Headers with cats found! - Page 5 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 30 votes, 5.00 average. Display Modes
Old 04-28-2011, 11:48 AM   #81
DanFromTucson
My Ride: 2004 330ci ZHP
Originally Posted by TxZHP04 View Post
They look white.
Seriously though, they look great. It's a shame they will be so well hidden once installed. I'll see if I can post some updated pics this weekend.
It's really amazing that a ceramic coating only 0.015" thick can really make a significant insulating difference. Cost for the coating was $275 plus return shipping.
You can paint the Swain White Lightning coating. I checked with Swain about this several years ago, and they basically said "have at it!".
DanFromTucson is offline   Reply With Quote
Old 04-28-2011, 12:28 PM   #82
TxZHP04
My Ride: ESS TS2+ ZHP
Yep, you can paint over the coating with any high temp paint color you like. I probably won't bother as they're pretty much invisible once installed. I actually like the white which is why it's too bad they're hidden behind the heat shield built into the gasket (which I plan to try to retain if at all possible).
Old 04-29-2011, 09:18 AM   #83
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
Mine was $195 (silver inside and outside) and no shipping because they were close by.
Jim
Jim Murphy is offline   Reply With Quote
Old 04-29-2011, 11:04 AM   #84
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Give me a shout if you need a hand installing them. If you haven't already, buy new studs/nuts.
Brady
Old 05-06-2011, 10:21 AM   #85
Species0113
My Ride: 2001 BMW 330CI
Just curious if anyone has ever heard or used these guys before? TRUCKPARTSHUB.COM
They have this Magnaflow 49758 listed for $548.46 shipped. Just seems too good to be true.
I called them to verify the part number and picture and they said it was correct and they were the lowest in the country. lol
https://www.truckpartshub.com/produc...-fit-converter
Species0113 is offline   Reply With Quote
Old 05-06-2011, 03:05 PM   #86
Rob43
Suspension Guru
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
OK, took a look.
Where does it say you get two of them ?
SUMMIT POINT WV 1:24:229 SCCA
Old 05-06-2011, 03:30 PM   #87
Rob43
Suspension Guru
Rob43's Avatar
Yeah, there scamming you if they didn't mention you also need the REAR section PN #49759, for the same price. Total $1096.92
The question of the day is does this "DIRECT-FIT CATALYTIC CONVERTER
PART# 49760" fit in the center section of the Magnaflow PN #16533. The catback system that so many of us bought into on the group buy, a year & a half ago ? If it does we could easily just swap this cat section in at the time of state inspection. Quick & easy, and then just pull it back out.
Old 05-06-2011, 03:31 PM   #88
darksideracer69
My Ride: 01 325ci
Originally Posted by Rob43 View Post
OK, took a look.
IMAG02051
Old 05-06-2011, 03:41 PM   #89
Species0113
OK, took a look.
It doesn't. Thats why I called. He didn't speak too good of engrish. But he did say it was complete. Maybe there was a small communication barrier.
Old 05-06-2011, 04:17 PM   #90
Rob43
Suspension Guru
Rob43's Avatar
The question of the day is does this Magnaflow "DIRECT-FIT CATALYTIC CONVERTER
OK, just had a talk with "Dave" a tech at Magnaflow, he said that PN #49760 would be a direct fit for anyone using the Magnaflow catback PN #16533.
He informed me that he needed to talk with his engineers about it actually working for are needs. His two concerns were, 1) Are the to new cats in the #49760 to far down stream to be effective? 2) Is the concentration of precious metals the same or as high as they are in the "header cats" that Magnaflow makes.
http://www.truckpartshub.com/product...-fit-converter
Old 05-06-2011, 04:45 PM   #91
TxZHP04
Depends on what you mean by effective. If we're talking about not getting CELs, then based on the overwhelming lack of success of people attempting to run cats anywhere downstream of the stock location, I'm going to go out on a limb and declare the answer to (1) to be a big fat no.
Old 05-06-2011, 04:51 PM   #92
darksideracer69
My Ride: 01 325ci
I ran cats downstream successfully, no SES
IMAG02051
Old 05-06-2011, 05:19 PM   #93
TxZHP04
There are far more failures than successes. You got lucky.
Old 05-06-2011, 05:31 PM   #94
Rob43
Suspension Guru
Rob43's Avatar
Depends on what you mean by effective....... I'm going to go out on a limb and declare the answer to (1) to be a big fat no.
This is the problem, One NO / One YES.
I should here back from Magnaflow by mid next week. When the time comes (Emission test), I still may give this a try because of the simplicity of swapping it in & out.
Old 05-10-2011, 03:52 PM   #95
mrclickcola
My Ride: 325i
Has anyone found out if there are any substantial gains that come from this or gains at all on a 325i na motor e46.
mrclickcola is offline   Reply With Quote
Old 05-10-2011, 04:06 PM   #96
TxZHP04
To the best of my knowldge, Jim and I have the only 2 sets of these so far and we both have supercharged 330s and neither of us has them installed or dyno'd yet.
Old 05-11-2011, 09:24 AM   #97
Jim Murphy
Unfortunately, I did not get a chance to dyno mine BEFOREHAND as it lost compression. So, the dyno will only show the after HP. Hoping for the dyno in a couple of weeks after the rebuild.
Jim
Old 06-07-2011, 10:11 PM   #98
JB_ZHP
My Ride: 05' ZHP Dinan 3
Has anyone installed these yet??? I am VERY interested in hearing feedback and seeing some before and after numbers, although I doubt the gains will be that impressive....
e46 signature
JB_ZHP is offline   Reply With Quote
Old 06-16-2011, 03:29 PM   #99
Jim Murphy
Well, it is taking a really long time but the motor with the header/cats are installed - no fitting problems so far - and the rest of the exhaust should line up okay. More updates later.
Jim
Old 06-16-2011, 04:34 PM   #100
TxZHP04
Jim
Good to hear. I was looking things over last weekend and I'm a little curious about how easily accessible the pre-cat O2s are going to be given the different angle at which they mount in these headers. It's also going to be interesting to see if I can still manage to retain the factory heat shields when installing these with the motor still in the car.
