How to remove a E46 headlight cover
*Tools needed*
A Flat-head screw driver
Image aided instructions
1= after removing your blinkers/indicators, pry out the top rubber headlight shield, you can undo the top 3 clips with your fingers and possibly the other 2 sitting next to the grill otherwise you a flathead screw driver.
2= pry out the lower lip(body color coded) sitting between the light and the bumper, start with the end closest to the grill and gently pull out working your way through to the fender,
3= remove the clear headlight cover by lifting off all it's clips, there is 3 clips at the top, 3 at the bottom and 1 the fender side, pull the cover out starting from the bottom,
4= Remove the inner black housing that goes around the light by simply pulling it out(no clips on this, it holds by tension)
