Front Drive AXLE/CV recommendation - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 02-23-2011, 11:00 AM   #1
bmwstephen
My Ride: e46 325XI, e36 M3
Exclamation Front Drive AXLE/CV recommendation
Hi all,
after having my 2nd re-manufactured passenger side drive axle from BMW installed by them crap out on me again, I'm looking for alternatives since I am out of warranty. Anyone have experience with the aftermarket brands, there is no way I'm shelling out $400+ for a re-manufactured axle from BMW again.
Its interesting that in both cases, the boot itself was never torn, rather the internal clamp/seal that the boot clamp binds over wore off, thus slinging grease everywhere. both lasted approximiately less than 25k miles.
bmwstephen is offline   Reply With Quote
Old 02-23-2011, 11:18 AM   #2
athayer187
My Ride: 2004 330xi
I'm sure others will chime in, but I just installed a set of A1 Cardone reman axles (bought off of Amazon.com, no core charge). I have about 3k winter miles on them, and they're holding up great. No long term experience yet, but there's no signs of any wear/failure points on any of the boots after very close inspection.
1988 535is - 10.5:1, PB N31 cammed M30B35, Miller WAR and MAF, style 29's and style 5's, urethane everywhere, revalved Bilsteins
500/450 Coilovers, Vorshlag camber plates, UUC SSK, Mason Eng. strut bars
Hella H1/H4's, Schroth Rallye 3's, Dinan 25/19 sways, e32 750i brakes, Bav Auto headers, M5 clutch and FW
athayer187 is offline   Reply With Quote
Old 02-23-2011, 11:20 AM   #3
bmwstephen
how much did you get it for?
Old 02-23-2011, 11:43 AM   #4
Kubica
My Ride: 2003 325xi
I only average about 1.5 years on my axles. I've yet to have an axle last 15k miles actually.
Do not buy FEQ or any other no-name brand axle- they are made in China. Napa sells the A1 Cardone reman axles for $75 each plus core.
Make sure you buy some diff fluid too.
Old 02-23-2011, 11:49 AM   #5
bmwstephen
so you're saying you lasted 1.5 years an A1 axle? how many A1's did you go through and what symptoms did you experience when you knew it went out again
Old 02-23-2011, 12:03 PM   #6
Kubica
My Ride: 2003 325xi
I will be putting on the car's fifth set of axles soon. First set was from the factory and lasted 70k miles. Second set was installed by the dealer and lasted about 15k miles. Third set was FEQ chinese junk and one lasted two weeks, the other two months. Fourth set was Cardone reman installed last winter- the boots are still good, but the grease slinged out of both a few weeks ago. I'm replacing the driver's side again very soon, since I will be replacing that wheel bearing.
I do track the car so expect more life out of the axles if you don't . . .
Old 02-23-2011, 12:14 PM   #7
athayer187
My Ride: 2004 330xi
Do you typically run your axles until they sling grease, or until they click or have play? I got ~110k out of my stock set. They slung grease at ~90k, I refilled them with Lucas red adn Tacky grease, and they were fine until the boots totally blew out and were dripping grease on my garage floor.
Old 02-23-2011, 12:31 PM   #8
bmwstephen
do you also need an alignment after these have been reinstalleD?
Old 02-23-2011, 12:43 PM   #9
Kubica
My Ride: 2003 325xi
No, I've never repacked the boots. I replace them when there is noticeable play in the shafts- i grab with one arm and shake the crap out of them. By this point there's usually a noticeable vibration in the steering wheel, so you are really just trying to figure out which side to replace. For $75 each, they are cheap enough to replace every year. Cheaper than nice brake pads. I've been replacing control arms every year and a half too- not so cheap.
Nope, just don't undo the top strut bolts or the tie-rods and you will be good to go.
Old 02-23-2011, 05:29 PM   #10
bombguy
bombguy's Avatar
My Ride: 2004 M3
My personal experience was to go with OEM parts on this. You get a 2yr. warranty on the part as long as it is installed by a qualified shop. I went through a CV boot on a new axle and dealership replaced it free of charge when I mentioned the warranty...all I did was show them the receipt of purchase. Of course, this was on my old Xi, and it was lowered as well.
2004 JB
KWv2, Spacers 15/F-10/R, MVR Rep, Alpine IDA-X305 w/ KCE-BT400 Bluetooth,
Agency Power Exhaust, Khoalty AE's
bombguy is offline   Reply With Quote
Old 02-23-2011, 09:43 PM   #11
lotar_6
My Ride: '01 xi, '94 Rado
Has anyone used Raxles on their xi? I bought a set for my Corrado when I put the diff in... love them and lifetime warranty! I'm just not sure if the inner CV's on the xi are the "tripod" joints like in the iX. If so, I don't think Marty can do them. Otherwise, I'm sure he can do them.
Just can't say enough good things about Raxles! He uses new joints not remans, and he uses lucas synthetic grease. Remanufactured joints are considerably weaker due to the surfacing of the bearing contact areas. Always steer clear of anything remanufactured if you can. And if you ever do a swap and need custom CV's, give him a call.
lotar_6 is offline   Reply With Quote
Old 02-24-2011, 10:16 AM   #12
jcarpfishman
My Ride: '01 330xi
Subscribed to hear about Raxles. Anyone have any experience with them?
Just repacked passenger axle the other day, doing the driver's side in a few days. Hopefully that will get me by until it's time to actually replace the axles when the weather is warmer. I figure, no clicking or vibration on acceleration / deceleration, so I should be good for a little while yet.
jcarpfishman is offline   Reply With Quote
Old 02-24-2011, 10:41 AM   #13
athayer187
My Ride: 2004 330xi
Repacking my axles bought me about a year until the boots finally blew out completely. Still wasn't any clicking, I just got tired of tracking grease inside from the garage floor.
Old 02-24-2011, 10:47 AM   #14
jcarpfishman
My Ride: '01 330xi
Sweet. I bought the boot kits, so I've got new boots, new grease, and new clamps. I even wrapped the location where the old clamp failed with moisture proof silicone tape, which should help keep it from spewing all over in the event that the new clamp fails too. As long as I've got no clicking, I should be good for a while.
Old 02-24-2011, 11:54 AM   #15
Rickna
My Ride: '01 330xi - '09 IS-F
I replaced my front/pass axle about 1-1/2 tears ago. I got the replacement from FCP Groton. I know it's made in China. It worked well until about 2 months ago. The wear is not on the CV joint but in the parts that slide horizontally.
See pic-
(Pic courtesy Pilotlviv)
Had I done more research, I would have bought the axle from RockAuto that uses A1CarDone. I was a noob then, and now I will pay the price.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 02-24-2011, 12:19 PM   #16
jcarpfishman
My Ride: '01 330xi
What were the symptoms that cropped up 2 months ago, just clicking?
Old 02-24-2011, 12:25 PM   #17
Rickna
Vibration during hard acceleration. Clicking would be the CV joint.
2001 BMW 330xi
2009 Lexus IS-F
Old 02-24-2011, 05:49 PM   #18
lotar_6
Originally Posted by Rickna View Post
See pic-
(Pic courtsey Pilotlviv)...
Thanks for the pic! so what exactly are we looking at here? I can't tell from the pic what it is... I've yet to need to do my axles, but I'm sure I will sometime.
Old 02-24-2011, 06:12 PM   #19
Rickna
The left part (Circled).
Pic (Pic courtesy Pilotlviv)
2001 BMW 330xi
2009 Lexus IS-F
Old 02-24-2011, 06:45 PM   #20
lotar_6
perfect! thank you.
it is indeed the tripod style joint. hhhmmmm.....
