E46 Convertible
The E46 vert forum. Talk about dropping your E46 top here. |
#1 |
Show your VERT subwoofer set up!
So iv been looking up ideas for a trunk set up and a lot i see are coupes or sedans and only a few verts(most have ski pass sub setup) Lets see what you have!
#2 |
oops just read you wanted a trunk set up...lol
Here's mine
#3 |
I have one JL Audio 10W3 behind the amps and took out the stock subwoofer and put a metal mesh in that spot so you can see the sub through the seat, or leave the center piece in. I think it sounds the same.
![]() 2002 E46 SMG M3 Jlevis power pullies, Dinan 3:91 gears, Dinan exhaust, Dinan Stage 3 Engine Upgrade, Dinan Cold Air Intake, Dinan strut bar, Lowered on KONI shocks and H@R sport springs, Stage 2 Stop Tech brakes, Titanium Silver Carbon Fiber interior, Kenwood Double Din fueled by JL Audio!!! |
#4 |
///Motorcepts ///Maintained
Takes up a little space but gives out plenty of Bass....
TRANSFORMATION LINK http://www.youtube.com/watch?v=VmDFUtpcWhQ TRANSFORMATION LINK II http://www.youtube.com/watch?v=OxP2aDrXJk8 TRANSFORMATION LINK III http://www.youtube.com/watch?v=TcQm1dekGNE&feature=plcp Exhaust Note http://www.youtube.com/watch?v=fKfRe_c1l1w |
#5 |
Modded ///Member
Where can i get one of those bad boys?
![]() ** Too much for a signature ** Instagram @ j_cerna |
#6 |
ebay...$230. 10 inch powered Bazooka subwoofer (100w-2ohm) I hooked mine straight up to the HK woofer speaker leads, ran the power lines... Sounds great...
#7 |
do you have a link on your install? that looks great btw
![]() ![]() ![]() THANKS TO; LUTZ PERFORMANCE AUTOMOTIVE Turner motorsports Modbargains Bimmerworld JLEVISW Active Autowerks Bavarian Autosport |
#8 |
Modded ///Member
Not the prettiest setup but at the time i was i had no money and my brother let me have all this.
.this is how it always rides but i moved the sound deadening mats under my amp so it wont look messy. ![]() Zapco 750 rms ![]() Inside view (crossover) ![]() Turned my box around so you can see me 10"t1 2ohm/ported box
#9 |
Modded ///Member
Just search my friend
http://www.e46fanatics.com/forum/sho...d.php?t=459283 http://www.mfestforum.com/forum/showthread.php?t=879
#10 |
![]() My tops down, its upset. >>>Mulatto325<<< Build thread http://forum.e46fanatics.com/showthr...087&highlight= |
#11 | |
I used to make and sell frames for those who wanted to save time or didn't have the means to make their own but I sold out and haven't had time to make any more yet
#12 | |
Modded ///Member
#13 | |
I don't have any video of it but it sounds great and can be as intense as you want it to be. I have mine connected to a 500W RMS Alpine amp with only about 1/2 the gain. This way it won't rattle the trunk lid too bad and is a solid thump that doesn't overpower my music. I won't win any bass competitions but in the car its impressive.
#14 | |
My Ride: Golf R, E46 330CiC
#15 |
Modded ///Member
A sealed box with an L7? I had that originally and it rattled those plastic panels under the car. I went with the Rockford fosgate t1 10" and a ported box so I could hit all the low notes and have DEEP bass. Add an EPICENTER(with bass knob) to the Ski pass setup so you can adjust the bass as you drive since kickers aren't the best at low notes
#16 | |
#17 |
Modded ///Member
I don't use mine either but sometimes I like a trunk. I started out wanting to do a SQ setup and all I did was buy a jl500/1 amp and ended up using that in my Camaro instead since the SQ In the BMW was pretty good.
#18 |
Did you you unhook the stock subwoofer, or leave it running, too?
Any additional info on how you connected this? Looks easy and awesome! I don't need a bass-thumping machine, but a little extra push would be great. |
#19 | |
TRANSFORMATION LINK http://www.youtube.com/watch?v=VmDFUtpcWhQ TRANSFORMATION LINK II http://www.youtube.com/watch?v=OxP2aDrXJk8 TRANSFORMATION LINK III http://www.youtube.com/watch?v=TcQm1dekGNE&feature=plcp Exhaust Note http://www.youtube.com/watch?v=fKfRe_c1l1w Last edited by SMUUUUUV; 05-04-2011 at 02:17 PM. |
#20 |
Let me ask you a question, Does this Hit nice? Im looking for Good solid bass. This seems to look like it fits perfect. Also are you running off of the factory amp or do you have a after market amp?
