E46 Xi Forum
Old 02-16-2011, 08:53 PM   #1
RECK48
My Ride: bmw 2004 e46
Exclamation Transmission fails after seafoam 325xi 2004.
I had just finished seafoaming thru the vacuum line my 325xi 04 133k while i was revving the car my fan just shot a causing a dent in the hood. My car wouldnt move when i put it in d. I had my radiator leaking. The fan broke some of the hoses but i was recently told that my transmission is also shot.i feared that. I just dont understand how the seafoam caused that anybody has any ideas?
Also i found a 328 1999 for sale i was wondering if i could do a transmission swap? And maybe use some of the other parts.
RECK48 is offline   Reply With Quote
Old 02-16-2011, 08:54 PM   #2
RECK48
I have a video by the way ill post up the link once i upload it.
Old 02-16-2011, 09:06 PM   #3
e4sixxx
My Ride: 2000 328ci
strictly coincidental, the fact your fan grenaded had nothing to do with the seafoam treatment. The reason why your car isnt going anywhere is because the ATF leaked out, if an auto trans doesnt have enough fluid the torque converter cannot generate the power to move your car. Fix the fan, or convert to a electric fan(see KPENGs thread) and all the hoses that were damaged, top off all fluids, and your back in business.
e4sixxx is offline   Reply With Quote
Old 02-16-2011, 09:48 PM   #4
RECK48
that makes whole lot of sense i didn't check it myself because the lack of tool plus i had to get it towed. appreciate it. forgot to mention the atf reservoir broke also but i thought that was for the steering.
Old 02-17-2011, 09:20 AM   #6
E-rock
My Ride: '01 330xi
Another Seafoam related death. Waiting on video link. Seafoam is infamously well-known for causing fans to explode.
"So when you go for a drive, remember to leave your murderous anger where it belongs - at home."
E-rock is offline   Reply With Quote
Old 02-17-2011, 09:35 AM   #7
darksideracer69
My Ride: 01 325ci
^So dumb lol
IMAG02051
Old 02-17-2011, 11:34 AM   #8
xi_ter
My Ride: 2003 325xi
The fan mounts deteriorate. Flooring the car while running Seafoam puts stress on the fan mount and they whole fan shifts and grenades.
Take a look at this post: http://forum.e46fanatics.com/showthr...911&highlight=
The fan probably only punctured ATF hoses.
Old 02-17-2011, 02:32 PM   #9
RECK48
View My Video decided to let my girl revv itt. try not to laugh.
Old 02-17-2011, 02:35 PM   #10
RECK48
thanks for the thread link Im deff upgrading to an electrical fan after this.
Old 02-17-2011, 02:37 PM   #11
OrientBlau
My Ride: 2003 330i
Sea Ffoam is mostly placebo. I wouldnt run it in my induction.
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
OrientBlau is offline   Reply With Quote
Old 02-17-2011, 02:38 PM   #12
RECK48
once i get my car back from the shop is in ill take it to my friends shop ill see the damage caused and fix it. im almost sure is not the transmission now. my air intake broke also btw. ill take pics and put them up.
Old 02-17-2011, 03:23 PM   #13
E-rock
My Ride: '01 330xi
Originally Posted by RECK48 View Post
try not to laugh.
I tried.
I failed.
Old 02-17-2011, 04:53 PM   #14
My Ride: Lexus
Simple: You're not supposed to rev the engine while stationary. This helped your already-deteriorating fan blades explode causing pieces of the blade to puncture your transmission cooling lines. Your trans fluid leaked out thus rendering the transmission useless. If you're lucky, you may be able to repair the lines, refill the trans and go on your way. If not, then you tried driving your car without fluid and fried the transmission. Do not blame this on Seafoam.
Old 02-17-2011, 05:36 PM   #15
RECK48
how can i tell if i fried my transmission or not i did try to move it after the leakage. would the pcm show any codes if this was the case?
Old 02-20-2011, 05:33 PM   #16
Rickna
My Ride: '01 330xi - '09 IS-F
Excluding forced industion, I have used Seafoam on several cars-never had a problem.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 02-20-2011, 06:13 PM   #17
iDriftYou
My Ride: is a HighWay monster
Automatic transmissions run only when there is ATF in them. If there is no ATF, the gears will not engage. I'm positive if you did in fact puncture your ATF cooling lines, then just get new lines and refill the tranny and your car should move. just my .02$.
-Shehroz
Current: 1990 Toyota Supra
Mods: CP pistons/ Eagle rods/ HKS MHG/ 264 Cams/ Rebuilt CT26
Future: GT35r
My DIY:
DIY ZF 5HP19 Transmission Drain/ Refill : http://forum.e46fanatics.com/showthr...12#post9551712
"My life doesn't only move in a straight line, why should my car?"
iDriftYou is offline   Reply With Quote
Old 02-20-2011, 07:38 PM   #18
gurov
My Ride: 2004 325XI Turbo
Send a message via AIM to gurov Send a message via MSN to gurov
yeah, the trans is most likely fine, if there's no atf, there wouldn't be any motion transfer via the torque converter, so the car just stops. fix the lines, fill it up with atf and go.
2014 X1 - m-sport - stock
2004 325xi top mount turbo - megasquirt3 for engine, 5 speed swap. build thread
1994 supra MKIV - single 72mm - bc272 cams - super spec twin plate clutch - aem v2, 1000CC ID, dual denso pump, j&s ultrasafeguard
2004 SE-R SpecV turbo - megasquirt3 j&s ultrasafeguard - SOLD
gurov is offline   Reply With Quote
Old 02-22-2011, 01:52 AM   #19
RECK48
getting my car back today. have a pretty basic idea in how to change the cooler lines. a little too basic. plus i see the hoses come with special ''quick-connect coupling". recommendations in how to make my job easier i will be making my first diy atf cooler lines and probably anything else i have to repair due to my fan-explosion. if its not already posted. help is appreciated.
Old 02-22-2011, 02:11 AM   #20
jerryscott
My Ride: 2002 325xi
there should be a grey plastic tab between the couplers, you need to push that in to release the spring. they are kind of tricky at times you kind of have to push the tab and pull the other end at the same time
jerryscott is offline   Reply With Quote
transmission seafoam
