Old 03-31-2011, 11:07 AM   #1
JooP
My Ride: E46 BMW 325i Schnitz
E46 325i Steering Noise
Hi Guys,
First post, here goes:
My car is making a terrible noise when you turn the steering wheel (see youtube link) and I'm not sure if it's the pump or piping. I have noticed since its been sitting in the garage for a while that there is a tiny bit of red fluid on the floor. The power steering pipes seem gunky too but this could just be from time?
Anyone have any clues as to what it could be before I rip it all out?
JooP is offline   Reply With Quote
Old 03-31-2011, 11:12 AM   #2
mack89
My Ride: '02 TIAG 330i 5spd
Two things. Pump or rack.
Have rack boots ever been damaged? If so, sand/small rock could've damaged the rack itself.
If they've never been damaged, I'd suspect pump.
mack89 is offline   Reply With Quote
Old 03-31-2011, 11:14 AM   #3
JooP
Thanks for the quick reply Mack.
Come to think of it. I had borrowed the car to my mum (veryyyy hard to do...) and she returned it like that. She said that she went through a hectic puddle of water and her road is full of potholes... so I wonder... ? Otherwise, to my knowledge, nope never...
Old 03-31-2011, 11:19 AM   #4
mack89
Rack doesn't get damaged if boots never been torn out. It's just bunch of pinions,,you know.
I'd replace PS pump, OEM LF20 pump should be around $250.
Old 03-31-2011, 11:22 AM   #5
GoingNuts
Just Nuts
My Ride: 2004 330Ci
It could be your low fluid.
So what engine oil do you use ? I can tell it's neither BMW nor Castrol oil.
GoingNuts is offline   Reply With Quote
Old 03-31-2011, 11:23 AM   #6
JooP
Thanks Mack, might just go ahead and do that, they're actually a lot cheaper here in SA, about $100. Do you know of a good DIY ?
Old 03-31-2011, 11:39 AM   #7
mack89
^This DIY will serve you just perfect
http://www.e46fanatics.com/forum/sho...d.php?t=575499
Old 03-31-2011, 04:45 PM   #8
JooP
It's actually Castrol to be honest and yes the tank is full... ?
Old 03-31-2011, 04:49 PM   #9
islanq
My Ride: An E46 like you...
Send a message via AIM to islanq
Wow, ironic, I just posted a thread about mine last night!
http://forum.e46fanatics.com/showthread.php?t=833523
This is the SAME exact sound I'm getting, it's like a rapid "thuding" noise when you even slightly turn the wheel, right? Did you drive it home like that? I parked mine about 5 miles across town. I'd like to get it today without a tow!
Consensus on my thread seems to be PS pump. However, I talked to my BMW mechanic buddy and he said it could ALSO be the little rod/shaft inside might have failed.
islanq is offline   Reply With Quote
Old 04-01-2011, 02:54 AM   #10
JooP
My mom was actually borrowing it. She drove it all the way to me like that and it's been sitting ever since!
Its a hectic noise, really scary. hehe -
If you hear anything new please let me know dude, and good luck getting it sorted lets stay in touch.
Old 04-01-2011, 07:59 PM   #11
islanq
http://forum.e46fanatics.com/showpos...23&postcount=7
^^^Check out my updated post about what happened to mine! Wasn't a bad steering pump, I'm assuming it was just a clocked line. If your pump IS bad however, I have a used OEM LUK LF-30 I purchased for $230 and can only return for in store credit which I no longer need. UGH! Asking $200+ shipping if you need one!
noise, pump, steering
