E46 Convertible
Old 04-20-2011, 08:00 AM   #1
BavLar
My Ride: 330Cic 5spd & 330i
Vert Spring/Shock Upgrade
Looks like the H&R Touring Cupkit might be the choice for me, but I can't find a lot of varied opinions on verts while searching the forum.
I currently have non-sport suspension in my '01 330. Shocks need replacement so I would like to mildly drip it at the same time. I don't want anything tucked, just a nice drop similar to sport suspension or even a hair lower in the front. Spirited driving for sure. H&R has a spring specific to the verts & wagons while Eibach and others just offer the same part number as for coupe's. That tells me it doesn't take extra weight into account. I considered the ZHP strut/shock kit for $500 on clearance which includes CA's and fatter sway bar, but that still leaves me without springs. Don't know if that would be a good solution packaged with H&R Touring springs.
Opinions and pics if you have them.
Thanks!
BavLar is offline   Reply With Quote
Old 04-20-2011, 08:53 AM   #2
douglas_ngo
Europrojektz Southeast
My Ride: Hamann Widebody
You can't go wrong with H&R cupkit. I have Tein SS Coilover and happy with it so far.
douglas_ngo is offline   Reply With Quote
Old 04-20-2011, 10:22 AM   #3
BavLar
I see that it's available for the M3 convertible, but I didn't see whether or not it will fit the non-m. $1300 is a great price for a coilover setup.
Old 04-20-2011, 12:31 PM   #4
douglas_ngo
I bought mine used and it came off a 330 sedan. I don't think E46 M3 coilover setup will fit on a non-m model.
Old 04-20-2011, 12:41 PM   #5
gary442
My Ride: 2004 M3 Vert
Vert Shock Upgrade
I redid my suspemsion about 6 months ago. Mine is a 02 330CiC with non-sport suspension. I used the H and R Touring Cup package. H and R is a nice quality package that I have used on other projects so I didn't hesitate when making the choice. It lowered the car approx 2" from the non-sport height. which is about the same exact height as my stepsons 05 ZHP. Car also has a nice subtle rake to it. The ride is excellent. Couldn't be happier. BTW, If you have any kind of mileage on your other suspension parts I would use this ocassion to replace/upgrade. My car has approx 72K and I replaced the control arms, bushings etc.etc. at the same time. I have attached some "after" pics.
Lastly, my wheels are OZ Ultralegerras 18X8 in Front and 18X9 in rear. Both have a 40mm offset.
ID:	401061   Click image for larger version
ID:	401062   Click image for larger version
ID:	401063   Click image for larger version
gary442 is offline   Reply With Quote
Old 04-20-2011, 01:28 PM   #6
BavLar
That's exactly what I needed to see. I was worried that there would be tuck in the back. I see yours has no tuck. Are you satisfied with the drop up front? My son has a '04 325i with sport suspension and I would like to see my front drop down perhaps even a hair lower than his, but would not complain about it if it was the same. Mainly want good sporty ride quality.
I've replaced CA's, CAB's, and end links about 25k miles ago. I have 78k on it now. This is one reason I've considered the ZHP shock/strut/CA/sway package on clearance from many dealers & other retailers. I was hopefulf that the H&R touring springs would work well on a vert coupled with this ZHP suspension package.
What about all the little items such as mounts and other stuff? I've found a list of things for sedans/coupes that I believe would be similar for the vert. Any advice there?
Old 04-20-2011, 01:36 PM   #7
gary442
Yes, the drop in the front, for me, is just right. When my stepsons ZHP is parked next to my 330 my car is approx 1/2" lower overall which is exactly what I was looking for. The H and R kit was a total bolt on. While I was at it I also installed the strut plates which you can get from our sponsors ( I got mine from Turner..only cost about $10 each). The ride quality is excellent, even my wife likes it and that says a lot. I would say it is comparable to the ZHP ride quality and certainly not as stiff as an M3 which I didn't want. I am not sure about mating the ZHP package to the H and R springs as this starts to get complicated in a hurry e.g. spring rates etc. which helps make the case for buying a matched set.
Lastly, when I first did this mod I was running 17x8 wheels with 40mm offset and 45 series tires all around. I have since gone to 18x8 front and 18x9 rear wheels with 40 series tires and found no difference in ride quality although this may have to do with the 18" wheels being lighter than the ones I took off but my point is the H and R Touring Cup package is very versitile.
Old 04-20-2011, 04:15 PM   #8
BavLar
No rub with the 18x9's? I have same dimension wheels but I'm not certain about my offset in the back. Don't recall if it's 35 or 45. Rub is no consideration with current suspension.
Wife-approved suspension is something I'm not likely to ever get. My driving habits will probably worsen if I get the cupkit. She already hates riding with me.
Old 04-20-2011, 07:57 PM   #9
gary442
No rub...key to this is the offset. At 40mm they look like they will rub but don't.
Old 04-26-2011, 07:37 AM   #10
BavLar
Did you use the sedan springs with this coilover setup? Aren't they a little soft for your convertible?
