Sounds like standard gunk. I'd change the oil more often, consider running a cycle of AutoRX, but that's about it. I'd run a synthetic that is a little more detergent heavy. BMW's oil is not... it likes to leave red staining behind, or worse.
If you're really concerned, pop the valve cover off and post pics. Some of us really get off on valvetrain pohrn
*signature*
antonmn is offline
Old 02-15-2011, 01:03 PM   #6
alwaysbored786
My Ride: M3
Originally Posted by Mclovin1458 View Post
...no
no, its not normal in the sense of what normal is. Its just a sort of common issue, normal would be if there was gunk crap.
If its just that redish/brownish paste, thats "normal". Thats regular deposits that have built up, not an issue at all....unless its some damn thick layers. Get a pic.
If its the yellow gunk crap, its most likely due to condensation; can also be a variety of other issues such as a bad/clogged ccv (crank case vent valve), cold temperatures are the main issue of this yellow gunk, you have nothing to worry abt since you're in FL
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
2002 330CI - SOLD
1988 325E - SOLD
Old 02-15-2011, 01:08 PM   #7
OrientBlau
My Ride: 2003 330i
Ditto.
Nothing like a few pairs of sexy rocker arms to ogle!
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
OrientBlau is offline
Old 02-15-2011, 01:42 PM   #8
iansanderson
My Ride: 2001 330CiC
many on the E38 boards have reported luck with this stuff:
http://www.auto-rx.com/
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
iansanderson is offline
Old 02-15-2011, 01:59 PM   #9
SamDoe1
My Ride: 4cyl of fury
Reading through their site a little... One thing that jumped out at me is that they do not recommend using synthetic oil while using autorx. Is this safe with our cars?
SamDoe1 is offline
Old 02-15-2011, 02:09 PM   #10
danewilson77
My Ride: 2004 zhp
You have to use an estoril free oil.......is it safe for our cars? I will only say it is not the BMW approved oil.
Do I think it will cause damage if you do use it for a short period of time? No. How long does Auto-Rx take to work? A long time. Quite a cunundrum isn't it?
My recommendation would be this...
1. Make your trips a lil longer to ensure your car reaches normal operating temp.
2. Replace your ccv.
3. Change your oil with the BMW approved Synthetic oil.....but decrease the frequency of filter changes. Meaning....if you go 7500 miles in between changes.....maybe change out your filter every 1500 miles.....just for this periodicity.
4. Evaluate oil condition by all available means...including sending off an oil sample to Blackstone labs (Do this at your next oil change-after doing the elevated filter changing). They will tell you if you are good to go or not.
danewilson77 is offline
Old 02-15-2011, 02:26 PM   #11
antonmn
My Ride: 02 325Ci
Last year I ran with 2/3 of a can of SeaFoam (basically a solvent) in the the crankcase for about 2500 miles. It really loaded up the oil filter with flaky crap, and caused the filter pleats to distort, as though they were under a lot of backpressure.
Long story short, it loosened a lot of garbage and sent it to the filter, which is what we want. But I'd probably only run it for maybe a thousand miles at a time. Maybe do that a few cycles with a cheaper dino oil.
*signature*
antonmn is offline
Old 02-15-2011, 02:34 PM   #12
danewilson77
My Ride: 2004 zhp
The issue here is you want a sloooooooooooow breakdown of the sludge. I fear this method (above) my clog a small oil passage port to a vital area of the engine. That would be my only concern with Kerosene or Seafoam.
Old 02-15-2011, 02:45 PM   #13
SamDoe1
I'm not asking because I have any issues right now, I'm just asking because I'm curious. If it is a viable solution, it might help out quite a few people.
SamDoe1 is offline
Old 02-15-2011, 03:06 PM   #14
OrientBlau
My Ride: 2003 330i
Ive heard Sea Foam is all placebo.
Old 02-15-2011, 03:18 PM   #15
E46330iguy
My Ride: Supercharged 330i
thats very bad, Instructions clearly say drive 100 miles than change oil
Winter Authority When Hell freezes over,we'll play Hockey there too
you've Met a terrible fate haven't you ?
KONI /Michelin/Stoptec/Borla/ Bimmerbrake / MTechII/AA Stage one (for now) Automatic--->5 speed swap/ UUC High performance clutch kit
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline
Old 02-15-2011, 03:19 PM   #16
antonmn
My Ride: 02 325Ci
You might be thinking of the induction cleaning, which is what most use it for. It's a solvent, and the problem is that it works too well. I posted an oil analysis about a year ago that showed how it lowered my oil's flashpoint and viscosity.
Can't say what it does in the fuel, and the induction cleaning might be nothing but a smoke show. But it certainly loosens stuff up when it's in the oil.
*signature*
antonmn is offline
Old 02-15-2011, 03:22 PM   #17
OrientBlau
My Ride: 2003 330i
Yeah, Im just thinking of the induction and smoke screen.
I'd still question though, the effect that these particles one poster mentioned in his filter. Sounds like risky stuff to find large particles in your filter and enough to distort the filter pleats. Personally, I'd be wary of running anything in my oil.
Old 02-15-2011, 03:41 PM   #18
antonmn
My Ride: 02 325Ci
Well, I don't think the crap in the filter was life or death... here's a pic:
https://picasaweb.google.com/lh/phot...eat=directlink
I just wouldn't leave it in for 2500 miles like I did.
*signature*
antonmn is offline
Old 02-15-2011, 08:52 PM   #19
sprintman
My Ride: Ex 325CI owner
Thumbs Up
Auto-Rx is the only thing I add. 2 1/2 bottles in my sump right now with a Group III 5W40 oil..
sprintman is offline
Old 02-16-2011, 01:20 PM   #20
VECTOR
Not sure what Group III is, maybe an Aussie designation/measurement?
What about the earlier comment about not running it with synthetic oil?
VECTOR is offline
Closed Thread
