Sponsored by BimmerWorld
Old 03-29-2011, 08:16 PM   #1
red330eye
My Ride: 2005 zhp
Dinan suspension
Are the Dinan suspension stages worth it? Are you paying for the name? Can I get the same performance from another brand for less money
red330eye is offline   Reply With Quote
Old 03-30-2011, 09:10 AM   #2
DJ Reminisce
My Ride: Knows Dubstep SUCKS
IMO:
1) NO
2) YES (and the $ spent on R&D)
3) YES
Dinan CAI_Stage II_3.46 Dif
OEM CF Strut Bar_Eibach Sportline_GC Konis
OEM Gloss Grills_H&R Spacers_Clubsport Sills_Painted Splitters
Amber LED Corners/6k HID Fogs/LED Interior_Shadow Emblems
500W_RE Audio_Hertz Components
DJ Reminisce is offline   Reply With Quote
Old 03-30-2011, 03:26 PM   #3
jaycard73
My Ride: '02 325xi
from what I understand, dinan uses koni shocks and rebranded H&R springs in their systems...the springs though are tuned differently from the ones you'd get from an H&R vendor.
jaycard73 is offline   Reply With Quote
Old 03-30-2011, 05:28 PM   #4
///Miller325ci
My Ride: 2005 Dinan-S2 325Ci
From what i heard and i have stage three dinan suspension and i love it... is that dinan uses koni shocks... but they are revalved by koni for dinan based on dinan's required specifications... dinan has an in house shock dynometer.... there is a sticker on the strut/shock body saying that these are adjusted to dinan's recommended specifications... um as far as springs i once heard steve dinan say that they make their own springs... but what you guys miss here is that they go into details when they are doing the suspension... they even tune bump stops... bumpstops act like a secondary spring... so as you drive faster it changes the way the drives... dinan will even go as far as to specify an alignment... everyday i'm amazed at how well the car handles yet... at the same time its soo smooth... on smooth roads its way smoother than stock... on rougher roads its a little less smooth but only minorly rougher than stock.... dinan also recommends tire pressures to run as well... really well designed.... everything is done for a reason... and highly recommended though... no doubt it is pretty expensive.... i love it...
///Miller325ci is offline   Reply With Quote
