E46 Xi Forum
Old 02-19-2011, 07:19 PM   #1
AlpinewhiteXi
My Ride: 01 325Xi // 86 325e
service engine light.
I'm sure there are tons of codes that set this light off, new to the e46 community and wondering what issues most commonly make it come on. i.e. plugs, air filter, etc? Or are we talking something a little more involved like an o2 sensor? Any feedback would be appreciated. Thanks.
AlpinewhiteXi is offline   Reply With Quote
Old 02-19-2011, 07:56 PM   #2
Lusticles
My Ride: 325Ci
The possibilities are endless. No use in guessing.
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 02-19-2011, 08:20 PM   #3
AlpinewhiteXi
So my best bet is to take it in to a shop to be diagnosed? Any DIY ways of finding out which code it is?
Old 02-19-2011, 09:20 PM   #4
dgoddard
My Ride: 02 325xi
Go to Autozone, they will give you a print out for free of the codes. Then take the codes and search for them on the forum.
2002 BMW 325xi Auto 127k
1988 BMW 535i Auto 187k
1984 BMW 528e 5Spd with e to i conversion 263k
2009 Ninja 250R 5k
dgoddard is offline   Reply With Quote
Old 02-21-2011, 10:28 AM   #5
AlpinewhiteXi
Thanks, found the codes here on the site.
Old 02-22-2011, 04:17 AM   #6
anhtu402
My Ride: 2002 BMW 325XI
What was your code? Just curious
Sent from my PC36100 using Bimmer App
anhtu402 is offline   Reply With Quote
Old 02-23-2011, 07:37 PM   #7
kudang
My Ride: 03 E46 XI touring
My engine light came on and was diagnosed as cyclone valve fault and thermostat fault.
kudang is offline   Reply With Quote
Old 02-24-2011, 07:54 AM   #8
SILVRRONIN
My Ride: 2003 325.xit
Cyclone vale??? thermostate fault I can understand..a cyclone valve?..never heard of it..
SILVRRONIN is offline   Reply With Quote
Old 02-24-2011, 07:58 AM   #9
Dvykhopen
My Ride: 02 325i sporpackag
If you're in the cold, and the SES pops up every month or so, usually it's the gas cap that throws this off. If it wasn't properly secured during a fill up, it'll put on the SES light. Unscrew the gas cap and screw it back in, then for the light to be reset, it usually takes 2 to 3 days of driving at various speeds. I've had this problem almost every winter.
Dvykhopen is offline   Reply With Quote
Old 02-24-2011, 08:34 AM   #10
Kubica
My Ride: 2003 325xi
10 year-old BMW? Time to invest in a Peake tool . . .
Old 02-24-2011, 08:36 AM   #11
99
My Ride: 01 330xi, 06 X3 3.0
I had to look it up too. It's the CCV.
99 is offline   Reply With Quote
Old 02-24-2011, 09:08 AM   #12
Ivanhoe
My Ride: BMW 330 xi 2005
I think its the best to do it if you have intention to keep the car for more then one year, I just bought one yesterday when for the first time the SES turns on.
Ivanhoe is offline   Reply With Quote
Old 02-24-2011, 04:21 PM   #13
AlpinewhiteXi
I came up with p0128. I reset the code and will see if it comes back on. From my research sounds like it is most commonly the thermostat that throws this code due to the engine not heating up fast enough. Could be from some of the brutal cold days we have had in the past couple months here in Denver. If it is the thermostat at least it's easy to replace
Old 02-24-2011, 04:24 PM   #14
AlpinewhiteXi
Actron scanner, Thanks.
Old 02-24-2011, 05:44 PM   #15
Kubica
My Ride: 2003 325xi
That's thermostat stuck open code- replace thermostat soon.
Old 02-24-2011, 06:04 PM   #16
AlpinewhiteXi
Got it thanks!
Old 02-25-2011, 03:01 PM   #17
ECSTuning
ECSTuning's Avatar
My Ride: BMW
^+1
To help diagnosis codes in the future...
Can't go wrong with PEAKE!
Manufactured specifically for BMWs, Peake scan/reset tools make servicing your BMW cheaper and easier than ever.
The tool easily connects to your diagnostic port in the engine bay and allows you to read any codes for a check engine light as well reset your oil service and inspection light with the push of a button.
This tool is a must for the first time do-it-yourself mechanic and to complete any tool box.
Click HERE to order or for more information.
Best,
Joe
800.924.5172
Old 02-25-2011, 05:18 PM   #18
AlpinewhiteXi
Originally Posted by ECSTuningJoe View Post
^+1
Best,
Joe
Good to know. I will definitely be buying one shortly. Thanks for the heads up.
Old 03-08-2011, 05:15 PM   #19
AlpinewhiteXi
So, its been a couple of weeks weather has been warm with a couple cold days mixed in. I reset the code it came back. Did some research and discovered that the thermostat temp sensor is $15 vs. 50-60 for the thermostat and housing. While deciding too do both or just the sensor the SES light went off and has not come back on for the last couple of days and it has been cold outside. Im begining to think that just the sensor is faulty. Input? Thanks.
